Depends how much the internal damage isGood to hear. I like seeing this unit. It didn't look to be too major so it was probably fairly easy to get it fixed.
Oddly old BigBlue had new motors fitted in one the DMS' only recently. I drove it the day after it came back out... Seemed to shoot off the mark! But the fire isn't my driving! Haha.
Both Lewes-Brighton shuttle diagrams - booked for 313 - are cancelled this morning, due to lack of serviceable units.
Reduces the service between these towns by a third, and at London Road by 50%
They can have it early, then!Wasn't this unit destined to go to the NRM?
I would be very surprised if it didn't come back, maybe give it some time, but considering 313026 up on GN is now supposedly out of use due to needing a major exam, although it may be some time, I think we will see 201 again. whether that be with parts robbed from 026 who knows, but there is still a considerable amount of time left for the franchise and its unlikely that they will be replaced in the first couple of months of the new franchise. Does anyone know what actually failed on 201?
On 201, the fire/smoke was internal. I've seen the pics, not great. (not able to share)
As before @sarahj, not a problem - fully understand
I can only speculate then that the internal damage is too much work and that unit will be formally withdrawn from service.
Are you at liberty to say if unit is still in the shed or not?
SE need them to allow services to run as 8 or 12 carriage services, it seems as if most of the 377s are running Canterbury West/Ashford Int to Victoria diagrams, and many of the 375s have been displaced out to make regular 8 carriage services from Ramsgate to Charing Cross via Canterbury West or Via Dover Priory, as well as the Ramsgate/Dover Priory to Victoria services! That in addition the Medway Valley line now uses 375s rather than networkers so all in all it wasn't about new services but improving seats per train
Most of the info I get comes from the Big Blue facebook group. (not open to non southern/gtr crew and if we don't know you)
If it's as bad as 377 442, I can't see it returning. There isn't the flexibility with the 313s to take a coach out, sadly.
If this is the case, another 313 will have to be sourced from GN until at least the end of the franchise, as they can't keep taking 377s from peak-time diagrams. Either that or they try and get a 377/5 back from SE?
GN 313s are going to be salvaged for spares then scrapped. As said best thing to do would be to source a 377 to cover the diagram. I am sure they can juggle the stock workings to make one available. The 455s are used less intensively these days so perhaps they could swap a 377 working in the metro area for a 455 and use the 377 for the 313 diagram. GTR have enough stock I am sure to balance it out even if its in the May timetable change officially.
Or even that random 377/1 from SE?
There's two 377/1s at Southeastern...377163/164Ah yes, I forgot about that!
The 455s usually run as 8 coach formations, so it’s not usually as simple as just borrowing one. There’s actually quite a shortage at times at the moment, too - they’re falling apart just as much as some of the 313s, if not perhaps more so!
It might perhaps be possible to retain the 387 from GN which is currently covering for GatEx overhauls, as many drivers (and all other onboard crew) who sign 377s also sign 387s.
Alternatively, now could be a good time to reduce the rather greedy use of 8/377 formations on the Milton Keynes services during off-peak hours, which is total overkill except in the most extreme circumstances.
The reason you have long trains running around off peak is because there's nowhere to put the surplus coaches, no drivers to take them there, and to prevent using up time at stations such as London Bridge and Victoria splitting and attaching them.the problem is they stay together on those MK diagrams all day......with nowhere to split or attach enroute. (well east croydon they could but that wouldnt be viable i guess). Think there are two sets of two though that (are used on shepherds bush shuttles) go back to the depot in mid morning....
....also you have those off peak London Bridge to Epsom 10 cars which are big overkill off peak.
