43096
- Joined
- 23 Nov 2015
- Messages
- 15,286
What's the alternative? If you do nothing to keep it "as was" it will deteriorate anyway and ultimately end up back as iron oxide.This could reopen the fun little argument of Preserved Railways - Museum or large-scale trainset?
Every time you replace a part on a train, you're removing a historical artefact, every time you repair it you're scarring the original parts with modern welds and rivets. The repair methods used aren't authentic and neither are the parts and equipment. Historically it's the equivalent of stripping out a historic building and patching it up with breezeblocks and polyfilla.
How many times have original works built boilers or large original parts been stripped out and replaced by modern replacements? The original being either dumped behind a shed to rust away or eventually scrapped? There has to be an acknowledgement that by continuing to make them run, preserved railways are degrading historical artefacts.
In any case, everything will have had repairs and modifications through its life so isn't original anyway. Arguably, making those repairs in preservation is just a continuation of what has happened through the vehicle's life.
