Poor External Condition of FCC Thameslink Stock
Furrball
9 May 2011
In addition to the graffiti there seems to be an issue that the carriage wash does not get into the door recesses so the windows on the doors are filthy, some to the point of being opaque!
jon0844
1 Feb 2009
Most London based TOCs have done very well presentation wise aside from FCC, Connex and NXEA
Let's split the TL and GN sides because on the Great Northern routes, I rarely see vandalised trains and they're all in the same livery (321s excepted) and kept clean.
D365
29 Jun 2012
Yep, GN stock is quite alright, in terms of external condition (don't let this start a debate on how much the livery is hated/improved with grafitti!).
Class377/5
19 Jun 2010
You might want to spilt it further as the stock gets shared with Southeastern where most if the TL is hit.
D365
29 Jun 2012
And 377/2s loaned from Southern? It depends where each fleet is cleaned.
jon0844
1 Feb 2009
Just realised the thread is titled FCC Thameslink stock - so my apologies!
ChiefPlanner
6 Sep 2011
Herts
Agreed ! - apart from the graffiti vandalism , the overall presentation is way below say that of Southern and SWT , many units have built on "road dirt" and such that the washers can't shift it from the door recesses and the car ends in particular (hence previous comment on "hand bashing")
Of course the provision of the service comes first (especially 8 / 12 cars in the peaks) , and the months of blockades at weekends preventing access and causing outstabling. Quite a big job -
It's definitely got worse in the last couple of weeks. I assume that because of Sports Day, everything with wheels on it is out, so there is no scope to stop units for anything except essential maintenance.
I always thought it would be faintly amusing for a graffiti artist to paint a whole coach in another TOCs livery. It couldn't look any worse than the 319/2s.
Blindtraveler
28 Feb 2011
great idea! Lets have an entire 395 in the old SPT orrange :) mega confuse the punters!
If its down to staffing then why not ask the jobcentre to provif some benifit claimants for the removal of unsitely liveries?
lewisf
21 Feb 2009
Kingston/Surbiton
Reminds me of that German S Bahn train where someone very convincingly painted on an extra set of doors!
D365
29 Jun 2012
^ That's something I haven't seen yet. Most times it's vandals spraying the touch door-open buttons so that people don't want to use it!
This isn't the stock we're talking about but it's an example of how graffiti can build up.
Class377/5
19 Jun 2010
It's not Olympic related as the only strengthing is at weekends on TL (tho haven't been provided proper diagrams for week day services just weekends).
Bare in mind normal TL timetable requires pretty much every out expect maintance units in the week any way.
Forgot about those as they are Southern's responsibility still.
thelem
17 Mar 2008
Surely they should be concentrating on preventing them being done in the first place. Even if you can't stable everything in doors, surely it wouldn't be too hard to install higher fences and CCTV - ideally monitored so the police can be called and catch people red handed.
Class377/5
19 Jun 2010
Problem is when you berth large numbers of your fleet at other companies locations means your powerless to stop it as noticed before.
michael769
9 Oct 2005
I would imagine that when you have lots of sets berthed up they provide a lot of cover for vandals to hide among as they go about their "business"
It is probably insurmountably difficult to provide sufficient CCTV coverage to effectivly deter the vandals.
jon0844
1 Feb 2009
Given the huge cost to clean, employing security on site might be cheaper.
Not G4S of course, as they would probably spray them themselves!
jon0844
1 Feb 2009
What I meant is that G4S would probably hire the graffiti artists to work as security, given their incredibly thorough screening process. But, 12CSVT, you're probably right - they might not work out how to use them!
ChiefPlanner
6 Sep 2011
Herts
An observation of a significant improvement in the external condition of the FCC fleet , and some of the 319/2 units have been properly cleaned ! Well done.
On a down side , graffiti still around , and no less than 2 EMT HST power cars have large murals on them - indicating perhaps Cricklewood may be a "tagging" spot ? (any one comment whether HST sets sit there overnight ?)
BestWestern
6 Feb 2011
Several images on Flikr of EMT stock having been sprayed, including two HST trailers and a 156. No 43's, but clearly they have issues somewhere. A shame considering they have a very smart livery and have clearly made some effort to get everything painted in house colours.
asylumxl
12 Feb 2009
Hiding in your shadow
EMT stock isn't stabled at Cricklewood in the evenings or over night as far as I'm aware, unless things have changed.
Like I've said previous times, a lot of the grafitti occurs further south, particularly Bellingham sidings and Ashford sidings.
I've only known FCC stock to be hit at Cricklewood a few times.
ChiefPlanner
6 Sep 2011
Herts
2x hast and 2x222 stable overnight at cricklewood, but are moved about for fueling.
That may be the case then - especially as the EMT stock tends to be nearer the up slow lines sidings ... one that somebody is hopefully watching.
Today - many more 319's running in good external condition -some apparently showing signs of partial "re-vinalying" - Monday am up peak was recently a bit of a NYC subway 1970's flashback with freshly muraled stock sliding into stations.:-x
Class377/5
19 Jun 2010
The lists getting smaller now and one of the 377's has been partly reliveried as well. However there is still some large bits to go especially on the 377 fleet. And another unit was hit over the weekend at Preston Park.
12CSVT
18 Aug 2010
Looks like 319013 / 214 / 216 / 217 all look as though they have had coaches re-vinyled in Southern green & white in the past few days.
BestWestern
6 Feb 2011
I noted one of the Southern-liveried contingent has received an all-over advertising vinyl, and had it's doors painted into standard Barbie pink to boot. That'll look interesting when they vinyls come off! :D
