Platform length at London Victoria
Discussion in 'Infrastructure & Stations' started by IanKR, 9 Aug 2015.
Thread Status:
  1. IanKR
    IanKR Member
    90
    21 Oct 2014
    London SE9
    On two occasions recently I've arrived at platform 2 at London Victoria on a 12-car train (375?) from Ramsgate. On nearing the station the automatic announcement has stated (after the usual "we will shortly be arriving at London Victoria ...") that passengers should not alight from the rear three cars of the train, due to the short platform. On the first occasion this surprised me, as I was fairly certain that all the platforms at VIC could easily handle 12-car trains. On the second occasion the guard buzzed in immediately after the auto message and advised passengers to ignore the bit about platform length, as this was not correct!
    Just wondering why this part of the announcement could not be excluded from the message - and why it's there at all; are there short platforms anywhere on this route that require SDO?
    Rail Forums
  3. kjhskj75
    kjhskj75 Member
    127
    14 Jul 2012
    According to the Quail maps, platforms 3-6 & 8 at Victoria are too short for 12-coach trains (all on the Chatham side), so it's probably a default message whenever the software detects a 3rd set. You just happened to be lucky today.
  4. The Planner
    The Planner Established Member
    9,606
    I would check the sectional appendix to see what the real lengths are and compare with actual train length.
  5. Temple
    Temple Established Member
    1,355
    3 Jun 2012
    I am by no means an expert on this, but have a fairly good understanding of ASDO, so I'll try and explain it...
    The 'issue' here is with the type of Automatic Selective Door Operating (ASDO) system. The Class 375s were the first units to have full ASDO, with the system known as Hima-Sella Tracklink 1. Simplified, this system uses a GPS (technically GNSS but GPS is a more familiar term to many) receiver in the leading cab which is linked to a database of every station and their door openings. Each station is defined by a central point, and then has a 300m geofence around it - which, when entered, confirms the station and doors to open to the train.
    Where Tracklink 1 fails is that it treats every platform as the same length, and for safety this is understandably assumed to be the shortest platform. When developed, there was no way to identify individual platforms and GPS wasn't accurate or reliable enough to be used, and so the same length was assumed for all. For example, if we take the relevant platforms at Victoria, from shortest to longest (below), you can see the shortest can only just hold 9 carriages. Now, when the service leaves the previous station, there's no absolutely firm way of knowing which platform it will arrive into and the system treats them all as being 188m long, just in case it is routed into platform 3.
    Platform 3 - 188m (9 carriages of 375 stock is around 182m depending on the subclass and combinations)
    Platform 4 - 201m
    Platform 8 - 221m
    Platform 6 - 245m
    Platform 5 - 247m
    Platform 1 - 270m
    Platform 7 - 286m
    Platform 2 - 359m
    This might all make more sense when you compare it to Tracklink 2, on Class 377s for example. With this 'newer' (relatively newer, it's now fairly old!) version there are also added readers, antennas and transmitter loops in the four foot to identify specific platforms. The train will still assume the shortest platform length, but if the train goes over a transmitter which identifies it is approaching a longer platform, then the number of carriages on which doors will open increases.
    Now, of course, coming to the reality of things... Firstly, I have never been on a 12 car 375 that has been too long for a platform at Victoria - it's very rare for it to happen. When a 12 car 375 arrives at Victoria platform 3, only the doors on the front 9 vehicles will automatically open. If one arrives into platform 2, then again, only the doors on the front 9 vehicles will automatically open when the driver releases the doors. A manual selection can then be performed on the 375's MITRAC system (train control and management) if the driver knows and is absolutely sure the platform can hold 12 carriages. This takes slightly longer, and is noticeable if you're in the rear X carriages awaiting the manual selection to release the doors, but is only around a 10 second wait. Again though, in reality, 12 car trains mainly work commuter services which have regular passengers. Those in the rear carriages know that the doors will probably open, contrary to the announcement so don't all rush forward. But, there will be one day when, due to disruption or something out of course, the train pulls into platform 3, the doors on the rear 3 carriages won't open, passengers will complain... but they'll have been told!
    How could it be fixed?
    Well, personally musing, I guess you could remove the announcement altogether and instead issue a briefing to guards to say something along the lines of... "Depending on the platform we are allocated at Victoria, the doors on the rear 3 carriages may not open due to some short platforms, but I'll let you know just before we arrive if this will be the case as at the moment I do not know which platform we will arrive into" and then just before arrival, the guard could read the route/platform indicator and make a further announcement to confirm or correct how many carriages will open. But, this is fairly long winded, confusing, complicated and it can't be guaranteed that a guard will make the announcement every single time (and then there could be confusion if there's no announcement at all).
  6. jopsuk
    jopsuk Veteran Member
    12,153
    13 May 2008
    At Victoria, if a 12-car train is put into (say) Platform 3, does it then foul points and block in other platforms?
  7. 30907
    30907 Established Member
    8,038
    Yes. 3 and 4 have always been basically 8 car. 8 used to be 14 cars (boat train with 2 MLV) like 5-7 but has been shortened.
  8. Hophead
    Hophead Member
    914
    5 Apr 2013
    Somewhat ironic to get that announcement coming into platform 2 - clearly that's one platform which can accommodate 12 coaches with a whole lot to spare.
  9. IanKR
    IanKR Member
    90
    21 Oct 2014
    London SE9
    Many thanks for your comprehensive and detailed response.
    Surprised that there are three platforms on the Southeastern side at VIC that won't carry 12-car trains (assuming a 20m carriage length)!
  10. 30907
    8,038
    Particularly surprised that 8 was shortened to less than 12.
    Though I have a feeling that may be due to subsequent changes affecting all platforms (new buffers taking more space?), as I though 3 could take 10 cars of EP stock.
Thread Status:
Share This Page
