SteveyBee131
It certainly hadn't up to the start of lockdown. Up to that point I travelled fairly regularly on 185s, and eco-mode was still a thing.According to other discussions the “eco mode” has been disabled in recent years.
What I find interesting is that 750 bhp engined DMUs such as 185s and 222s (but not 180s) can show 750V dc powered units a clean pair of heels to 60 mph and beyond.
350 should be 2000 kW as 450, many reference books (and some ROSCO info sheets), only give the figures for a single motor vehicle, and of course there are 2...May I query the figures for the 350 - they seem low for what is a relatively high performance unit?
Would this be the same as the 450?
Thanks
Sometimes the engines are off because they have failed. A problem also found with Voyagers, I understand.I did York-Manchester last year on a 185 and the coach I was in had the engine off for the entire journey. It's very noticeably quieter travelling in the 'off' coach!
Yes - they need editing. There may be other errors / typos., etc. - with so much data, it is all too easy to copy the wrong numbers, or put things in the wrong rows / columns. Thanks to everyone who report my mistakes, etc. I will update the files as/when necessary.May I query the figures for the 350 - they seem low for what is a relatively high performance unit?
Thanks
Thanks
Remember going out of Waterloo on a 50 and it left a 455 behind, assuming current demand is so high that drivers didn't risk applying too much power on units? Was told by someone who used to drive out of Waterloo if three trains left at same time you had to make sure you applied power at different time to others otherwise would trip power supply! Assume been upgraded since then but still limited?What I find interesting is that 750 bhp engined DMUs such as 185s and 222s (but not 180s) can show 750V dc powered units a clean pair of heels to 60 mph and beyond.
Class 350 and 360 are the same.350 should be 2000 kW as 450, many reference books (and some ROSCO info sheets), only give the figures for a single motor vehicle, and of course there are 2...
It's not - it's used by some drivers, but most opt to turn it off, because they are sluggish as hell up the hills in the pennines on 2 engines.According to other discussions the “eco mode” has been disabled in recent years.
Can't believe with 1500hp installed and even taking transmission losses into account they lack performance. Is it because they're so heavy? A 3 car 158 on all engines has less installed power.It's not - it's used by some drivers, but most opt to turn it off, because they are sluggish as hell up the hills in the pennines on 2 engines.
You're spoiled with three good engines on a 185. They're amazingly quick. Before I signed 185s I only ever drove EMUs so was used to good performance. I don't have any experience with anything slower to compare them to.Can't believe with 1500hp installed and even taking transmission losses into account they lack performance. Is it because they're so heavy? A 3 car 158 on all engines has less installed power.
A 185 will leave a voyager behind from a standing start, the voyager only picking up the edge through its higher top speed. Plenty times over the years I have been on a 185 leaving york at the same time a voyager did, pretty much side by side but once 2nd gear kicked in the 185 surged away like a demented bat! It was only on approach to carlton junction the voyager caught up and passed. HSTs on a 9+2 load had no chance!
The 185 has lower 'gearing' as only 100mph, maybe that makes a difference?Hmmm in theory a healthy voyager has a better 0-60 time than a 185 (assuming all its engines are working). The diesel electric transmission allows better acceleration)
Also your 185's don't deliver full power from a standing start either ..do they.Hmmm in theory a healthy voyager has a better 0-60 time than a 185 (assuming all its engines are working). The diesel electric transmission allows better acceleration)
W
Same here. Which EMUs did you drive ?
Interesting bunch ..700 quickest..followed by 377/387 - the 185s only 30sec slower to 100mph. The 319s are awful. Maybe slightly quicker to 60mph than the 185..but very sluggish after that - particularly over 80mph319/377/387/700
No point claiming the DC units have the same hp/ton ratio - they simply don't. The traction electronics are deliver 1100-1200kW maximum - even if the hardware is designed for maximum 2000kW.
That's why TGV and Eurostar are given different power ratings for the specific supply. Did you ever see anyone claim Eurostar delivered 16,400 hp on 750vDC?
Similarly bi-modes are given an electric and a diesel power rating.
Please rate the Class 444's and 450's at their 'capped' ratings that reflect their true performance.
What's the reason for that design decision?To add to that - the shut down engine cannot be restarted until you come to a stand - not a problem when doing 100mph across the plain of York - but a right pain if you suffer a TSR or signal check - because you only then have 2 engines to get you back to line speed - nightmare if you have steep gradients to encounter.
Why does it need reverse gears to engage when travelling forwards?Transmission needs to be stationary for reverse gears to engage.
