Proposed May 2014 timetable changes (Manchester area)
pemma
23 Jan 2009
Knutsford
A summary of what I've noticed:
* Liverpool to Stalybridge service set to be truncated at Victoria - options for replacement service for Stalybridge being examined.
* Blackpool North to Victoria service to run to Huddersfield (but no through service in reverse with a Huddersfield-Wigan service instead.)
* 1tph Liverpool to Victoria to Newcastle and 1tph Airport to York service (standard pattern) in lieu of 1tph Airport to Newcastle (standard pattern) - Newcastle to continue to get a limited direct Airport service.
* A Rochdale service extended to Todmorden (reversing on re-opened Todmorden curve. Burnley-Manchester service to start in December 2014 due to Northern not being able to source additional rolling stock in time for May 2014.)
* New 05:40 Blackpool – Manchester and 06:50 Manchester – Preston Northern Rail services to replace withdrawn TPE services.
* 15:33 Hazel Grove – Preston and 17:23 from Preston to Hazel Grove services to get extra capacity.
* Peak time Barrow to Manchester Airport morning services and evening Manchester Airport to Barrow services to remain.
Further details here: http://www.transportforgreatermanch...il_service_changes_december_2013_and_may_2014
pemma
23 Jan 2009
Knutsford
Will Ashton-under-Lyne railway station see a reduced level of service ?
In the linked pdf TfGM make the point that not that long ago it went to a 3tph frequency instead of a 2tph frequency. They suggest pros and cons of alternatives like the Southport-Victoria service running to Stalybridge which is dismissed and a Stalybridge-Victoria shuttle, which TfGM state is the most viable option but it will cause operating costs to increase.
Sounds like the Liverpool-Stalybridge will be cut back to Victoria permanently.
In my casual use it seems a poor performer east of Newton-le-Willows, though 1tph isn't attractive.
The new Liverpool-Victoria-Newcastle service is being introduced at a period of maximum dislocation and lack of facilities at Victoria, and during electrification works and Metrolink rebuilding.
It's a grim place at the moment (even more than it was).
It won't be popular with users changing there, compared to Piccadilly.
Lack of mention of south Manchester must mean no changes there.
I am amazed how much management time goes into these relatively simple changes.
And all to be thrown in the mincer if devolution of the new franchises goes ahead.
pemma
23 Jan 2009
Knutsford
Well with no extra rolling stock for Northern expected until December 2014 and the existing units likely to be needed to work a bit harder from May 2014 due to changes as a result of the new TPE timetable, I doubt Northern could change South Manchester. The lack of extra stock for a Burnley-Manchester service to start straight away would also mean no stock for a new Stockport-Victoria service, for instance.
Dunc108
10 Jun 2013
Morecambe
Well the quicker they get Victoria sorted the better, the TPE service is just the tip of the iceberg; when the Ordsall Curve opens they'll be a damn site more TPE traffic over Miles Platting!
WatcherZero
25 Feb 2010
In the near term the only changes to South Manchester services would be to capacity, that in the next couple of years Northern might have enough electrics that they no longer have to regularly substitute a diesel and most airport services would get longer and enjoy the fourth platform at the Airport.
In the more distant future you never know, the Airport Western Link may make an appearance in Cp6 or Cp7, that would shake up South Manchester and Cheshire services quite fundamentally.
gnolife
4 Nov 2010
Johnstone
Will the Liverpool - Piccadilly - Stalybridge - Scarborough service remain, or it the Liverpool - Newcastle service replacing that as well?
They could do with addressing the abysmal state of sunday evening services eminating from Victoria. Everything seems to grind to a halt by about nine.
pemma
23 Jan 2009
Knutsford
The Liverpool - Scarborough stays the same from my understanding.
Yes that remains until North TPE goes 6tph (with 2tph Liverpool-Victoria-Newcastle) which is post-Ordsall Chord. The expectation is that Liverpool-Warrington-Sheffield will go half-hourly after Liverpool-Scarborough goes.
The 'South Manchester' schemes listed under the Northern Hub are:
1. Additional hourly Greenbank-Stockport service.
2. New hourly Stockport-Denton-Victoria service (could be an extension of 1 rather than a stand-alone service.)
3. Liverpool-Buxton stopping service via CLC (not really possible to implement pre-Ordsall Chord.)
4. Hazel Grove terminators possibly extended to Sheffield, Chinley or Buxton, subject to business case. (Given Hazel Grove to Preston could become an electric service in 2018 I imagine Preston services would be diverted to an alternative 'South Manchester' destination.)
There's also a proposal from a Network Rail RUS to extend the Stoke stopper to Birmingham via Stone alongside other changes.
Obviously all the above require additional rolling stock or infrastructure which is not yet available.
I understand that consideration was given to extending the Airport spur when the additional platforms at the Airport station were put in.
If you look at all the proposals from different parties involving the Mid-Cheshire line then it'll probably give you a headache when you try to work out how they will fit together:
1. Crewe to Middlewich, Northwich and beyond service.
2. Tram-trains between central Manchester and Northwich/Greenbank via Sale.
3. Additional Greenbank-Stockport trains.
4. Western Airport link.
5. Half-hourly Altrincham-Stockport service with new Metrolink interchange at Baguley and possible station at Cheadle.
In the short term though we can safely say 3 is likely to go ahead in the next few years with 1 being a possibility and the rest are long term aspirations.
