750V nominal wiring would be able to support a Type 1 equivalent, which means that if we can solve the feeding issues we could potentially generate a low performance general railway on the Swiss model with relatively low capital costs.
Such a thing will need ongoing subsidy, but with the outlook for fossil fuel phase out it is worth bearing in mind.
It is really annoying that the RSSB will simply not allow a 1500Vdc tramway.
It would make trams far more economic to engineer and operate.
EDIT:
It is also worth noting that if the vehicle has a main circuit breaker between the pantograph and traction electronics that you could simply have a DPDT contactor after the circuit breaker.
When the voltage on the line drops out of spec, like in a neutral section, the main breaker opens, disconnecting it from the line.
When the line voltage returns you can use a pair of anti parallel diode protected relays to determine which polarity it is. The contactor can then be set appropriately and the breaker brought back in, hopefully all in a second or less.
