problem with passenger 37 BVE4 version
Simming
8 Jun 2005
Cornwall
When running this loco on the railtour on X-City, when I go into notch 7 the sounds go all jumpy, IE, the sounds flash on and off, if you get me.
its only seems to be notch 7, and the passenger version, as ive run the freight one no problem.
Dave A
7 Jun 2005
I've had no problems. Is it in full screen mode as bve sounds seem to suffer sometimes when it is :?
Craig
15 Jun 2005
Newcastle
Sounds like you're applying too much power. I assume you're putting the loco into P7 straight away? You need to watch the ammeter (top right dial) and keep the needle in the green/yellow areas. Once it reaches yellow/red you need to reduce power slightly until you increase speed and the needle drops, then you can apply more power.
Simming
8 Jun 2005
Cornwall
No, Im watching the Amps, but even when im on the 55mph stretch, its still jumpy.
I know it trips outs, Cause I put it straight into full, and it tripped before.
Tom B
27 Jul 2005
Moved to Development & Support as it's more appropriate here.
Harold
9 Jun 2005
Southampton
No problems at my end
infact i enjoy running this 37 as much as i enjoyed traveling behind it on a sleeper
HBA135
Nick
8 Jun 2005
Simmig I'll give you the correct .dat code when I'm back off holiday.
Jim
11 Jun 2005
Wick
I think it is down to slipping. There are some points of bad adhesion on X-City
Guinness
13 Jun 2005
wumpty said:
Hi, First post for me here ;)
It is down to slipping. Try driving the class 37 on a non rainy route and it should accelerate fine!
Welcome :)
Now that post shows how far BVE has come! :)
HSTfan!!!
11 Jun 2005
seems odd however there are a few points of bad adhesion on the route, personally I've run the whole route with no problems at all on more than one occasion (after I got the engine started! :lol: )
T
Tom
Guest
Hi wumpty, just by your e-mail address you registered with I can see interesting things!
Well done with the routes, and welcome to RailUK!
Jim
11 Jun 2005
Wick
Who is he :?
joeholmes
4 Jul 2005
Japanese is a coool lanuage... God help me thought to understand it....
joe
