For as long as I can remember you could approach Oxford from the north at speed with flashing yellows controlling the approach to the 25mph turnout for the platform road just north of the station; but from the south you were brought almost to a stand at Osney Cemetery before the signal cleared even when the platform was empty. So I was delighted when the whole layout south of the station was recently remodelled: a much-needed improvement I thought. Imagine my disappointment to find that, not only is the new turnout still 25mph when a longer-lead for at least 50mph would have been possible, but worse there's still no approach-control and the potential for 2-minute time saving for arriving trains appears to have been missed. Or will this be rectified when control passes to the TVSC at Didcot?
Thanks jimm - let's hope that the timetable for next summer's completion of the total scheme is achieved.
I must make an effort and take an Oxford General to Islip cheap return to see the alterations and progress from a ringside seat.
Brian M, for 10p more you can get a cheap return from Oxford to Bicester which will allow you 2tph to choose from rather than the rather sparse service that Islip gets.
The track work in the Wolvercot tunnel area (and the route generally) is complete, it is visible in a number of videos taken in and since December 2016.Does anyone know if the Down Bletchley through Wolvercote Tunnel is completed?
The easternmost of the new up carriage sidings at the station are now complete and at least one of them is in use with temporary lighting on the trackside walkway. Work to lay the other new up sidings is under way.
wasn't there talk at some time of opening a new station about 2 - 2.5 miles south of the present station, near where the southern ring road crosses the main lines? Or am I imagining it?
Could be worse.That might also be down to them replacing HSTs on the Cotswold line with knackered old 2-coach Turbos. Service seems to have fallen off a cliff edge in the last month or so.
Could be worse.
Do you want some 2 car knackered old Pacers instead?
ooooh I bet half the north would beg to differThere's very little difference.
Before the Turbos came along they had the 155s, built by Leyland Bus at Workington.Could be worse.
You make it sound like every HST diagram over the Cotswolds has been replaced by a 2 car Turbo as routine, that certainly isn’t the fact. There are now 800s running on the Cotswolds as well and if there is need to replace one of those, it’s usually by an HST. Yes, there has been incidences of 2 car Turbos as a short notice replacement, it depends what’s available! A 2car may be preferred instead of a 3car as due to no SDO on the Turbos, the 2car can be used to stop at the short platforms at Combe & Finstock.
Both Hanborough and Charlbury have recorded falls in passenger numbers since Oxford Parkway opened. Anecdotally Parkway appears to have taken a non-negligible amount of off-peak leisure traffic from the Charlbury area, but not commuter traffic.
Could be worse.
That might be due to the car parks at Hanborough and Charlbury generally being full by the time the morning rush hour is over? That said, even Parkway fills up from time to time. Car park extensions at the Oxford area stations are going to have to be considered in the near future.
DESIGNS for a new train station have already been drawn up as business leaders and MPs push for Oxford's Cowley Branch Line to be reopened next year.
A Government-backed report called for the rail line to be reopened for passenger services in 2019 and a £300,000 study into how it could happen was also commissioned.
Chiltern Railways said the timescale was 'ambitious' but the Oxford Mail can reveal plans for a new station at Oxford Science Park have already been drawn up as part of an architectural competition.
The scheme could also include another station at Oxford Business Park with journeys into the city taking less than ten minutes.
