Why are you obsessed with destroying a very useful and popular service?
Wikipedia saysI disagree to a point:
Sheffield
Yes you were right that the early operations were certainly hindered by a complex ticketing system and the initially small coverage area, contributing to disappointing ridership figures during its first years.
However in 1997 when Stagecoach took over operations and following management and operational changes, as well as further expansion of the system, ridership numbers have risen considerably.
Also you forgot that Rotherham is just a extension of the Sheffield network, they don't have their own network.
I remember horrendous cost and time over-runs when it was being built because (as in Edinburgh) all the services buried in the streets had to be found then moved at the tram's expense.The early years of the Supertram were not straightforward; in the eyes of some officials, the scheme was reportedly viewed as having been a failure. Running in direct competition with cheaper and more frequent buses, far greater numbers of passengers chose to continue commuting by means other than the fledgling tram network; retailers also frequently complained due to the disruption caused by the lengthy construction works performed while establishing the Supertram network.[9] The complex ticketing system originally adopted has also been attributed as having being a source of irritance and confusion to would-be passengers.[2] Within the first two years of operations, it became clear that the projections for passenger numbers had been overly optimistic, while there was concern that the system represented poor value for money and did not seem to be gaining traction.[9] Thus, the issue of what party should bear the cost became a politicised matter. Allegedly, by 1996, the councils backing the Supertram had recognised that the operation had both operational and managerial problems which required addressing, thus consultants were asked to draw up options for the system's reorganisation into a more commercially-viable venture, including the franchising of Supertram and its wholesale selling-off
Edinburgh
except that it was almost so catastrophically late and over-budget that it has probably wrecked the chances of any other tram re-introductions in the UK.I can't see how you can count Edinburgh as a disaster apart from the various disputes between Edinburgh Council and the Tram Contractors especially considering the following facts:
Edinburgh Trams in its first year of operation had 4.92 million passengers travelling on the system which increased to 5.38 million in its second year of operation.
This basically means that this is 6.7% greater than the target set before the system's launch.
Also note that Edinburgh Trams had achieved profitability two years ahead of schedule.
Now that doesn't sound much like a disaster to me!
Don't know the line in question so can't comment on that. I just don't understand the obsession with guided busways. The Cambs one operates at 50mph, which is actually slower than a bus can legally be driven at on a suitable road.
Trams are (surprisingly) quite good at coping with gradients, I think!
My memory is that Sheffield didn't have a particularly easy birth,
Sheffield
Wikipedia says I remember horrendous cost and time over-runs when it was being built because (as in Edinburgh) all the services buried in the streets had to be found then moved at the tram's expense.
should be looking at ways to increase footfall.......a link between watford junction and st albans city would do it.....any short cut avoiding london and saving time would.Not obsessed just wondering on ways to increase the service frequency that's all.
I’m reasonably sure the topography doesn’t work for that, not least getting across London
Road. It would need some residential demolition, and it gets awfully close to the 125 new flats at Ziggurat.
As mentioned last time we had this discussion, any extension of paths down the WCML is a waste of paths (most of which don’t exist) and has the potential to screw up the slow lines whenever a branch train is late off, meaning the next down branch train can’t get on. Unless you build two loops, one of which at Watford on the branch (with two platforms).
The issue is that Holywell Hill is a main residential street, and is also the main access route both for people living in several houses immediately off it, and for a whole swathe of people who access the town from the south west direction. Banning cars will make life very difficult for several thousand people for whom that road is the main, and in some cases only, access their property.
However, having driven up it 20 minutes ago, (as I do about 3 times a week) I can say there definitely is room for all types of vehicle, including trams (which would be rather less frequent than buses on the road). What is needed is a ban on parking on the road itself. The gradient is about 10% according to my legs when cycling it, I genuinely don’t know if that is within tram capability.
Absolutely not, I was just recognising that a installing a tram line means dealing with all sorts of other rotting services, which if costed against the tram will scupper it, and really ought to be dealt with as part of a work- and quality-generating and energy-saving initiative. I would happily accept trolley buses as a second-best, but we keep being told that batteries and special non-polluting internal combustion engines will render them obsolete anyway...Presumably you are against any heavy rail infrastructure improvements because they have an awkward tendency to go over-budget and be delayed?
I'm very much afraid so: There seem to be lots of excuses around for not getting on with Manchester to Leeds. When will Swansea be done? Or the other obvious lines in the west of England... Anyone want to join in a sweepstake for the date that Bristol Parkway (Westerleigh Jn) to Bromsgrove gets done?Has the GWML electrification wrecked the chances of any other electrification in the UK?
I'm not familiar with the Trings so didn't know they were the first to go if it all goes a tad Pete Tong, maybe extending the Trings to Milton Keynes and having the SN services terminate at Tring instead?
Gradients no serious problems for trams - there are some equally steep gradients on the Sheffield system. On the few occasions I have visited St. Albans, the worst problem was traffic jams that would also affect any trams. Any tram system ought to serve both stations in St. Albans, but I think the main traffic for each station would be to/from the city centre area, rather than people crossing between the two stations.
The Trings provide the only Euston service for Kings Langley and Apsley for most of the day.
The best way is probably a second train per hour as a Clapham Junction to Watford Junction short working. No need to cut the longer one.
There's not much else from MML land to Hertford other than the 724 though. What they could do (I say this with my tongue in cheek) is make it a truly limited stop service and run it along a bus way from Watford to St Albans Abbey, up Holywell Hill to the City Centre, and then down London Road to join a second busway to the A1(M) bridge just outside Hatfield, then down conventional roads to Welwyn Garden City, and then along a third busway from Welwyn GC to Hertford. Not sure that Sustrans/walkers/cyclists would be too happy, mind. BTW the 321 frequency is every 20 minutes.
