ChrisPSR
What is "cleared away", please? The Up Main Home and the Up Distant must have been 'on' (danger/caution) whilst the coal empties were being admitted to the loop - the mechanical interlocking, by then a fundamental part of any signalling installation, would have prevented that. The Up Loop Home signal (which had authorised that movement) must have been replaced to danger before the loop entry points were returned to normal, and at some time after that, the signals right through on the Up Main were cleared (that is, to show a proceed indication). Do you disagree with any of that?
1) Do not the words used indicate the meaning?
2) I think you should have been at the various hearings if you know how the signals were operated and engineered. I have certainly not read any definitive proof of your engineering and use statements. All engineering was in its infancy fitted in part through to none existent.
