Peter Mugridge
Ah... is it the Inverness to Wick via Thurso...................................?
An X in a timetable would typically indicate a request stop, so this may be stations along a route.I think I know what they are there for, but are the 'x's replacing letters?
Quite correct.An X in a timetable would typically indicate a request stop, so this may be stations along a route.
It'll change when Dunrobin Castle opens for the summer.Ah... is it the Inverness to Wick via Thurso...................................?
That's a pretty good shout, though.I know, but I can't get what I assume to be CRS codes to work, so I thought they were with the middle lettterissing maybe, replaced with an X
The one I'm thinking ofOlive Mount cutting, Liverpool ?
The one I'm thinking of was half as deep again...
Correct, although I have seen 120 ft deep quoted in several places. My book says tunnelling was reckoned to be cheaper beyond about 60 ft depth, but they wanted the stone anyway.Could it be Talerddigg on the Cambrian? (About 100 feet with once near vertical sides.)
Sorry, I was away for a bit and hadn't realised I had won the last question.
In that case -
What was Rondout, Illinois on the Milwaukee Road once famous for?
I couldn't resist Googling re Rondout, Illinois; which I felt disqualified me from directly answering. However -- in the light of your clue -- the Wiki item shows a sign at that place; which if I'm correct, gives particulars of a dramatic railway-related event there nearly a hundred years ago.
Train robbery with biggest "haul" from any such, in US history, 14th June 1924; carried out on mail train ex Chicago, where the perpetrators had boarded the train. Some $2 million in cash, jewellery and securities, was stolen.
Seeing the number of lines that met there I wondered if the actual station name boards were the biggest physically (if they listed all the participating railways?)
It apparently had a very early signal box/interlocking with lots of lines converging, so maybe biggest signal gantry/most signals? (a bit like Rugby in the UK)
Were they some form of warning signs instructing drivers to stop at a particular place or not to take a particular line?
Buffalo herd migrating across tracks?
