Does it need one? It's gone off for PRM modification hasn't it?I thought I saw a post saying that XC HST set 05 had also been given a derogation but having clicked on the link I cannot find any confirmation of this in any of the letters. Does it have a derogation?
It was reply #77 on the Non PRM thread. I was wondering whether they may hold it back for a few weeks in case of problems with any of the other sets given that XC have no extra capacity, and/or Wabtec are not able to start work on it straight away.Does it need one? It's gone off for PRM modification hasn't it?
It’s at Laira not allocated today. The letter was written in November, before XC02 had come back from Wabtec, so was probably XC covering themselves if XC02 was not released in time.Does it need one? It's gone off for PRM modification hasn't it?
So for the GA EMU fleet the expectation is;
20 x 317 to retire October 2020.
18 x 317 to be made PRM-Compliant by April 2020.
27 x 317s available for service beyond October 2020.
Entire 321 fleet available until 1 December 2020. Renatus only beyond that.
So long as the 745/1 are mostly available by May, that all seems achievable.
Let’s hope they don’t find they have problems with opening and closing the doors on XC02 then like they did with the first two sets to be released (although to be fair the last two seem to have been ok)It’s at Laira not allocated today. The letter was written in November, before XC02 had come back from Wabtec, so was probably XC covering themselves if XC02 was not released in time.
XC02 is in service and there is a path in for a Laira-Doncaster move tomorrow, presumably for XC05 to go.Let’s hope they don’t find they have problems with opening and closing the doors on XC02 then like they did with the first two sets to be released (although to be fair the last two seem to have been ok)
They comply with PRM so they don't need dispensation.Are the Greater Anglia's 30 x 321 Renatus extended until end of 2020?
If class 360s Desiro units are off lease in August 2020 means class 321 renatus took the 360's duties until new bombardier class 720 delivered to GA?
The first derogation letter has been public since October 2018, although the Bromley North branch update to it is very recent of course. While it was a well known issue of discussion on here was it common knowledge among ordinary passengers of the line?It looks like for SouthEastern their 466s have a permanent exemption when they run with 465s (and only with 465s) as well as being given a limited exemption through to 31 December 2020 for solo operation on the Grove Park to Bromley North line. I think the future of Bromley North was something which was vexing a few people so they can rest easy that services will still exist tomorrow!
It probably depends on how literal you consider the letter. If you apply the logic of no single 153 to operate then either a two car unit will be plodding round, on the Spalding shuttles, with low patronage or the service may have to suffer a replacement bus service. Sadly, people can't have it all their way. Yes there are deficiencies and yes all passengers should be treated the same; however you can't expect changes to happen in such a short space of time. Perhaps the DfT bears some responsibility in all this by setting an unachievable target.If it’s specified route only is it right to interpret it as excluding the Nottingham services on the Peterborough Doncaster route.
if so surely all the later services to Spalding can’t be 153 as it’s effectively a shuttle to/from Peterborough till the last one which extends to Nottingham.
I wouldn't rule out the 90s getting extended either if at all possible, since if the roll-out of the 745s is even half like as slow and hit by problems as the 755s is, they're going to struggle.
In the second half of the year all 379s and 360s are leaving Greater Anglia so if the 720 situation is still bad then, they're going to have problems even if they get exemptions for the 317s and 321s.
I doubt the EU will care. Have a trip to Belgium and see what their trains are like. Still low platforms and two steps to climb in on some routes.The class 442 pre-date the regulations, but the regulations make clear what must happen by 1 Jan 2020.
I’d say it’s pretty likely that the 442 won’t meet the legal requirements and thus require derogations.
Any derogations have to be notified to the EU and must fulfill certain criteria in order to be made. I wonder if - on an administrative technicality - some of the derogations are in fact not strictly legal. Given that we haven’t left the EU. And whether that includes for the class 442.
It will be interesting to see whether these derogations get challenged in Court given that there has been more than adequate notice to the rail industry of these regulations. And that regardless of the status quo, the regulations trump derogations making them null and void. Therefore the trains can’t be used, derogation or no derogation.
And the arbitrary 31/12/19 was a U.K. Government decision, not the EU. Given that the requirement for dispensations is to a very large degree down to DfT’s own mismanagement, you might say “hoist by their own petard”.I doubt the EU will care. Have a trip to Belgium and see what their trains are like. Still low platforms and two steps to climb in on some routes.
Yeah, struck me as odd.I note that one of Northern's "exempted routes" is Huddersfield to Leeds: which hasn't been operated by Northern for two and a half years. I'd assume they meant via Bradford, but that is addressed separately as Huddersfield to Bradford via Halifax.
Interesting that there's no letter for TfW 150/2s on that webpage, but TfW have admitted that so far only around 20 out of their 36 x 150s are fully PRM modified.
Also, none of the TfW dispensation letters specify specific routes to confine non-PRM compliant trains to, or specify that non-compliant trains must be coupled to compliant ones.
It had one to allow it to work until the end of this week if needed. However it wasnt needed as it is wy to Doncaster today.I thought I saw a post saying that XC HST set 05 had also been given a derogation but having clicked on the link I cannot find any confirmation of this in any of the letters. Does it have a derogation?
Thanks - I have just seen the post on the XC HST thread. Let’s hope that door problems don’t make 1V44 continually late.It had one to allow it to work until the end of this week if needed. However it wasnt needed as it is wy to Doncaster today.
There was a letter posted on Facebook for the tfw 150s dft didn't publish it with the rest of TFWs fleet.
I think the statements/questions in your last paragraph are matters that require a legal judgement or opinion.The class 442 pre-date the regulations, but the regulations make clear what must happen by 1 Jan 2020.
Legally there are no "derogations". A derogation would permit a new design of train not to comply with some part of the EU Directive. The documents the DfT has issued are "dispensations" against the UK retrofit legislation and do not have to be notified to the EU.Any derogations have to be notified to the EU and must fulfill certain criteria in order to be made. I wonder if - on an administrative technicality - some of the derogations are in fact not strictly legal. Given that we haven’t left the EU. And whether that includes for the class 442.
Agreed. As I understand it it was an EU Directive rather than a Regulation underpinning this, meaning that it was up to individual member states how and when they achieve the prescribed level of accessibility through domestic legislation.Legally there are no "derogations". A derogation would permit a new design of train not to comply with some part of the EU Directive. The documents the DfT has issued are "dispensations" against the UK retrofit legislation and do not have to be notified to the EU.
THANK YOU! I've had enough on blaming rules and regulations on the EU gov. Having lived abroad, I'd say the Uk gov along is pretty awful for pointless bureaucracy, even if our culture at large is very much make fun of the rules and regs.And the arbitrary 31/12/19 was a U.K. Government decision, not the EU. Given that the requirement for dispensations is to a very large degree down to DfT’s own mismanagement, you might say “hoist by their own petard”.
