Rail Freight Flows
Discussion in 'Allocations, Diagrams & Timetables' started by pmb, 15 Nov 2019.
  1. Dr Hoo
    Dr Hoo Established Member
    1,474
    10 Nov 2015
    Hope Valley
    Noting that the established Clitheroe to Avonmouth Cement flow has been cancelled recently is Padeswood genuinely new traffic or just a substitution (over a shorter distance, actually)?
  2. furnessvale
    furnessvale Established Member
    3,608
    14 Jul 2015
    Yes, I hadn't noticed the cancellations. Padeswood sidings have only recent repened and it makes sense for the cement company to use them in this way.
  3. 158756
    158756 Member
    1,084
    12 Aug 2014
    Immingham I would have thought was likely to suffer the same problems as Liverpool (which I think is a bigger container port) in being too close to most of the inland terminals for rail to be competitive.
  4. high camera
    high camera Member
    57
    16 Jan 2013
    Hansons cement at Clitheroe is on its annual shutdown for maintenance work, no cement being produced so no trains required.
  5. furnessvale
    3,608
    14 Jul 2015
    Or more correctly, no trains can be dispatched from that plant hence the use of Padeswood. I wonder if the traffic will revert to Clitheroe after the shutdown or maybe both plants will dispatch by rail?
  6. daccer
    daccer Member
    362
    11 Feb 2009
    They have spent a lot of cash at Padeswood on tickling up the sidings etc and I doubt if they would do that if they were not thinking of a long term use.
  7. furnessvale
    3,608
    14 Jul 2015
    Yes. I think the first train(s) out of Padeswood went elsewhere than Avonmouth and I am sure that will continue even if the Avonmouth traffic reverts to Clitheroe after the shut down.
  8. Chris 76
    Chris 76 Member
    22
    21 Jul 2017
    Moseley, Birmingham
    Found this when I checked out Padeswood after seeing it from the A483 after Christmas:
    The project also includes installing new cement silos alongside the existing railway line to allow up to three trains a week to be loaded for deliveries to the depots at Kings Cross, London, Avonmouth, Bristol or Belshill, Glasgow depending on demand. At present, the rail link is only used to bring in coal to fire the kilns.
    https://www.hanson-communities.co.uk/en/padeswood-cement-works-planning-application
  9. pmb
    pmb Member
    40
    15 Nov 2019
    Cambridgeshire
    Here's a link to a slightly more up to date article (02/09/2019) - the article above appears to have been written only shortly after construction commenced.
    https://www.hanson-communities.co.u...for-cement-load-at-padeswood-in-three-decades
    The point of posting this article is that interestingly it mentions nothing about Avonmouth like the previous one. Maybe this confirms what people have been saying that traffic from Clitheroe will run to Avonmouth when Clitheroe starts up again.
  10. high camera
    high camera Member
    57
    16 Jan 2013
    Clitheroe cement appears to be running again, there is a train in yard now and smoke coming from factory chimney
  11. Far north 37
    Far north 37 Established Member
    1,767
    13 Apr 2011
    66789 working 6C03 later this evening to carlisle yard is the train in question.
  12. 158756
    158756 Member
    1,084
    12 Aug 2014
    According to RTT this train ran three times last week as well, so what was it carrying then it the factory was closed?
  13. james_the_xv
    james_the_xv Member
    13
    29 Oct 2019
    Coventry / Glasgow
    Route learning?
  14. Far north 37
    1,767
    13 Apr 2011
    Deleted.
  15. Far north 37
    1,767
    13 Apr 2011
    No it ran under its normal headcode route learning loco would have been under a class 0 headcode.
  16. furnessvale
    3,608
    14 Jul 2015
    The manufacturing plant may have been closed for maintenance but they probably have on site silo storage.
  17. Far north 37
    1,767
    13 Apr 2011
    The train is actually for mossend recesses in carlisle enroute.
  18. furnessvale
    3,608
    14 Jul 2015
  19. ExRes
    ExRes Established Member
    2,545
    16 Dec 2012
    Devon (Ex Sussex)
    Excellent news which will help Cappagh/DCR get some more lorry loads off our overcrowded roads, the only slight disappointment is that they're unlikely to be built in the UK like the Ecofret2 intermodal triple platforms ordered from WH Davis by VTG for GBRf
  20. 158756
    158756 Member
    1,084
    12 Aug 2014
  21. ExRes
    2,545
    16 Dec 2012
    Devon (Ex Sussex)
    I believe they have been ordered to work with the DCR 60s on in house Cappagh aggregate and construction jobs which is work new to the railway
  22. pmb
    pmb Member
    40
    15 Nov 2019
    Cambridgeshire
    DCR have a path in the system for a new overnight service, 22:10 6Z60 from Carlisle to Willesden. ExRes, on the DCR locos thread, notes that 60028, after working the 1546 6Z20 Chaddesden to Kingmoor yesterday as its maiden run, looks to be working this new flow this evening.
    Does anyone know what this new flow will be about? I presume it will be recycled ballast as it's coming from Kingmoor Yard?
  23. furnessvale
    3,608
    14 Jul 2015
    Just a couple of points to bring this thread up to the front.
    Trainloads of building waste have restarted from Cricklewood to Calvert, and today is the first day of car trains from Dagenham to Garston being hauled by DRS.
  24. Momo and diggy
    Momo and diggy Member
    12
    20 Feb 2020
    Little hulton
    Is the Dagenham to garston being hauled by a class 88
  25. Mag_seven
    Mag_seven Established Member
    5,721
    1 Sep 2014
    here to eternity
    According to post #94 in this thread, yes.
  26. growler373
    growler373 New Member
    2
    28 May 2015
    Apparently the curvature at Garston is too much for an 88, 66434 was on it yesterday
  27. furnessvale
    3,608
    14 Jul 2015
    That is interesting. A curve too much for a Bo-Bo so they put a Co-Co on the job!
  28. billh
    billh Member
    124
    7 Jan 2015
    Aggregate test working last night, Peak Forest to Salford Hope St with a full consist of shortened coal hoppers. Potential for more vehicles with greater total payload for the same length of train.
  29. AndrewE
    AndrewE Established Member
    3,435
    9 Nov 2015
    That is counter-intuitive. You would think that the space taken up by buffers and drawgear would be better used by filling in the gap between 2 short wagons and putting stone in it!
    If it is the case (that shorter-wheelbase wagons can carry more) I wonder why firms have invested in all these 100-ton hoppers? Maybe the weight savings by doing away with bogies lets you fill a stone wagon deeper.
  30. furnessvale
    3,608
    14 Jul 2015
    You have got the wrong end of the stick.
    Up to now the wagons have been ex coal bogie hoppers which are longer and cannot be fully filled with stone without going overweight. By cutting 10ft+ out of the length of each wagon, they can still be loaded to 102 tonnes but more wagons can fit in a given length.
Share This Page
