Preston-London Any Permitted valid via Blackburn?
Please could someone confirm or otherwise my interpretation of the NRG?
I need to be in London for 11am on a weekday for which the 0758 PRE-EUS is the obvious choice, and with a Senior Railcard the Off Peak Return at £57.35 is unbeatable.
The return is in my own time and the next day, and I have used the NRG to establish that I have a wide choice of routes back (time restrictions permitting).
My home station is Blackburn, from which the VT Railcard easement does not apply, so I split at Preston.
Looking at maps BK, EP or RP it seems that Preston can be reached via Bolton-Blackburn.
Therefore, so long as I don't travel via Preston, I can use the return half of the SVR to finish short at Blackburn.
Am I right?
If so, I will see if the timetable works.
Thanks in advance.
maniacmartin
Fares Advisor
15 May 2012
Croydon
Preston (Lancs) is a Routeing Point
Yellow pages (page 1564) shows the mapped routes to be:
BK+GC CL+EJ DW+SY EP KN+GC NP+MM RP+RG.
BK+GC meet up at Birmingham Group, with BK showing a route via Bolton and Blackburn
This looks fine to me. Obviously you would need a seperate undiscounted ticket to get from Blackburn to Preston on the outbound journey.
If your journey back is actually off-peak, you may not need an actual split if it works better. You could purchase the through ticket and an additional Blackburn-Preston single, and just use the return half on the way back, if I understand correctly the discussion on another thread.
(BoJ, and therefore starting short at Preston, is permitted on that ticket)
bb21
Emeritus Moderator
4 Feb 2010
If I understand you correctly Neil, that would not be valid on the outward as the Railcard easement would not apply to a Blackburn-London ticket.
How likely the Virgin guard will pick up on that is a different question.
30907
It would be off peak otherwise I would have to use VT on the way home which is boring.
And anyway, leaving aside the easement, BBN-EUS is more expensive than PRE-EUS anyway, if not by much.
kieron
22 Mar 2012
Connah's Quay
You can go home via High Wycombe Oxford, Rugby or Sheffield with a London-Preston ticket, so there's plenty of choice. One thing you can't do is use the train via the Todmorden Curve from Manchester.
Starmill
Fares Advisor
18 May 2012
Bolton
We came to the conclusion that a Blackburn - London ticket is valid in conjunction with the railcard easement, so long as it is permitted to start short at Preston and travel from Preston to London exclusively on Virgin Trains.
There would be no requirement to buy a Blackburn - Preston and Preston - London ticket, but the easement would not apply to the Northern service.
bb21
Emeritus Moderator
4 Feb 2010
Did we?
In reality I suspect it would not matter as Virgin guards are probably only interested in the easement application on their own trains, but did we draw any conclusion?
I must have missed it.
