Porterbrook Cl.769 'Flex' trains from 319s, initially for Northern
Discussion in 'Traction & Rolling Stock' started by aformeruser, 2 Dec 2016.
  1. Nicholas43
    Nicholas43 Member
    191
    16 Jun 2011
    Is there any information, or informed conjecture, about what services GWR are planning to run, when? Is it only Reading<>Gatwick? Or (some?) Oxford<>Reading<>Gatwick?
  2. Surreyman
    Surreyman Member
    531
    29 Jan 2012
    The reports I have seen, suggest; -
    Reading to Gatwick & presumably on the same tracks the Reading - Redhill stopping service.
    Paddington to Oxford through trains i.e over and above the 387s running Paddington - Didcot under the "juice', although given that IETs are on order for this route, I suspect they may be just a few peak hour through trips.
    Reading - Basingstoke.
    Not specifically noted but assume that Slough - Windsor & Twyford - Henley branches would be 769 operated
    The West Ealing - Greenford & the Maidenhead - Bourne End - Marlow branches won't take 4 car trains.
    They could work Didcot/Reading - Banbury.
    387s run to Swindon sidings now and are due to provide 'Rugby Specials' through to Cardiff in future, main line beyond Didcot won't be cleared for 769s but presumably could be.
    If there are 19 units due and allowing for engineering spares, that suggests a max of 17 diagrames, would roughly work out at 7 for Reading - Gatwick, one apiece for Windsor & Henley branches, 2 for the Basingstoke line and assuming either 3 - 8 car or 2 - 12 car for Paddington - Oxford, makes a total of 17? (will probably be corrected very soon!!!)
  3. JN114
    JN114 Established Member
    1,875
    28 Jun 2005
    They won’t see regular use on the mainline; just branches, Basingstoke and Gatwick/Redhills.
  4. Surreyman
    Surreyman Member
    531
    29 Jan 2012
    It has been implied in print that they would replace the 12 387s converting to Heathrow Express, how exactly that pans out in real numbers I'm not sure but then when Crossrail eventually starts running, it will displace 387s currently used on Paddington - Reading 'Stoppers', so long term, (unless Didcot - Oxford & Reading - Basingstoke are electrified), std GWR 387s are only going to be used Reading - Newbury 'Stoppers' and Paddington - Newbury/Didcot 'fasts'.
  5. JN114
    1,875
    28 Jun 2005
    It’s been implied incorrectly then.
  6. big all
    big all Member
    567
    23 Sep 2018
    i though perhaps connect basings with gatwicks as a single service but realized that would restrict electric working from gatwick to reigate if no moving changeovers can take place :D:D
  7. JN114
    1,875
    28 Jun 2005
    Correct. And while grade separated junctions exist at either end of Reading station now; the flow of traffic through Reading really isn’t geared up to through services from other lines onto the SR at Southern or Spur Junctions.
  8. big all
    big all Member
    567
    23 Sep 2018
    its a shame really as perhaps a eastleigh to gatwick via reading or a southampton to brighton via reading would be a very useful service not end to end but middle one half to middle to end the other half or beginning to middle other half route way more in a spoke in wheel way where a journey is via the more sensible connecting reasonable short to medium route
  9. notlob.divad
    notlob.divad Established Member
    1,109
    19 Jan 2016
  10. zn1
    zn1 Member
    392
    3 Sep 2011
    once they are bedded in, the maintenance depots, train crews and passengers have got used to them, and of course the units themselves have got used to the roads they will operate on....19 units with 2 MS will work...id personally allow so slack just to allow for the above...they wont be running at 100% diagram efficiency at first..if reading depot have any sense they will keep at least 4 turbos on as spares with at 2 at RG and 2 at maidenhead for cover daily for a short period...
  11. johnpeter3
    johnpeter3 Member
    14
    10 Jan 2015
  12. jonesy3001
    jonesy3001 Established Member
    1,915
    13 Jul 2009
    Malta
  13. 6Gtraincrew
    6Gtraincrew Member
    84
    22 Feb 2018
    002 coupled up and ready to leave. Debranded, but still in Northern colours. Grey with blue doors.
  14. jonesy3001
    1,915
    13 Jul 2009
    Malta
    think you mean old thameslink colours.
  15. Kyle1
    Kyle1 Member
    27
    24 Aug 2014
    Barry, Vale of Glamorgan
    Post removed as I'm a blithering idiot
  16. PHILIPE
    PHILIPE Established Member
    9,748
    14 Nov 2011
    Caerphilly
  17. Kyle1
    Kyle1 Member
    27
    24 Aug 2014
  18. anamyd
    anamyd Established Member
    1,202
    17 Aug 2018
    769-002 now delivered to Canton 14/3/19 1457
  19. AndrewE
    AndrewE Established Member
    2,691
    9 Nov 2015
    But when are they going to be any use?
  20. crosscity
    crosscity Member
    302
    5 Dec 2011
    Which Thameslink unit was this converted from? A cursory look at earlier posts mentions 319426 or 319002.
  21. anamyd
    1,202
    17 Aug 2018
    Supposedly will be going into service in May after route, driver and guard training...
  22. anamyd
    1,202
    17 Aug 2018
    319-002 (the 769s retain their 319 unit numbers other than the class). this will be followed by 003, 006, 007 and 008 which are the other units of the original 5 ordered under Arriva Trains Wales. 426 and three other identified units would be the extra 4 ordered under Transport for Wales.
  23. PHILIPE
    9,748
    14 Nov 2011
    Caerphilly
    4 week period of fitter training first. Can't go out on the road and fail without fitters to fix it
  24. Kite159
    Kite159 Veteran Member
    12,600
    27 Jan 2014
    West of Andover
    May 2020? :lol:
    Who wants to bet 769002 will end up heading back towards Loughborough before it turns a wheel on the public network. Or the first test from Cardiff Central to Cardiff Queen Street it breaks down attempting to climb the hill in the rain
  25. anamyd
    1,202
    17 Aug 2018
    by summer then I guess...
  26. big all
    big all Member
    567
    23 Sep 2018
    if they can manage the 1/4mile 1/46 into sutton platform i am sure they can manage the worst the vallies can throw at them ;)
  27. Kite159
    12,600
    27 Jan 2014
    West of Andover
    But that was on electric, who knows what they will be like on diesel on a very wet day
  28. Charlie Smythe
    Charlie Smythe On Moderation
    378
    18 Aug 2018
    Exeter
    Not brilliant considering they are, at least compared to the 150's which this unit often compared to, rather under powered at only 1050hp for 155 tonnes (6.7hp/tonne) compared to a 4 car 150's 1140hp for 143 tonnes (8hp/ tonne)
    As for on a wet day then its more about weight on driven axles which for a 4 car 150 is around 50% at 70 - 72 tonnes, however for a 769 its only 50 tonnes.
    Therefore on paper at least the 150 should be a better performer although with modern electronic equipment and the fact that a 769 is diesel electric multiple unit, the performance deficit may not be so much, if not at all.
  29. big all
    big all Member
    567
    23 Sep 2018
    its irellivent its the same traction motors so same grip same control
    unless the diesel control is more "notchy" than the electric then grip will be less off a problem
  30. JN114
    1,875
    28 Jun 2005
    It’s the same traction equipment, just a different source of electricity; the total additional weight of which is less than a crush load of passengers in one coach. They’ll cope absolutely fine.
Share This Page
