pappleby
Hi, could anyone please tell me, how they determined the spacing between sleepers.
Nowadays, another factor is the need to increase lateral restraint to avoid buckling in CWR.I think it was mostly by experience from the early days of plateways onwards. No doubt these days there is more science behind it. Presumably train weight and speed determine the weight of rail required and thus the number of sleepers to support train and rail on the ballast bed.
Did you have any particular historical era in mind?Hi, could anyone please tell me, how they determined the spacing between sleepers.
By the category of track, which is determined by equated million gross tonne per annum and line speed, also the curvature of the track plus any cant deficiency.
I believe it ranges from 600mm to 760mm. Most new installs are either 650mm or 700mm.
That does not answer the original question.
As those figures are current not Historic.
How did Brunel, Stephenson et al decide on the spacing originally?
Does it come down to a Horses pace stepping between the sleepers or stone blocks?
In the mid 1960s, when I was a perway engineer, I remember reading the American Association of Railways (AAR) standards for track.I seem to recall the original stone blocks didn't have any cross-ties so just relied on their own weight to stay in position. This would have meant there was nothing for a horse pulling wagons to trip over, but presumably a big risk that the gauge would widen under the forces of heavy locomotives.
There was a discussion on another thread about how some US railroads persisted with 4'9" until well into the 20th century, but it was close enough that it could be standardized piecemeal without having to shut the whole line while the track and stock were converted.In the mid 1960s, when I was a perway engineer, I remember reading the American Association of Railways (AAR) standards for track.
On gauge it said, "for 110mph running gauge shall be 4ft 8.5ins, plus or minus half an inch". In other words anything between 4ft 8ins and 4ft 9ins will do.
Perhaps in 1825 gauge was even less important!![]()
Very simply higher speeds, higher axle loadings and generally higher traffic levels, together with the need for greater restraint on sideways movement (especially for continuous rail on curves) have required a change from 24 sleepers per 60’ to 26 or 28 on many lines.
The spacing between sleepers is a combination of factors, but axle load and rail height (profile) are the two primary factors.
Axle loads in the UK rarely exceed 25t, (unless you work where I do!). Axle loads elsewhere in the world are higher (30t+). In order for the rails not to fatigue (and break) you need to stay below a limiting stress. To reduce this stress you either put the rail supports (sleepers) closer together, or make the rail taller, (or both). Or if you look at it the opposite way to keep the same stress with heavier axle loads you need taller rails and/or sleepers spaced more closely together. That's why tramways only need dinky little rails and freight railways use much bigger ones.
