Progress on Avanti West Coast's 805/807s Hitachi AT300 sets
Nicholas Lewis
9 Aug 2019
Which gets us back to the question...is the power supply upgrade work planned? And when? If not the 807's look like they will primarily be used on xx:16 Euston to Birmingham semi - fast for the foreseeable future.
Wasn't it deferred when Crewe was going to be completely rebuilt under HS2 as that would have dealt with it?
fadster
28 Aug 2014
5Q32 Merchant Park to Oxley past through Melton Mowbray with a white 805006.
Cheers, Fadster.
HamworthyGoods
15 Jan 2019
The short forming also caused Avanti to remove Seatfrog on a couple of the alternative services from Crewe/Stafford, anticipating busy trains.
Which makes total sense as the ‘cheap’ upgrades are only there to fill premium seats which would otherwise be empty.
800001
24 Oct 2015
69011 is due to haul 807001 from Merchant Park to Darlington as 5Q20 this evening, then detach, and 807 will start its mainline test continuing to York.
Scotrail12
16 Nov 2014
Will these trains ever make it to Glasgow? The Pendolinos are my least favourites by a country mile, would be great to eventually have something else on this route.
pokemonsuper9
20 Dec 2022
Greater Manchester
Definitely not in service, especially not any time soon.
They're not planned to go any further North than Preston/Blackpool with passengers.
800001
24 Oct 2015
So essentially a 7 coach 803?
No, as a 803 has a larger battery to provide static power to the train in the event of issues.
I believe an 807 has a standard battery which would lose power quickly in OHl is failed.
robbeale
14 Jan 2016
Seems the first one off Birmingham to Holyhead is cancelled or partially cancelled more than it makes it through. Not the most reliable when it's a train that connects with a ferry to Ireland. In the last 5 days it's only made it to Holyhead twice, neither of which were on time.
Russel
30 Jun 2022
Lichfield
Give them time to bed in...
The Voyager runs on the North Wales Coast are subject to frequent cancellations too, so it's not unique to the IET.
Today this service only ran Birmingham-Crewe (with 805 003), and then on to Euston 4.5 hours later.
The explanation on RTT was "an issue with the train crew".
If Avanti can't find trained 80x crew, you'd think a Voyager would be turned out instead.
The 1248 Holyhead-Euston was also cancelled.
Avanti don't deserve more time for them to bed in - the service should run or be substituted, which is what TfW try to do with the Mk4s on the same line.
800001
24 Oct 2015
Was it no 80x train crew, or no crews in general ie can not substitute a 221?
dk1
2 Oct 2009
East Anglia
Lots of Avanti cancellations this weekend due to lack of crew.
Northern are warning of severe disruption on ‘X’ this weekend too for similar reasons.
Northerngirl
16 Aug 2023
Wirral
Holyhead always seems to get the short end of the stick with cancellations anyway, having only a few staff trained on the new ones must make it even worse
Keithheller
12 Feb 2019
Anything to do with some warm weather, the euro’s starting and Fathers Day on Sunday
poffle
11 Oct 2023
Dublin, Ireland
Possibly. Who wants to work extra when there are better things to do in life? Ironically I’m working a buckshee Sunday this week :p
Presumably also if staff are still being trained on Averos then that reduces the pool of staff available to staff trains.
There also seem to have been some infrastructure issues west of Bangor with a number of trains cancelled/severely delayed due to "Points Failure" or Signalling issues over the last week.
dk1
2 Oct 2009
East Anglia
Yes I noticed issues further west with some trains spinning at Llandudno Jcn.
MontyP
18 Nov 2015
Is there any intention to run extra services to Preston/Blackpool? The Glasgow trains can be extremely busy as far as Preston/Lancaster, an extra hourly service to Preston would perhaps make sense if there is a path and enough rolling stock. Could even pick up the Warrington/Wigan stops to speed the Glasgow services up a bit.
pokemonsuper9
20 Dec 2022
Greater Manchester
I believe the intention is for 807s to cover some of the services that currently terminate at Blackpool.
Personally I'd rather the Fast train not skip Wigan :)
Toby268
13 Jan 2022
Avanti have bid for most of the remaining Blackpool west mids terminators (might be all) to be reinstated to run through to Glasgow as per pre Covid from (if I remember correctly) may 2025. Along with this is 2 additional Blackpool services throughout the day via the Trent valley which are to be operated by 390s. At present the only planned services from Blackpool using 2x 805s are the early morning 0535 departure from Blackpool and the soon to be reinstated 1705 Euston to Blackpool, using 1x 805 set.
Sheridan
11 Jan 2012
I noticed that the PIS on 805s (although possibly this was the case on Voyagers as well) announce ‘Bangor’ in English but ‘Bangor (Gwynedd)’ in Welsh. If it needs to be clarified which Bangor the train is calling at, surely it’s the English announcement which would need it more? (Personally I don’t think it’s necessary to add the county in either language but especially not in Welsh.)
TT-ONR-NRN
30 Dec 2016
Salford Quays, Manchester
It's the same on TfW's 197s, oddly.