Which was the other idea I was thinking of, I can't see a second service being extended to St Albans for 2 reasons:
1. Abbey Line platforms are 4 cars long I think?
2. These services are now 8 or 10 car long now?
But you're right, having 2tph between WFJ and CLJ would improve cross London links.
The thing with the 724 is it really ought to be a express service calling at the main points between Harlow and Heathrow not at every local stop en route.
Think Stagecoach's X5 service between Cambridge and Oxford etc....
Rather that suggesting whether a through service is even practicable (let alone viable in passenger terms) I prefer to think that a two train service on the branch could be timed to provide a valuable alternative route not only to London, but also northwards up the WCML. Most of the VT and LNR services are clockface timetabled so the complete independence of the branch can be optimised to provide effective interchanges. In the morning peak, the few Watford starters could be served better and even in the evening, a Watford to Clapham/East Croydon shuttle could align with Abbey line departures.I don't see sending it to St Albans as having any benefit at all as, as I said, they already have a cross-London service in the form of Thameslink.
If St Albans was to get a through service, connecting it to a Watford shuttle (half hourly all day) would make most sense.
I did think that you supported it but your post was really the latest one on which to post a return to the original topic. I've pondered of giving the line the simplest of clockface working (1 per hour) but the issues would be:I do support half hourly on the branch. But having said that, I actually think a reasonable second choice would be a frequency reduction. The present bitty 45 minute service is not memorable. Reduce it to hourly clockface timed to connect with specific trains to London and northbound and to arrive in Watford in time for starting work at 9 and the more memorable service will actually make it more useful.
Something to do with lack of demand - have you visited Hertford? It's a tiny place relatively speaking yet has 2 decent train services to London - which is why people move there. There isn't (and hasn't for very many years) been the demand for travel between Welwyn / Hatfield and St Albans back towards Hertford and Ware.
The basic bus service pattern from St Albans / Hatfield / Welwyn to Hertford is broadly unchanged since the 1980s i.e.
341 running roughly hourly from Hatfield via Essendon to Hertford.
724 running roughly hourly from St Albans to Hatfield, WGC and Hertford.
The only change was the withdrawl of the 388 which used to run 3 / 4 times a day from WGC to Hertford via Digswell, Tewin - and that service had been an HCC contract since the first round of deregulation back in the mid 80s.
If there was this mysterious pent up demand for such journeys the current services would be full and standing most of the time - but they're not.
As for a "busway" between Welwyn GC and Hertford - can I ask what you've been drinking or smoking?
Er... - putting a diesel on a line already equipped with 25kV OLE is never in a list of "best things". St Albans, and Watford has enough diesel pollution of it's own (including class 22x smoke generators). As the wires are there, use them, and there is no shortage of trains to do that with.... But this is meant to be about the St Albans branch line not local bus services so the best thing for the branch apart from having a Class 230 trundle up and down all day is to get that passing loop in and restructure the timetable so it operates to a 30 minute service all day and timetabled to meet connections at either end.
Okay but the 341/641 could be better managed for example operate them as one service say as the 341 or the 641 and run them on a hourly service all week including Sundays ensuring they call at both Hatfield and Hertford Railway Stations as both Hatfield and Hertford are only 30 mins by bus which must be easier then relying on the hourly train service from Hertford to Stevenage then getting the train service from there to Hatfield.
As to the belief that current services would be full and standing with this mysterious demand, I think that's being slightly creative as I don't believe they would be full and standing but they would serve a useful connection between the two towns and would be popular once they got well marketed and known.
So what would you do with the line if you were Hertfordshire Council?So the money could be used to much better effect elsewhere on the network.
Wouldn't an A1 upgrade be a DfT budget matter?... If HCC were looking at funding something, I'd plump either for improving the A1 or the Croxley Rail link, both of which I suspect would offer a better benefits case. ...
The A405/412 route carries quite a lot of St Albans traffic and it can only get worse. One day it may need something doing that doesn't encourage yet more road traffic.... The Abbey Line I'd leave as is to be honest - it's not going to suddenly see a massive patronage increase because most of the St Albans traffic uses City for London and the intermediate stations are all serving pretty minor places.
The issue there is finding paths for it to cross the main line at Watford junction, I suspect that is a large part of why the current service continues north.The best way is probably a second train per hour as a Clapham Junction to Watford Junction short working. No need to cut the longer one.
Reinstating the Hatfield connection would be very problematic. Firstly the route is severely severed at the Hatfield end by the building of the A1 road tunnel and other developments beyond the tunnel and up to Hatfield station, and at least one new estate across the route at St Albans. Secondly the "Alban Way" pedestrian and cycling route along the old trackbed has become very popular as a traffic-free route and any change to it would be, I suspect, be strongly resisted by many. Thirdly, the route would require a reversal at St Albans Abbey station each time - or of course drop the Abbey station and reinstate London Road station with a significantly shorter walking route to the City station......I surely can't be the only person who is fed up with seeing existing and disused alignments being used for guided busways. Thanks to the guided busway in Cambridge, East-West rail now faces a huge problem of how to get a connection into Cambridge in the future.
As for the Abbey Line, re-instate the passing loop and re-open it to Hatfield. The latter would eliminate the need to go into London and back out again, for what should be a simple journey between neighbouring areas.
