RIA letter on Electrification
Grumpy Git
13 Oct 2019
Just stop buggering about and get the wires up.
Its irrelevant what they burn at the power station to produce the electricity then.
The Ham
6 Jul 2012
Indeed, however over time the generation system is getting greener and in the last few years quite a lot quicker than I was thought before looking into it.
twpsaesneg
21 Jul 2009
How did we end up here after all the great BR successes of the 1980s
The original plans for the New Electrification Programme under Network Rail were drawn up by people including experienced ex-BR Wiring Engineers, and called for a rolling programme, similar to that carried out by BR.
Unfortunately, political pressure pushed them down the road of doing everything at once, NWEP, GWEP and MMLE, plus Walsall to Rugeley and GoB.
This inflated wildly the rates for skilled or even semi skilled OLE Design and construction staff which in part led to higher costs than anticipated and a chronic skills shortage meaning that works were maybe not done as well first time as they may have been with skills less thinly spread.
Now we are left with a massive hole in the workload, with many skilled people leaving the industry or going abroad to Australia and Canada.
The Supply Chain has worked with NR to provide accurate costs for newer schemes but the DfT have been reluctant to let more than small packages of work at a time, which isn't providing much confidence for anyone in the industry. In my view the DfT / Minister needs to clearly signal what the intentions are long term. Grayling had his head turned by the magic of bi-Mode and Hydrogen, but a more balanced approach is needed.
My wish list would be to commit to finishing GWEP, so that the core Bristol services and Oxfords could go electric, the MMLE (which has been managed generally well), and then move onto trying to link up some electric islands and cross country routes like Felixstowe to Birmingham.
I also believe that NR should specify a performance spec and then let the supply chain actually build it without changing it - much of the cost increases have come from DfT or NR requested change post contract award, which always costs a lot!
Class 170101
1 Mar 2014
Why, specifically?
Seems too close in proximity terms and have no wish to be blown up should it go wrong on the train.
And yet this is happening in Germany as noted in posts above. So does your thinking mean that
1. You know of risks they don't, or believe their mitigation of risks is inadequate?
2. They have adequately mitigated the risks in ways you don't know, or don't understand?
3. You a simply have a lower tolerance of risk?
Genuinely interested in views on this from anyone who thinks hydrogen is too intrinsically unsafe to be used on the railway.
Possibly point 3 but then you have made points 1 and 2 and mitigation of risks could be believed to be inadequate because I don't understand because I (and others) have not been well informed.
Agree with Grumpy Git totally!
Meerkat
14 Jul 2018
I don't know. Do you?
I can't quite tell from this kind of response whether I am supposed to infer that an H2 train in a tunnel can never be made safe? Or that it has not yet been shown safe, but can/will be? Or that the costs of delivering a safe,hydrogen workable railway make it uneconomic ?
They're 3 quite different positions, which is sort of why I'm asking for the collective wisdom...
A tunnel would seem the highest risk so if the German services don’t have them then that is a major risk to be looked at (rather than just saying “the Germans have them so we can”)
Chris 76
21 Jul 2017
Moseley, Birmingham
anthony263
19 Aug 2008
South Wales
I'd say finish the gwml electrification to Swansea as well as the Maesteg and Ebbw vale branches and to Bristol tm and Oxford. After that do the Midland followed by infills etc
GRALISTAIR
11 Apr 2012
Dalton GA USA & Preston Lancs
And yet she electrified the East Coast Mainline, built the Channel Tunnel, Thameslink and worked to get Crossrail started. It was John Major and Tony Blair who had no love for railways.
plus infills in Merseyside plus quite a bit of Southern region plus London Norwich plus London Kings Lynn plus Carstairs Edinburgh - not too shabby at all.
As others have pointed out, a hydrogen fire is much less dangerous than a diesel fire. In the case of an accident that breaches the fuel tanks, hydrogen won't form pools or soak into upholstering, and will burn off far more quickly than a liquid hydrocarbon would.
