Oyster card on Javelin
GodAtum
11 Dec 2009
A bit confused! Ordinarily one cannot use an Oyster card on the Javelin services but can use the special Games Travelcard between St. Pancras and Stratford International stations?
Mojo
7 Aug 2005
That is correct. Once the Javelin services start running later this month, Games Travelcards will be valid on them, but other Travelcards and Oyster Pay As You Go (PAYG) will not.
GodAtum
11 Dec 2009
Ah OK, do you have any dates on when they will be accepted?
LondonJohn
17 Jul 2011
My travel to the games will be covered by my current travelcard so the free games one is a bit of a waste for me though I might take a few trips back and forth from St Pancras to Stratford just to stick 2 fingers up at SET for not allowing TC on their so elite train that it doesn't have a first class.
GodAtum
11 Dec 2009
I have a LOCOG Oyster card, I just phoned their helpline and they said I cannot use it on the Javelin!?
Just read this:
Games Family and Games Volunteers can use their special pink Oystercards to travel on our High speed services between St Pancras and Stratford International, both in the run up to the Olympic Games and in the period between the Olympic and Paralympic Games. This is only valid if the Accreditation card is presented with the Games Travelcard.
Please note no other Oystercards are accepted on High Speed services.
MikeWh
15 Jun 2010
Crayford
No, it won't be valid on HS1.
See http://www.oyster-rail.org.uk/2012/05/olympic-volunteer-oyster-cards/
From East Croydon, I would consider changing at London Bridge for the Jubilee Line, which will probably take a similar length of time to changing at St Pancras, but without giving SET any undeserved extra money!
Trying not to perpetuate the pantomime that this has become, but ...
"Oh yes it will!"
Southeastern have agreed, probably under a lot of last minute pressure, to allow holders of Games family Oyster cards to travel free providing they also have their accreditation with them. If you continue through the comments on that page you'll see the saga unfolding. There are no touching facilities at either end so the cards and accreditation need to be shown at the manual gate.
P
paul211b
Guest
I have received my pink oyster card and I am accredited for the games.
Can I use this on the HS1 train from Gillingham Kent to Stratford international?
seem strange that its only valid between Stratford int and St Pancras int. Only gives you Ebsfleet...pointless.
spoke to a barrier man this morning and he did not have a clue..
thanks
MikeWh
15 Jun 2010
Crayford
Welcome to the forum,
No, the pink Oyster cards are only valid between St Pancras and Stratford. The next station (Ebbsfleet) is well beyond zone 6. Assuming that your Oyster has a travelcard on it then you need a ticket to boundary zone 6 and can take any train from Gillingham to Lewisham then the DLR to Stratford.
