Porterbrook Cl.769 'Flex' trains from 319s, initially for Northern
Discussion in 'Traction & Rolling Stock' started by aformeruser, 2 Dec 2016.
  1. physics34
    physics34 Established Member
    3,041
    1 Dec 2013
    They would need SDO as a few stations down there can only fit 1 carriage!
  2. modernrail
    modernrail Member
    327
    26 Jul 2015
    Really! Is that what happens when they run 4 carriages on Marshlink in summer?
  3. samuelmorris
    samuelmorris Established Member
    3,215
    18 Jul 2013
    Brentwood, Essex
    It would have to be a 319-based unit. 321s do not have third-rail gear and DC buses - there's no inherent practicality there other than using a straight DMU. Also yes, I think SDO is needed down there which neither 319s or 321s have in their current guise that I recall. 319s replacing 313s could work but as I understand it, they need to be 3-car units. Now we have the opposite problem as well - 321s can be converted down to 3-cars easily, but 319s have too much auxiliary gear to relocate. 321s not having DC gear, the best bet for Coastway I think is to bolster the EMU fleet further and put the 3-car 377s back down there.
  4. edwin_m
    edwin_m Veteran Member
    14,849
    319s were run under DOO on Thameslink.
  5. samuelmorris
    3,215
    18 Jul 2013
    Brentwood, Essex
    Whoops, I meant SDO, apologies - will edit.
  6. Fincra5
    Fincra5 Established Member
    1,748
    6 Jun 2009
    319s don't need to be shortened to 3 cars for use on SN. 313's no longer visit the East Coast between Eastbourne and Hastings , where the two 3 car stations (Pevensey Bay and Normans Bay). 769s would be good for the Marshlink but would need SDO - as mentioned some stations are 1-coach. But 313s will be here for a while...
  7. samuelmorris
    3,215
    18 Jul 2013
    Brentwood, Essex
    Fair enough, I don't know the area well enough to know which stations were affected (though I suppose I could have looked it up in the sectional appendix).
  8. The Ham
    The Ham Established Member
    5,657
    6 Jul 2012
    Depending on how busy the stations are I've seen 8 (maybe 12) coach trains serve a station which is normally 2 or 3 coache trains only without the use of SDO, by the guard just opening a local door. It does require a longer stop (say +1 minute) so that people have time to walk along the platform. However if it was always the first door on the second coach there could be a sign or platform markings to highlight the general area that People needed to wait in.
    For on train passengers there would be announcements and information on the PIS's ("xxxx is the next station stop, passengers wishing to leave here need to do so by the door the guard opens in the second coach")
  9. edwin_m
    14,849
    It gets a bit more complicated when accessibilty is taken into account. Not all passengers are able to walk through the train to use the correct door. At least where the station has step-free access to the platforms, it's probably necessary to use the door nearest the wheelchair area. Using this door in both directions makes it possible to put fixed signs in the rest of the train directing passengers there if alighting at the stations in question.
  10. a_c_skinner
    a_c_skinner Established Member
    1,043
    21 Jun 2013
    Does anyone know what is happening with the early units? Are any on the big railway? Are they still pottering up and down the GC line? I'm beginning to swing to the "it won't work" camp, if only because nothing seems to be progressing.
  11. notlob.divad
    notlob.divad Established Member
    1,117
    19 Jan 2016
    I believe at least one has been dragged to Allerton. Presumably for maintenance training.
  12. big all
    big all Member
    618
    23 Sep 2018
    because there seems to be definate units earmarked for specific areas so a pressing need they will tend to spend more resources to "make it work" rather than the 230 choice where it seems will only work if the figures add up and make financial and commercial sense
  13. Class455
    Class455 Member
    879
    19 May 2016
    Wonder if Northern will use their 769's down to Huddersfield at all?
  14. jayiscupid
    jayiscupid Member
    130
    19 Aug 2015
    Singapore
    There was a comment in Today's Railways last month (page 7) which said Porterbrook are looking into the potential of a Flex 377 for Marshlink and Uckfield freeing up more 170s.
  15. AM9
    AM9 Established Member
    6,486
    13 May 2014
    St Albans
    What advantage would a 377 have over a 319 when it comes to accommodating a pair of diesel generator sets?
  16. modernrail
    modernrail Member
    327
    26 Jul 2015
    Might it be more about 319s not being able to get through Oxted tunnel (something I have read on here) and having a common fleet type (something Northern are not allowed).
  17. AM9
    6,486
    13 May 2014
    St Albans
    Apart from the fact that Northern already have class 319s and no Electrostars.
