Realised the other day whilst doing some spotting that all the Pendos passing by had their rear pantograph raised.
From NW Rail noticeboard, I suspect this is not far from the truth.
Some interesting news about the Class 390 Pendolinos related to the use of the current-collecting pantographs when on the electrified lines where they normally roam. Each train set has two of these, one on the third carriage from the 'front' and one on the third carriage from the 'rear.' Only one is required for normal working, and the original intention was that the rear one (in the direction of travel) should be used, and in their early days around 2004 this was the case. However, soon after entering passenger service, it was decided that the front one was to be used. An apocryphal story at the time was that Richard Branson thought this looked better ... although a more prosaic, if cryptic, explanation is 'infrastructure issues.'
However, these issues have now been resolved, we are told, and a recent instruction to train drivers states that from 21 December onwards, they should revert to using the rearmost pantograph. This seems to have some obvious advantages, especially that if some mishap with the overhead wires causes pantograph damage, the lowered front unit will have already passed by safely, and the train may be able to continue by using it. Another point is that carbon stains on the train roof are caused by small amounts burned off from the current collector, and using the rear one will keep this to a minimum area. It is also felt that this will will help reduce the likelihood of damage to the carbon collector head itself, which has been a problem with these trains.