A more immediate concern is the level of overcrowding on the 07:17 Manchester-Chester which desperately needs to become 4 car unless an c.08:00 Stockport-Greenbank service can be added.
cle
17 Nov 2010
Might they also look at the level crossing in Hale? When a train is in, it's down for at least 4-5 minutes.
pemma
23 Jan 2009
Knutsford
I think the level crossing at Navigation Road is more of an issue. Hale gets at most 3 passenger trains per hour currently, Navigation Road gets 20 trams per hour and up to 3 passenger trains per hour.
Dunc108
10 Jun 2013
Morecambe
Well, at least it's got Blackpool & Wigan diagrams now on a Sunday, didn't even have those till a few years back! :lol:
Thomas6187
27 May 2011
Rochdale
I wonder if the TfGM are trying to make people in the Moston area use the Tram instead of the Train. The trains been reduced to 1tph and almost half during the peak hours.
Xenophon PCDGS
17 Apr 2011
Moston people using the tram...:shock:
Please be so kind as to examine an area map of Moston and whilst the Metrolink stop of Newton Heath and Moston serves the border area of Moston that adjoins Newton Heath, a vast area of Moston is nowhere whatsoever near to that tram stop. Nor is this area anywhere near the railway station on Hollinwood Avenue that is on the northern area border to Chadderton. Can you honestly expect the good citizens of Moston to forsake their existing bus services to use either the train or the tram?
pemma
23 Jan 2009
Knutsford
Update on Stalybridge
TfGM said:
Therefore, from May 2014; at Stalybridge and Ashton the peak service frequency is retained at current levels, and in the off peak two trains per hour, and good cross city links, are retained to Manchester Victoria in conjunction with the following service changes:
 the Kirkby to Manchester Victoria will continue to be extended to and from Stalybridge;
 eastbound the Manchester Victoria to Huddersfield service will be linked to the existing Blackpool to Manchester service;
 westbound, the Huddersfield service will operate through to Wigan Wallgate;
 the proposed Northern Rail services to and from Stalybridge will provide worthwhile connections into and out of the new FTPE Liverpool – Newcastle service in both directions at Manchester Victoria:
 the Northern westbound local provides a 9 minute connection into the fast FTPE service to Liverpool;
 passengers from Liverpool on the FTPE Newcastle service have a comfortable 13 minute connection into the Northern Rail local service to Ashton and Stalybridge; and
 the ability to connect into the FTPE services actually provides a shorter Ashton to Liverpool journey time in each direction of only 55 minutes, compared with 1 hour 20 minutes now.
As a result of the additional services detailed in Section 2.5, Stalybridge will enjoy a two train per hour service to/from Manchester Piccadilly (spaced 30 minutes apart), comprising;
 the FTPE Liverpool to Scarborough (and vice versa) service will call at Stalybridge (as now);
 the FTPE Manchester Piccadilly to Hull (and vice-versa) service will now call additionally at Stalybridge.
The highlighted bit being the most surprising given it changes the May 2014 timetable that TPE have had approved by ORR.
http://www.transportforgreatermanch..._stalybridge_and_ashton_off_peak_rail_service
WatcherZero
25 Feb 2010
One of the other four options explored was to ask FTPE if the new Liverpool to Newcastle service could call at Stalybridge (or Ashton). FTPE was not able to do this for operating reasons.
However, TfGM has continued to work on possible options to improve the service to Stalybridge, including suggesting that the Manchester Piccadilly to Hull service could call. FTPE positively investigated this suggestion, exploring the operational and commercial implications. TfGM is pleased to report that working collaboratively with FTPE and Northern Rail that from May 2014 the off peak Manchester Piccadilly - Hull services (and vice versa) will call at Stalybridge.
To facilitate a 2 minute earlier departure from Piccadilly of the Hull service, it is also necessary to retime the Manchester Piccadilly – Rose Hill trains to also depart 2 minutes earlier. Therefore the Rose Hill train will also depart and run 2 minutes earlier throughout. There is no impact on journey times or operational resilience of the service, as the present 19 minutes standing time at Rose Hill is simply reduced to 17 minutes.
FTPE has bid for the above services to call at Stalybridge; this is will be subject to final confirmation from Network Rail as part of the timetable development process.
Looks like they sucessfully persuaded TPE, they were previously saying they didnt want to stop at Stalybridge as the time penalty to other passengers outweighed the extra revenue.
Also unsurprisingly says that Northerns revenue forecasting unit is currently swamped with work calculating the service and travel patterns for future electric services.
In other news Northern are applying to the Dft to destrengthen a couple of services to provide extra Bolton capacity reducing the capacity loss from 8% to 5% though TfGM doesnt want this to be a permanent loss to the services destrengthened and to operate on days when crowding is predicted to be bad not as a fixed arrangement. Northern has also finished their calculation on Bolton crowding post TPE change and they believe that while some of the busiest services may be 98% full that no services would be over capacity and that the busiest services have spare capacity on the preceding and succeeding services.
pemma
23 Jan 2009
Knutsford
It also involves tweaks to some Northern Rail services through Guide Bridge by a couple of minutes to avoid a clash with the re-timed Hull-Manchester service.
Apparently from May 2014 there's going to be 3 x 185 diagrams on Hull services, 1 x 2 car 170 diagram and 1 x 4 car 170 diagram, so combined with the additional TPE service there's less of an argument of there being no room on the TPE services for Stalybridge passengers.
cle
17 Nov 2010
I guess they are teeing it up in people's perceptions that the fastest trains in future will indeed be from Victoria (heading both west and east), and Piccadilly will be more the semi-fasts doing Stalybridge, Dewsbury, Birchwood etc.
pemma
23 Jan 2009
Knutsford
The Airport services would do both but would obviously be slower from Piccadilly than from Victoria.
