Passenger charter discounts/void days on changeover season tkt
A1
20 Dec 2012
When a changeover occurs, does this affect the calculation of any discount/void days due to poor performance?
Example:
Z1-Hayes & Harlington changing to Z1-West Drayton (so FGW) a week before expiry. When the ticket expires and is renewed, is the replacement treated as if you had the Z1-West Drayton for the entire year, or is there some other method used to calculate void days and discount?
hairyhandedfool
14 Apr 2008
Void days are added to the end of a ticket, so when a changeover occurs on a ticket with void days, these days are deducted from the number of days remaining before the base rates are worked out. They are added on again at the end of the process when the ticket is issued. No new void days are added for the new journey.
Charter Discounts are lost when the new ticket's base rate is worked out, however, the base rate of the old ticket is still worked from what was paid for it.
barrykas
19 Sep 2006
Just as an addendum to the above, where "void days" are owed on the original ticket those should be refunded in the normal manner before the change-over is calculated. They CAN NOT be carried forward.
Also, charter discounts CAN be carried forward if both the old and new journeys are within the same charter service group. The "base rate" is calculated based on the discounted fare.
A discount CAN NOT be carried forward where the original journey is subject to discount and the new journey is not, nor can one be applied where the new journey is subject to discount but the original journey is not.
hairyhandedfool
14 Apr 2008
Just as an addendum to the above, where "void days" are owed on the original ticket those should be refunded in the normal manner before the change-over is calculated. They CAN NOT be carried forward....
That's not how I understood the notes in iKB.
.....Also, charter discounts CAN be carried forward if both the old and new journeys are within the same charter service group. The "base rate" is calculated based on the discounted fare....
Again, this is not what I understood from reading iKB.
EDIT: I'll have another read when I'm next in work.
barrykas
19 Sep 2006
I should have been clearer in my previous post.
I agree that, where "void" days were added when the ticket was renewed, they should be deducted prior to calculating the base rate for that ticket for change-over purposes, then added back on when issuing the new ticket.
However, if there are any that have become due since, iKB (and The Manual before it) states that they must be refunded prior to doing the change-over calculation.
Picking an example at random:
Passenger holds a season ticket from Alton to Waterloo (SWT Mainline Group 4). On renewing the ticket on 1st January 2014, they had 5 "void" days added, extending the validity of the new ticket to 5th January 2015.
They then apply for a change-over to Aldershot to Waterloo (thus remaining in the same charter service group) on 20th August 2014.
When calculating the base rate, the 5 additional days are deducted, and the relevant fares divided by 365 as normal.
Since they renewed their ticket, two additional half days have been accrued (8th and 10th July). A refund must be processed for these prior to doing the change-over. The additional day can not be added to the new ticket (extending it to 6th January 2015).
As for charter discounts, it's mostly common sense that a passenger shouldn't get "credit" for poor service they haven't experienced, and nor should a TOC be "penalised" for poor service they haven't caused.
Some further examples:
  • Customer holds a Slough - London Terminals season with a 5% charter discount, wishes to change to West Drayton - London Terminals. The discount can be transferred, as both journeys are within the same charter service group.
  • Customer holds a Slough - London Terminals season with a 5% charter discount, wishes to change to Gerrards Cross - London Terminals. The discount can not be transferred, as no discount applies to the new journey.
  • Customer holds a Gerrards Cross - London Terminals season with no charter discount, wishes to change to Slough - London Terminals, where a 5% discount would apply. The discount can not be applied to the new ticket, as the customer hasn't been travelling with FGW.
Having said all that, it's unlikely that the OP would be able to do a change-over where less than a month's validity remains on the original ticket, due to the limitations imposed by some Ticket Issuing Systems, which still apply the old rules.
hairyhandedfool
14 Apr 2008
However, if there are any that have become due since, iKB (and The Manual before it) states that they must be refunded prior to doing the change-over calculation......
Oh, yes, sorry, I see what you mean now.