About the only thing about them that poses a greater risk is that they burn very cleanly so it can be very hard to see them.
That was likely because there was a BR infrastructure that captured all benefits of electrification and thus would make a convincing case to the Treasury and other actors.
Once the industry fragmented all that went out the window.
klass43
20 Feb 2020
I doubt there are any examples of towns or cities the size of Leicester and Plymouth for example in western Europe which are not on the electric network.
GRALISTAIR
11 Apr 2012
Exactly - privatization was the enemy of electrification not Margaret.
GRALISTAIR
11 Apr 2012
Yes and hopefully climate change, net zero carbon target etc are the exact catalyst we need to make sure all our top 15 cities have some electrification.
klass43
20 Feb 2020
Hydrogen fuel cells are terribly inefficient compared to overhead wires. The only reason it keeps getting put forward is that most H2 is made from natural gas.
A combination of batteries and overhead wires is a much better solution. Batteries are useful for bridging short hops (perhaps 20-30-40 miles) where eletricfication is not economic.
Or where electrification goes through a national park or AONB. I find it ironic that Corby was cut off from the passenger network until fairly recently but is due for electrification, yet many larger towns and cities which have been running passenger services for over a century still remain 'off grid'.
Class 170101
1 Mar 2014
Corby was a simple matter of re-instating the platform rather than the whole line as the line passed through the town anyway and wasn't closed unlike the original station.
Kneedown
29 Dec 2007
Nottinghamshire
But it's a lot harder to get diesel to catch fire than it is hydrogen. You can put a lighted match in a pool of diesel and it won't catch fire. Hydrogen on the other hand... well i'm sure we all remember the experiments in science at school!
And what else do you remember about those experiments? Pop and the fire was gone, away up into the air.
Grumpy Git
13 Oct 2019
I'd suggest there will potentially be several magnitudes more hydrogen to go "pop" if it was going to power a train!
I remember accidentally destroying a small motorbike battery due to a hydrogen explosion and it was certainly more than a "pop".
Yes, there would be. But there's also a lot of diesel to leak all over the place and soak into things if it's enough to power a train.
The point I'm making isn't that hydrogen is 100% safe, just that it is no more dangerous than diesel.
Grumpy Git
13 Oct 2019
As an electrical engineer who has designed "ex" systems for use in explosive atmospheres I completely disagree.
Hydrogen environments require stricter regulations than other flammable gasses (e.g. methane for instance), due to its ability to permeate places where other gasses cannot get.
Rhydgaled
25 Nov 2010
Hydrogen trains are unproven technology despite what certain companies may say and there is no infrastructure for it. Also tell me how hydrogen can be used to pull a 4000 tonne freight train- won’t happen. Electrification is proven technology and provided it is a nice steady rolling program should get better and better and provide really good skilled jobs. Why oh why will the DfT not see it.
Doesn't the iLint mean that it is a proven technology, at least for passenger trains in mainland Europe? Freight and/or UK-gauge passenger stock is of course another matter entirely.
At least with bi-modes in service already on GWR, and shortly to be so on the MML, there will no longer be the pressure of a rolling stock replacement deadline so work can be planned more realistically and there would be more scope to reschedule tasks as expedient. At least some of the bi-modes might eventually be 'de-engined' in the future, once sufficient wiring is in place; the AT300s are designed with easily removable diesel generator rafts that could allow this.
The engine rafts might be easily removed, but cascading class 800s to XC (to replace Voyagers that burn diesel under the wires) would be a better solution in my view. XC will still need diesel for parts of their network for many years to come, but it seems crazy to me to build new diesel engines for XC while scrapping engines from GWR class 800s. You could remove the generator rafts from GWR sets and install them on new XC sets (which would be built without engines) I suppose, but would it be easier to build new EMU vehicles for GWR and cascade the diesel-equiped motor cars from GWR to XC?
