Oyster / Railcard discount - evening peak
Acton1991
20 Jan 2019
Hi there - wondered if someone could confirm whether you get 26-30 railcard discount on Oyster fares in the evening peak?
It seems to confirm it here, but just wanted to double check.
thanks!
thanks!
Not on single fares other than from outside Zone 1 into Zone 1.
Look at the single fare finder and select National Railcards.
MikeWh
15 Jun 2010
Crayford
The off-peak cap for railcard holders does apply for travel in the evening peak but the effect of that will depend on travel earlier in the day.
My experience is that peak fares in the evening often ensure that the reduced off-peak cap is indeed reached.
How does the Oyster off-peak cap for railcard holders work if a journey was made before 09:30 of lower value than the difference between the off-peak and anytime cap?
MikeWh
15 Jun 2010
Crayford
If spend before 0930 is less than the difference between the caps then the effect will be the off-peak cap plus the journeys made before 0930. Take a look at https://oysterfares.com/information-pages/capping-examples/ where the third example shows exactly this scenario.
Acton1991
20 Jan 2019
It really isn't confusing.
Railcard discounts on Oyster
* apply to off-peak single fares
* don't apply to peak single fares.
You can find out fares on the single fare finder https://tfl.gov.uk/fares/find-fares/tube-and-rail-fares/single-fare-finder
What you find simple may be confusing for others, please be mindful of that. That's why we ask questions. But thank you for your help.
Yes, sorry.
I note, however, that TfL probably did set out with the intention of it being straightforward and the application of railcards to single fares is at least consistent - it is the classification of a single fare as peak or off-peak that increases complexity.
I must admit that I would never make a 'new' journey on Oyster / Contactless without first checking the Single Fare Finder, which might be a sign that it could be seen as confusing.
