Pictures/definition of ticket stamps
Discussion in 'Fares Advice & Policy' started by james-martin, 13 Aug 2019.
  1. james-martin
    james-martin Member
    54
    15 Jul 2013
    Sheffield
    Evening all,
    I was just wondering whether there is an official definition document (or failing that a photo that can be annotated) that defines what the different sections mean for ticket stamps? I'm essentially keen on knowing whether it is guaranteed standardised across TOCs and whether staff get allocated a unique identification number and being certain I'm looking at the right number.
    Many thanks,
    James.
    Rail Forums
  3. yorkie
    yorkie Administrator Staff Member Administrator
    45,296
    Can you clarify what you mean by "ticket stamps"?
  4. james-martin
    james-martin Member
    54
    15 Jul 2013
    Sheffield
    One with the date stamped in and two other numbers/strings, one in line with the date, the other perpendicular. Google was not my friend on this query ;)
  5. alistairlees
    alistairlees Established Member
    1,393
    29 Dec 2016
    Do you have a photo?
  6. yorkie
    45,296
    If you mean stamps when a ticket is inspected, there is certainly no national standard; on most TOCs it's random, and typically means nothing more than the journey has commenced.
  7. pdeaves
    pdeaves Established Member
    2,782
    14 Sep 2014
    Gateway to the South West
    I assume the original poster refers to the 'ink press'-type gadget that clippies use. At least one portion of the text should be the train headcode (e.g. 1A23) that defines the train it was used on. However, this relies on the guard setting it properly!
  8. james-martin
    james-martin Member
    54
    15 Jul 2013
    Sheffield
    Thanks Yorkie and Pdeaves your points helped me find the stamper name which is used at inspection. It's a Zifa type. https://www.zifferndruck.de/en/products_ticketstamper.shtml That page contains a non UK sample print.
    So by the sounds of it there is no standard requirement for the information included by a TOC? It seems from the distributor website the product allows for both setting numbers/identities by dials and have some sections which are only internally adjustable. I guess where the perpendicular info is a staff identity that will not have wheels for external adjustment? :)
  9. Haywain
    Haywain Established Member
    4,073
    3 Feb 2013
    Yes, a Zifa stamp. Another bit of the information is, I think, the guards duty/diagram number.
  10. james-martin
    james-martin Member
    54
    15 Jul 2013
    Sheffield
    I had never seen it written before and thought from an ancient memory it was a 'ZIP' stamper and so had my Google fail! Good to know the correct term now :)
Share This Page
