Passenger load on Bristol GW services
seawolf
7 Jan 2012
Portsea
Can anyone from the area comment on how feasible it is to commute on the HSTs and stoppers into Bristol Temple Meads, from Swindon (on HST) and intermediate stations such as Bath (on anything) ?
I imagine they're quite busy in the two rush hours, but when have you found they start to get and finish being uncomfortably busy for a commuter?
lightning76
27 Aug 2009
Here
The HSTs from Swindon don't really get uncomfortably busy at all. Busy, yes, but not so much so that one would wait an hour to avoid them. The shorter trains from the Westbury line can get pretty wedged between Bristol and Bath, but it is only a 15 minute or so journey. It certainly isn't comparable to certain trains into London, or the 1715 ish Sheffield to Manchester I once had the misfortune of taking.
Flamingo
26 Apr 2010
Lots do the commute. HST's should, in my experience, fit everybody. Don't confuse lots of people standing with no seats available. The two don't mean the same thing. Of course, if you get a First Class season ticket, there is even more space.
seawolf
7 Jan 2012
Portsea
Thanks both. Yes, doesn't sound quite like going in/out of most northern cities!
Can I assume that the servies are quite reliable enough, if they're well used by commuters?
Is it also similar from the Cheltenham / Gloucester region?
jimm
6 Apr 2012
Closer you get to Bristol, the busier the GWR stoppers get, especially from/to Yate. And bear in mind that whereas from Swindon the fast trains are nice long GWR HSTs with lots of seats, the fast trains from Cheltenham are XC Voyagers...
dzug2
5 Feb 2011
The occasional XC HST from Cheltenham as well
jimm
6 Apr 2012
We're talking commuting times here and bar the rather busy HST leaving Temple Meads for Leeds at 17.30, none are at times suited to commuting in or out of Bristol.
Bit different to an HST every 30 minutes from/to Bath, Chippenham and Swindon.
Parallel
9 Dec 2013
The HSTs between Swindon and Bristol can get busy but not too bad unless there's disruption. In terms of stopping/other services between Bath and Bristol (i.e. Bristol - Westbury etc), these can be very busy.
LordCreed
28 May 2014
What about services to Weston and Taunton?
XC Voyagers can be uncomfortable in the peaks. You'll get on, but most likely will end up standing and the carriages can get very warm.
The units can be busy as far as Weston, but they do quieten down by Taunton.
lightning76
27 Aug 2009
Here
In my frequent but random experience the service east of Bristol is reliable if one isn't too discerning. Delays of 10-15 minutes are common and should be factored in to any plans. Serious delays or cancellations are no better or worse than anywhere else.
