MatthewRead
I was reading the latest issue of Express and it had an article about the Q stock's restoration will it be able to run before the surface network is entirely re-signaled in 2023?
As discussed elsewhere, the section from Harrow to Amersham will remain available for conventionally-signalled trains, due to it having Chiltern traffic over it, so that's pretty much the only bit that it will be able to operate on.
Albeit that will depend upon the train protection system installed for use by trains operating under lineside signalling. I'm not sure if this has been decided upon, but I would be surprised if TPWS grids were not being considered in lieu of trainstops, given that the primary (entire?) reason for providing lineside signalling will be to allow mainline stock to continue to operate as today.
Isn't there something in the way of TWPS grids?
The -ve rail can be gapped fairly easily...
Has to be, or the negative shoe would tear up the grid.Oh cool, is that a grid under a protective wooden ramp?
If I recall correctly TPWS was designed to prevent head on collisions or being hit in the side and not for a rear end smash . But I could be wrong . Do not forget there are lots of four aspect signals on the metropolitan north of Harrow that means lots of gaps in the fourth rail .
As for the district to Wimbledon the line already has AWS so there is no need to fit TPWS on the automatic signals just a few at the junctions . So why put a grid in the north bound platform starting signal as it is automatic ? There are always gaps in the fourth rail for other reasons So is the gap shown in the photo really for a TPWS grid ?
On the Richmond branch the existing signalling will remain and have the CBTC system overlaid, so LU trains will operate automatically. Trainstops are likely to remain for LO trains as there is no TPWS.What about Gunnersbury to Richmond, or the Wimbledon branch south of East Putney. Are they being resignalled? How will other rail trains operate there?
As LU own the infrastructure on the Wimbledon branch it will be resignalled, new posts with spacing optimised for CBTC operation, trainstops removed. LU trains will operate automatically.
The Wimbledon branch currently still has bulb signals and the older version of the position shunt signals (red & white at danger).
