If we had trolleybuses I would suggest a bored tunnel underneath it
Like a tube?
Which says very little of any substance. It is clearly designed to "float" ideas that are potentially controversial so as to trigger a response now. This will allow Westminster City Council (WCC), TfL and City Hall to judge likely opposition from the public / parties not already involved in the planning work that's been going on for years.
It's very clear that WCC are reluctant because of overspill risks to adjacent streets which will annoy residents and businesses. TfL is shackled because the Mayor wants pedestrianisation and therefore can't publicly put forward a "pro bus" argument. The result will be pedestrianisation with cycling allowed. Taxis will get special ranks and access as close to Oxford St as possible and the buses and coaches will all be booted out with no running down roads like Wigmore St or New Cavendish Street. Existing trunk routes will be curtailed, diverted well away or simply axed and merged into other routes. No one is putting forward a case for buses to retain a major public transport role in Zone 1 - it's all about Tube / Crossrail / bicycles and shank's pony. The general public will only twigg what's happening when it's too late.
Sadiq Khan may be the son of a bus driver, but he is showing no awareness of the importance of buses in the public transport mix. I'd imagine he's listening far too much to Val Shawcross and her opinions on how bus routes should be structured. Allowing people to change buses in limited circumstances without extra charge is worse than provision of a 'through' service, and the bus will be abandoned in greater numbers than at any time since the 1958 Bus Strike forced changes to travel patterns which were just beginning to be rectified when the Congestion Charge took effect. All that good work, maybe not undone in a stroke but it could be perceived that way.
I'd also repeat something I've said on here many times over the last few months, that the security issues surrounding Oxford Street becoming pedestrianized are now immense. I cannot imagine the Met Police sanctioning such a policy.
If the consultation process is anything like that for the Oxford Street and surrounding area bus routes, then I wouldn't waste any effort in challenging the views being expressed. In the case of the bus routes, even before the consultation process was closed TfL had stated that Borismasters made surplus by changes to the 73 route etc were going to be used elsewhere. Lo and behold, all changes that were 'consulted' on are going ahead, apart from the one possible expansion (of the 23 to Wembley!)
TfL said:We could divert some buses to a suitable alternative route such as Wigmore Street, which is not currently served by bus.
TfL said:That said, despite making up almost a third of the traffic, taxis account for only two per cent of trips on Oxford Street.
That seems very cynical. Your suggestion of no running down Wigmore Steet, appears to be somewhat contradicted by this statement in the consultation:
I also don't see any suggestion that, as you claim, bicycles are being promoted at the expense of buses. The consultation simply presents a number of options for restricting both cycles and buses (and also taxis and delivery vehicles) to varying degrees from accessing Oxford Street and directing them to alternative routes instead.
That really shows up how a tiny proportion of people using taxis (and I suspect, outside of Oxford Street itself, Uber cars) are completely clogging up the streets of central London for everyone else. To my mind that clearly demonstrates the urgency of removing taxis as far as possible from not just Oxford Street, but all of central London.
Personally, I do hope that a means will be found to completely pedestrianize Oxford Street (with the only possible exception being for delivery vehicles during restricted hours at night).
You'll then just have stops for Oxford Street East, West and Central and use the tram to connect them.
Where else is this tram going to go?
You could extend it west to Ealing and Ruislip, and east to Redbridge...
Sounds expensive as well as requiring another change for anyone going to Oxford Street.
Why are changes suddenly a problem on buses when they are not on the Tube?
I'm not here to defend Sadiq Khan but he seems to be coming in for some totally misguided and irrational criticism here and what exactly are these security issues that the Met Police are unlikely to sanction?
Yes my comments are cynical. I disagree with the policy. I also disagree with the continued dismantling of Central London's bus network. I am hardly going to view these things in a positive light.
There are two points here.
1. Pedestrianisation of Oxford St is a Manifesto commitment. These are the things that get done. Things which are not do not garner support or are allowed to whither. Unsurprisingly protecting bus services in Central London does not feature in Mayor Khan's manifesto.
2. The things you quote from the consultation are things *known* to be controversial which is why they are being "floated" now. I have been reading comments about buses in Wigmore St for years and years. I know from a local resident that this is a deeply controversial issue for those who live there. They don't want it. The local councilors know it is not wanted. Mentioning it now is guaranteed to trigger a response. Ditto the proposed bans on taxis (the entire taxi trade hates TfL, the Mayor and many Assembly Members with a passion) and cycling (we all know the cycling lobby is very adept at generating opposition and applying political pressure).
As the consultation unexpectedly coincides with purdah I suspect it has been stripped of detailed proposals at the last minute and floated with "concepts" or "possibilities" to flush out opposition and responses. This is a very simple political tactic used to prepare the ground for the next stages of the process whereby "concessions" can be granted even though the idea was never serious in the first place. Work has been going on this scheme for several years now and I can't believe that there are not detailed plans with a wide variety of options prepared by WCC / TfL and other stakeholders. And yes that is *also* very cynical but we are dealing with an intensely political issue here.
Changes on the Tube require walking down a well-signed route and waiting only a few minutes on a platform, probably under cover the whole time.
Changes on buses involve deciphering a map (if there is one) to find the correct stop, walking along a crowded pavement and possibly across a busy road, and in wet weather getting soaked by the rain and/or splashes from passing vehicles. There is then an unpredictable interval before the next bus arrives (or sometimes several).
You were also usually charged an extra fare for your trouble, though that at least is being sorted out in London.
They are a problem on the tube!
Is something like a Bus Station such an alien concept to London?
I don't believe you're unaware of the latest tactics of ISIS supporters and others with grievances to target crowded open spaces in Europe with vehicles driven by people seeking, in their perverted thinking, martyrdom. Creating such an open space amid much publicity in our capital city would, imo, be tantamount to inviting carnage and, I believe, my view might well be shared by people whose views (unlike mine) count.
This is rubbish, anti-vehicle bollards could be put at either end of Oxford Street to prevent vehicles coming into the area. These can already be found around at airports, the majority of landmarks and football stadiums in London.I don't believe you're unaware of the latest tactics of ISIS supporters and others with grievances to target crowded open spaces in Europe with vehicles driven by people seeking, in their perverted thinking, martyrdom. Creating such an open space amid much publicity in our capital city would, imo, be tantamount to inviting carnage and, I believe, my view might well be shared by people whose views (unlike mine) count.
I don't see the point of the proposal to terminate route 73 at Oxford Circus and then divert 390 to Victoria instead. why not just drop route 390 ?
one of the routes could go via Piccadilly (though that is also full of buses) - route 14 used to link to Euston and Kings Cross via piccadilly to South Kensington.
route 30 could extend from Marble arch to Victoria to maintain another direct link victoria to kings cross (via Baker street).
