73235 is still located at Bournemouth depot.
IIRC it's there for shunting stock.
Despite reports elsewhere, it's recent repaint into all over blue (with yellow warning panels) was carried out prior to First/MTR taking over the franchise
On the 220s and 221s, I think it is intriguing to speculate on what could be done to
a) increase their capacity
b) increase their comfort.
a) Can one easily add another car to these units? In the case of the 221s, would that have to be motorised? Could the electric pantograph bi-mode idea yet be usefully applied?
b) I don't know where to begin here. I have no idea why the toilets could not be replaced with retention kit that doesn't smell. As far as seating is concerned, perhaps only an extra coach would allow a a better seating layout that gave more room throughout and give some grater capacity to compensate for that lost.
Or bi mode 442s
Well there's also the smelliness, the engine noise, the claustrophobic sloping walls and low ceiling, the general plasticky nastiness of the interiors... but apart from all that, they're wonderful!The voyagers and meridians are also fundamentally good trains, despite what this forum seems to think. The only problems are the internal layout (including toilets), and more importantly, the length!
I travelled all the way from Tamworth to Durham and back on a Voyager this week and it was absolutely fine. There is so much nonsense talked about them. The only thing wrong with them is that are not long enough, they should all be 5 carriages long at least. I think they should be cascaded to routes like Cardiff to Nottingham, Birmingham to Stansted and Liverpool to Norwich when they can be.
No good. They are too heavy for the Sprinter differentials so would be slower than the current services.
Hmm, the odd 220 that I see seems to do the same speed as the 170s that are usually on that route...No good. They are too heavy for the Sprinter differentials so would be slower than the current services.
Not so much a question of speed as a question of acceleration; 170s are lighter and quicker off the mark than the 22x fleet, but the problems are only really noticeable on 125mph-capable routes that the 2 classes share (which, IIRC, is only really Brum-Derby).Hmm, the odd 220 that I see seems to do the same speed as the 170s that are usually on that route...
Bear in mind both classes were delivered fully capable of dual voltage conversion.Presumably though when the time comes, dual-voltage EMUs will replace the 444s/450s
By the way, earlier suggestions that they be replaced for 'fleet commonality' purposes in the next franchise are possibly missing the point that they are already effectively a common fleet for maintenance, which consists of 172 units or 733 vehicles. The Aventra fleet in comparison will be a similar size at 750 vehicles, but based and maintained separately at the London end of the network. Why is any commonality needed?
It is only the 442s that will be a relatively small fleet.
Of course, and you'd still have two main fleet types that each still had a critical mass. Swapping out 172 units 20 years early? Has seemed a pretty nonsensical idea since this thread started.And that Microfleet could be dealt with by a bolt on order of 23m Aventras with end doors in the next franchise.
The 444s and 450s will happily continue to run on 3rd rail for the rest of their lifeBear in mind both classes were delivered fully capable of dual voltage conversion.
