Railway General Knowledge.
Cowley
15 Apr 2016
Devon
Argh. Wish I’d thought of that.
I even ran through a few class 50 names before I posted.
Feeling a bit silly now to be honest...
DerekC
26 Oct 2015
Hampshire (nearly a Hog)
I am guessing it's something like "Planet" or "Thunderer" which were popular kinds of name in the early days and passed down to later generations of locomotives.
Trackman
28 Feb 2013
Lewisham
No correct answer so far.
Great question. City of London..? (Only joking)
City of London is up there, there were 6 - that's why I used it as an example.
The one I'm looking for was carried at least 9 times.
Clues:
It's 1 word.
There is one loco left on the mainline railway that carries the name (AFAIK) but is stored at the moment, not sure if it's getting overhauled.
Trackman
28 Feb 2013
Lewisham
No guesses recently, so another clue.
This name has been carried on a class 37 and class 47 loco.
The class 37 only carried the name for a short period of a time.
That should narrow it down a bit!
Cowley
15 Apr 2016
Devon
Was the name on the 37 official or was it a painted on Tinsley name?
I’m struggling with this one. Vulcan maybe?
Trackman
28 Feb 2013
Lewisham
I thought it was official- but some digging about shows its unofficial.
However, your guess is correct- Vulcan!
apart from the 37, 45 106 carried ‘Vulcan’ nicely painted by Tinsley staff but records show as 'unofficial'.
However 'Vulcan' still wins with 8 locos.
Your floor!
Mag_seven
1 Sep 2014
here to eternity
As an aside there are also loco names with the name "Vulcan" as part of them e.g. 37558 'Avro Vulcan XH558', 86228 "Vulcan Heritage"
Cowley
15 Apr 2016
Devon
Your floor!
Thanks, that was a good one.
Ok this is a bit left-field.
I’ve got a structural problem with the walls on a house that’s for sale in Exeter.
The house was built in the 1930s.
It’s nowhere near a railway, but the problem is related to the railway.
Can anyone guess the link?
AndrewE
9 Nov 2015
Building on hints and other people's suggestions I would guess that steam loco ash was used to make breeze blocks, which have turned out to corrode the wall ties, potentially destabilising a cavity wall.
My first thought was that loco smoke had caused enough corrosion to create the problem. I have read that general urban air pollution has destroyed the wall ties on some estates, which is why they are made from stainless steel nowadays rather than the older galvanised steel...
Cowley
15 Apr 2016
Devon
I think that’s probably close enough Andrew. The ash was bought cheaply and mixed up as paste for use as mortar between the blockwork. Unfortunately it has such a hi Ph value it’s rotted the wall ties out.
Over to you...
AndrewE
9 Nov 2015
Over to you...
I think Snow1964 got as close as I did before me, although I hadn't read his (?) reply when I posted mine: Your floor Snowy!
AndrewE gave a more technical solution, but I thank him for saying I had basically answered it before him.
Let’s try this question, which line which was built as a cut off (or more direct routing), has 3 stations (all still open), and the station buildings show 1886 as build dates. However the line didn’t open until 1888
Which line is it (from where to where) and a bonus if you can say what gave way which delayed the opening.
No guesses so far, so a clue :
this line is electrified (so should restrict the options quite a bit, based on opening date)
krus_aragon
10 Jun 2009
North Wales
I've no idea myself (the subsequent clue about an electrified route makes it clear that it's outside my usual patch), but would I be correct in guessing that the opening of the line was delayed by two years (or so) for some reason?
I think I had better give a second clue, in addition to clue 1 the line is electrified. The delay was due to a particular clay which caused a newly constructed embankment to slump, apparently at one point is few hundred feet wide at bottom following the slumping, the oozing clay was locally nicknamed the treacle mines.
Liverpool and New Brighton ?
No, not correct, too far north
as there is a 100 milepost along this line, think 100 miles from London, (that clue should eliminate a lot as would be in the sea if went 100 miles from London in certain directions).
