Northampton avoiding line?
No that’s not correct, all the original stations are still open on line in question
Could it be the LSWR direct line from Brockenhurst to Christchurch? It cut off a loop of "Castleman's Corkscrew". Not sure of the opening date but it's about the right distance from London, has three open stations and is electrified.
3rd rail side contact electrification?
Given that there are 4 railways left using the technology, could it be multiple phase AC then? I've seen pictures of locos with 2 pantographs, (and not just shunters running under trolleybus wires) so I guess they might be 3-phase if an insulated rail provided the third? Or maybe like trolleybus DC with feed and return wires?It wasn't Atmospheric, was it?!
OK, I have recently read a book which claimed that 2 original broad gauge (7-foot and a bit) locos survive and that they worked into the 2nd half of the 20th century, although not continuously.That's the one. The Cascades Tunnel used and the Petit Train still uses 3-phase AC. Two wires plus rail for the three phase-connections. The big advantage is that you get simple non-electronically-controlled regenerative braking using induction motors - just the job for heavy gradients.
Your connection.
Correct: after being first retired when their breakwater job was done, at least one was resurrected to work a quarry when the road network was being improved.I think I've heard that it concerns an island of the Azores group; a basically short, isolated line running along a breakwater or "mole" on the shore, the line existing to carry stone etc., for maintenance of said work. Locos -- aged saddle-tanks (0-4-0 wheel arrangement?) -- still in existence at this venue, thanks to a preservation / conservation initiative of some kind.
Open floor, please.
I think that C H-E is Cuthbert (Chip) Hamilton Ellis (29 June 1909 – 29 June 1987), so you're talking about railway writing and painting.
And a very good book it is too2Simon Garfield wrote "The Last Journey of William Huskisson" about early railway development, including the death of WH.
Open writing floor!
Here's an 'off-the-top-of-my-head' answer from a non-GWR specialist:I agree ... in fact, they both are!
I'll take this back if I may, and ask you to identify some random GWR Shed Codes:
ABH
BCN
LTS
MTHR
NEY
RYR
A clue is that they're all in Wales!
Aberystwyth
Brecon
Llantrisant
Merthyr
Neyland
Radyr
I think that was a product of my knowledge of geography! (I'm hotter on the independent, pre-grouping railways of South Wales than the GWR itself.)I'd hate to think what you're like with your specialist subject, because you're 100% correct!
That's two of the four on my list. One of the others is arguable, but there's another option definitely missing.Well, I will have a guess:
Hoyhead
Porth Dinllaen (not sure if I have spelt it right) on the Lleyn Peninsula
Fishguard
Milford Haven
You are indeed mistaken about Port Dinorwig, Porth Dinllaen is on the list, so that's one correct. (Holyhead is the other correct one.)Neyland was the one preferred by Brunel, and there's still buildings of his era there; however, Fishguard was the choice for South West Wales. Something tells me that Port Dinorwic was also considered, but I may be mixing that up with Port Dinllaen.
