I dont know Paddington at all, but I assume they will have to remove overhead lines to get a crane in to lift and rerail the train ??
Depending on how far off the line it is, they might not need a crane.
Facebook and another Forum say Cat A SPAD at SN6004. If the info is available elsewhere in the public domain, are we speculating ?
There installing questions then there is gossiping and spreading rumours. At end ofndaybthisnis why we have the hmri/raib to do there investigation it's what there paid for the armchair investigators are quick to come out with ASSUMPTIONS and this is how rumours start. Let the real investigators do there job. How would you like it if you made a big error init place of work that affected others and people starting making speculations about what you done to be totally different to what actually happened as they were not there to see what you done. Works both ways end of the day we were not there so can't say what happened or why that's down to te investigators and the driver and staff involved to discuss not on a public forum
Can we keep the speculation to a minimum please
Doubtful, http://www.bbc.co.uk/news/uk-england-london-36555082
Will the RAIB likely investigate this derailment?
Would the sidings be equipped with AWS/TPWS/ATP?
Poor driver.
Does raise questions as to why have automatic derailment devices when you could just fit a magnet.
What would the magnet do? Stick the train to it?
Some of the things people come out with on here is golden.
Thoughts with the driver
TSo they did their job and derailed the train but straight into a gantry?
Yeah. Perhaps a cheaper alternative would be sellotape.
In all seriousness though, I meant AWS.
No it's just not nice I feel to speculate that's all after all we know how the press can get things wrong sometimes that's all didn't mean to start a argument
Is there anything so wrong in informed speculation? Network Rail have already told us there was a SPAD.
Really only three possibilities. Driver error, signaller error, infrastructure fault.
To me whatever happened with the unit is one thing. But who allowed electrification gantries etc to be put in the 'line of fire' from said trap points? So they did their job and derailed the train but straight into a gantry?
I know a set of trap points that run over the side of a bridge !
Mile north of Banbury the trap points on the down loop lead straight into the Oxford Canal!
Pretty much yes. A big giant magnet comes out the ground and the train gets magnetised to the track.
That doesn't look like a Heathrow Express to me.1Y73 being evacuated nr Ladbroke Grove
Wouldn't work in this case. It's an aluminium train...
Yes. That long siding along there was used very intensively. If I recall correctly, by mail, Red Star parcels, and I think newspapers - but that was 40+ years ago.Is this the little bit thats left of the old "engine only" line that formed an up-and-over for locos to access old oak common without blocking the station throat. Also wasnt there some sort of goods/parcels platform along this stretch?
Trap points are provided to protect every exit from a siding onto a passenger running line
Sidings, if falling towards the line, or on a level, to be provided with locked chock blocks, or locked points, leading into a blind siding
Sidings to be so arranged that shunting operations upon them shall present the least possible obstruction to the passenger lines. Safety points to be provided upon goods and mineral lines and sidings, at their junctions with passenger lines with the points closed against the passenger lines and interlocked with the signals.
Was going to form part of a train to Henley-on-Thames. 25mph. Its derailed on the catch points coming off the Link Line.
I can't comment on its use as an "engine only" line, (while I do recall light locos making their rapid exit immediately behind a departing service, I don't remember where they went or how they returned).
Which of itself is a safety feature. Should there not be consideration of resilience as well? Directing a train falling foul of the trap points into a collision with an electrification gantry is going to magnify the disruption effect by several degrees of magnitude.