  18. modernrail
    modernrail Member
    327
    26 Jul 2015
    Not sure what point is being made? They also have class 150, 153, 155, 156, 142, 144, 158, 333, 321, 322, 323 and will shortly add 195 and 331. 14 in total although it will roll back to 12 in a few years when pacers go.
    In contrast Southern has 4 classes.
  19. sd0733
    sd0733 Established Member
    1,270
    7 Nov 2012
    153, 321, 322, 323 are all also scheduled to drop out the fleet.
  20. jonesy3001
    jonesy3001 Established Member
    1,949
    13 Jul 2009
    Malta
    According to posts on the facebook groups, the 323s are staying with the WMT ones joining and the 319s leaving.
  21. 43096
    43096 Established Member
    4,847
    23 Nov 2015
    But that is Facebook. There has not been any official comment.
  22. AndrewE
    AndrewE Established Member
    2,731
    9 Nov 2015
    What a clever plan (not!) I really hope that our best commuter trains currently are not moving on. The bimode version is presumable staying until something can be procured to replace them (I doubt that Barrow and Windermere will see any wires in my lifetime) but if the 319s go we shall lose the benefits of the commonalities between 319s and 769s.
    Maybe there will be sister fleets of electrics and bimodes procured one day, but I wouldn't expect it before the 769s collapse, by when it will be too late to look for a bi-mode 331.
  23. AM9
    6,486
    13 May 2014
    St Albans
    So out of your list, the 150s, 153s, 156s, 142s, 158s, and when they come, 195s are all diesel so have nothing to do with commonality with EMUs. That leaves the 321/322 (basically the same vehicles) the 323s and the 333s. GTR, (Southern is just a brand) has 313s, 355s, 377s (two non-compatible types), 387s and 700s. I've excluded 365s because they don't run on 3rd rail. GTR also has DMU types: 159s and 171s (which are required for less than 10% of their total traffic.
    I don't see that much difference. However, considering the rag-bag bunch of routes that Northern runs, the trains available in most cases fitted the needs of the services scheduled on them.
    All this "something Northern are not allowed" wailing conveniently ignores that just over twenty years ago, the majority of the services south of the Thames were run by trains more than 40 years old, some of them comprising hardware that was pre-war, whilst the Northern area had modern Sprinters and Super-Sprinters from the '80s. The 323s and 333s were new EMUs and the 308s were a stop-gap until the 321/322s were available ISTR.
  24. Fincra5
    1,748
    6 Jun 2009
    Would be difficult. Looking at the 769s don't they have a GenSet under each DTSO? 377's have 3 motor cars (DMOS A/B and MOSL) Leaving only the PTOSL to mount a GenSet... Unless you removed the Traction Equipment from a MOSL but then the 377Flex would be horrendously slow and sluggish. Its bad enough moving a 377 with one motor coach out, let alone with the weight on GenSets.
  25. AM9
    6,486
    13 May 2014
    St Albans
    That was why I asked the question. A 4-car 319 has a power per weight figure of 9.46 hp per tonne whereas a 4-car 377 has a figure of 9.21 hp per tonne. Although the 377s have 6 motored axles, the PTSOL is unmotored so the weight of the transformer (or concrete weight) and compressor doesn't help with adhesion. With 319s, the full 50 tonne weight of the MSO is available.
  26. 43096
    4,847
    23 Nov 2015
    Nope: GTR only have 171s.
    You really need to go and look at the history of the Southern units. 20 years ago (1999), the slam door fleet was not as old as you might think: the oldest VEPs were built in 1967 (32 years old) and the oldest CIG was 1964 build (35 years old). Only the 205/207 DEMU fleet (1958 on) and the CEPs (1956 on) met the criteria, and the CEPs had a rebuild in the 1980s that arguably made them superior to the CIGs. Other than that, services were in the hands of the 1980s and 90s built 159s, 442s, 455s, 456s and the Networkers. Clearly your statement does not stand up to scrutiny.
  27. Jonny
    Jonny Established Member
    1,995
    10 Feb 2011
    Some jiggery-pokery to move the PTOSL motors onto one or both of the DMOS coaches would be a win-win in that case.
  28. aleggatta
    aleggatta Member
    176
    28 Sep 2015
    it's PTOSL not PMOSL, no motors to move!
  29. Charlie Smythe
    Charlie Smythe On Moderation
    378
    18 Aug 2018
    Exeter
    Although on a 769 the weight of the engines are on the driving trailer so they do add to adhesion.
  30. AM9
    6,486
    13 May 2014
    St Albans
    I don't think so, there aren't any motors in the driving cars where the gensets will be mounted.
Share This Page
