Following the posting of this post I've created a thread to discuss measures which could be undertaken to improve rail in the North Hampshire areas, chances are there'll be overlap into some nearby areas:
In response to this posts: the problem with the Alton line is that it's single track beyond Farnham and the level crossing at Farnham.
The level crossing could be an easy fix by changing the road layout so that the crossroads were closed and a grade separated junction provided at the over bridge to the West. This would also benefit the road network by removing a significant bottleneck on the highway network.
Ideally you'd want to provide a pedestrian/cycle link across the A31 where the existing crossroads are (either by providing an over bridge or by rising the road so that it could pass under).
Apologies for getting the crayons out here. But has it ever been considered to lay a very short chord from the Aldershot/Alton line joining to the northern part of the North Downs line? If it's really so difficult to manage conflicts at Guildford and on the Brighton line, why not make better use of the northern part of the NDL by running 2tph Reading to Farnham and 2tph Reading to Redhill/Gatwick.
Having 4tph from the northeast Hampshire conurbation into Reading would be a big improvement. It would benefit Reading's reach as a commercial centre and definitely help make new journey options getting people out of cars. I'd assume capacity exists on the Alton line to accommodate extra services.
Thoughts?!
