cactustwirly
Very likely not to be......
Why not that's the usual powercar for NL65?
Nope it was 43316. 43075 is not likely to run with LNER ever again dur to a alternator fault.
Not sure that this is the correct place to post but Northern Rail appear to have hired a LNER HST Set to shuttle between Leeds & Harrogate whilst the UCI World Cycling Championships are on between 21st & 29th September 2019
Just had a quick google- LNER are laying on Azuma’s from Leeds to Harrogate generally leaving Leeds hourly from 11:46- this will give 4tph Leeds- Harrogate
While on Sundays they will leave 2 trains half hour behind one another followed by an hours gap then repeat. Roughly 3tph Leeds to Harrogate
https://www.lner.co.uk/our-destinations/travel-inspiration/uci-road-world-championships/
LNER had better hope Porterbrook are in a good mood if they want to hand it back in that condition.43075 has already gone, due to alternator issues.
To the best of my knowledge, this is when each service converts to different traction. Note not all services will immediately convert to Azuma operation, some will convert to Class 91+Mark 4 operation first.
The following services switched from HST to Azuma operation last week:
1E03 05:26 Stirling - Kings Cross
1A04 06:05 Leeds - Kings Cross
1N81 09:06 Kings Cross - York
1Y84 12:02 York - Kings Cross
1D13 12:03 Kings Cross - Leeds
1A36 14:45 Leeds - Kings Cross
1W22 15:00 Kings Cross - Stirling
1D24 17:33 Kings Cross - Harrogate
The following services have switched from HST to Azuma operation today:
1S01 06:22 Newcastle - Edinburgh
1E07 08:30 Edinburgh - Kings Cross
1W20 14:00 Kings Cross - Aberdeen
1D21 16:03 Kings Cross - Leeds
1A48 18:45 Leeds - Kings Cross
1N35 22:00 Kings Cross - Newcastle
1E11 07:52 Aberdeen - Kings Cross will convert to Azuma operation tomorrow (26th November)
The following services will switch from HST to Azuma operation from 2nd December:
1Y08 05:40 Sunderland - Kings Cross
1W03 07:08 Leeds - Aberdeen
1B81 07:30 Lincoln - Kings Cross
1W11 10:00 Kings Cross - Aberdeen
1E25 14:52 Aberdeen - Kings Cross
1E30 18:18 Aberdeen - Leeds
1N33 20:00 Kings Cross - Sunderland
1D36 23:33 Kings Cross - Leeds
The following services will switch from HST to Azuma operation from 9th December:
1A15 07:34 Harrogate - Kings Cross
1E09 09:30 Edinburgh - Kings Cross
1W96 12:00 Kings Cross - Inverness
1N87 15:06 Kings Cross - York
1S26 17:00 Kings Cross - Edinburgh
1Y90 18:02 York - Kings Cross
1D33 21:33 Kings Cross - Leeds
1E13 07:55 Inverness - Kings Cross will convert to Azuma operation from 10th December
The following services will switch from HST to Azuma operation from 16th December:
1A09 07:15 Leeds - Kings Cross
1E15 09:52 Aberdeen - Kings Cross
1D09 10:03 Kings Cross - Leeds
1A30 12:45 Leeds - Kings Cross
1W24 16:00 Kings Cross - Aberdeen
1B90 19:06 Kings Cross - Lincoln
The following services will switch from HST to Class 91+Mark 4 operation from 16th December:
1E05 07:30 Edinburgh - Kings Cross
1N85 13:06 Kings Cross - York
1Y88 16:03 York - Kings Cross
1S28 18:00 Kings Cross - Edinburgh
The 16th December is the first weekday without the HSTs. The last weekday for the HSTs is the 13th December - not sure whether there will be any HSTs in service that weekend or not.Thanks for the update, Dan. So the 16th is the last day then, with two diagrams?
Thanks - which one is that?Only one Aberdeen - Kings Cross and return are worked by an Azuma at the moment, rest are still HSTs until the end of the week at least.
Thanks, that's very useful.To the best of my knowledge, this is when each service converts to different traction. Note not all services will immediately convert to Azuma operation, some will convert to Class 91+Mark 4 operation first.
Good question! are the Azumas yet cleared for the diversionary route north south via Lincoln? I see some LNER services listed on real time trains passing Lincoln on saturday.Thanks, that's very useful.
I don't suppose you know which diversions via Lincoln are HST this Saturday?
If you try and book a ticket on the lner website on a service (eg P'boro to Doncaster after the diversions eg after 12 noon sat) it tells you - as it usually does - what sort of rolling stock it is - I wonder how reliable this is ref the actual rolling stock then used on the day?Thanks, that's very useful.
I saw a YouTube video a week or so back of a days diversions via Lincoln taken early November. Was mostly HSTs but at least one Azuma, I didn’t watch the whole thing...Good question! are the Azumas yet cleared for the diversionary route north south via Lincoln? I see some LNER services listed on real time trains passing Lincoln on saturday.
using this method looks like an HST north bound of Peterborough at 12.26 and 13.48, not checked other times yet.If you try and book a ticket on the lner website on a service (eg P'boro to Doncaster after the diversions eg after 12 noon sat) it tells you - as it usually does - what sort of rolling stock it is - I wonder how reliable this is ref the actual rolling stock then used on the day?
These don't seem to be showing on booking engines (LNER and National rail site) now. Wonder if that means they have been pulled, or if the sites just tell you to use the bus replacement service because it is (theoretically) quicker than the diverted trains?using this method looks like an HST north bound of Peterborough at 12.26 and 13.48, not checked other times yet.
Some of the other diversions do look like Azumas however.
The trains still show on Real Time Trains, just not listed on the LNER booking engine.
That's what I'm thinking. I'll play about with the settings tho. LNER site still states thru trains at limited frequency.Probably because the RRBs are faster, can you not force it to show slower journeys?
What about setting it to avoid Grantham?That's what I'm thinking. I'll play about with the settings tho. LNER site still states thru trains at limited frequency.
Just posted them above.I don't suppose you know which diversions via Lincoln are HST this Saturday?
Thanks - this list is really helpful!LNER HST workings Saturday 30th November
These workings are correct to the best of my knowledge, and will apply on Saturday 30th November only:
1S01 06:20 Newcastle - Edinburgh
1A13 06:55 Skipton - Kings Cross
1E11 07:52 Aberdeen - Kings Cross (diverted via Lincoln)
1E13 07:55 Inverness - Kings Cross (diverted via Lincoln)
1W96 11:06 Kings Cross - Inverness
1S18 11:35 Kings Cross - Edinburgh (diverted via Lincoln)
1W20 13:00 Kings Cross - Aberdeen (diverted via Lincoln)
1W24 14:35 Kings Cross - Edinburgh (diverted via Lincoln)
1E25 14:52 Aberdeen - Kings Cross (diverted via Lincoln)
1S26 16:00 Kings Cross - Edinburgh (diverted via Lincoln)
1S28 17:00 Kings Cross - Edinburgh (diverted via Lincoln)
1N31 18:00 Kings Cross - Newcastle (diverted via Lincoln)
1E27 18:30 Edinburgh - Newcastle
As usual, on the day problems could result in services being covered by Azumas or 91s, but these are all booked to be HSTs.
Good man!LNER HST workings Saturday 30th November