I get the emotion behind your comment but it's factually inaccurate. In the 1980s British Rail carried on doing what it had been doing since the 1950s: electrifying major commuter routes and the west and east coast main lines. In the 80s the wires extended out from Essex to the rest of East Anglia, to Norwich and Cambridge. The East Coast main line electrification was approved and started. And please no 'it was on the cheap, headspans useless in the wind etc' comments, we know that and it's been done to death in other forums. Then there was St Pancras to Bedford, and third rail electrification of the core remaining southern diesel routes (Hastings, East Grinstead, Weymouth). And the Ayrshire coast electrification, extending Glasgow's electric network far beyond the Clydeside conurbation.
Imagine if there'd been no BR privatisation and Railtrack in the 1990s. BR would have continued electrifying, perhaps Great Western or Midland main line in the 1990s, the other of those two in the 2000s, Transpennine too, perhaps cross country would have been done by now. We'd be arguing if it was worth electrifying beyond Plymouth rather than beyond Bristol.
While I feel that privatisation was a mistake, I don't think it made much difference to the electrification suituation. Electrification in the UK has been 'boom & bust' since the late 1950s and even in BR days there was a need to get the government to authorise (and presumably pay for) electrification. In 1981 BR wanted a major rolling programme of electrification (the report is available on Railways Archive). Had the full programme been approved, we would not be arguing if it was worth electrifying beyond Plymouth, the line would have already been wired to Penzance by 2003 (or even 1997 in the fast option!). The last element of the programme, Edinburgh - Aberdeen, would have been completed by 2010 at the latest (2001 under the faster option). Interestingly Manchester - Bolton - Preston - Blackpool North was included as part of the baseline as assumed to be electrified regardless of the programme (along with Bedford - St. Pancras and the GEML to Norwich, which obviously did get done). Looking at the various options for smaller electrification programmes included in the report, it is also interesting to note that Birmingham - Derby, Leeds - York and the Midland Main Line (including Sheffield - Leeds) were prioritised above the ECML north of Newcastle.
Decarbonisation will come one way or another, even if the answer is electric buses
That is what I'm afraid of regarding TfW's decsion to order a large number of diesel-only class 197s. At least if they'd ordered bi-modes you could part-electrify routes to cut diesel use down to the sections; which when you factor in the embedded carbon of battery manufacture probably wouldn't look too bad on the carbon balance sheet. A 5-car class 197 lashup burning diesel all the way from Swansea to Manchester on the other hand could put the carbon balance sheet firmly 'in the red', particularly when you factor in increased car use from passengers avoiding the 'interogation centre seats' (Fainsa Sophias) on the 197s.
The difference being energy density. To carry enough hydrogen to give the same range as a tank of diesel fuel would require an extra vehicle to store it. Also the infrastructure isn’t in place at the moment for fuelling hydrogen as it is for diesel fuel so that cost would need to be taken into account.
There are two kinds of energy density. There is energy/mass and energy/volume - I seem to recall seeing a chart somewhere comparing batteries and hydrogen on both these measures but cannot find it now. If I recall correctly, on one of the two energy density measures, one of the two low-carbon options (hydrogen and batteries, I forget which) wasn't far off the energy density of diesel, but neither came close on the other energy density measure.
Aren't there seperate teams doing the GWML and MML? If so, they could both carry on. I'd have the GWML team finish the Oxford and Bristol wires first (to Bristol via both Bristol Parkway and Bath), then do Ebbw Vale, Cardiff-Penarth/Barry Island/Barry-Bridgend and Oxford - Bletchley (the latter while it is closed for east-west rail works), Reading-Basingstoke and Thames Valley branches. Meanwhile, the Welsh Government need to look at speed and massive capacity improvements on the GWML between Cardiff and Bridgend before locking the current inadequate infrustructure in stone by wiring it up. Once the capacity issues between Cardiff and Bridgend are sorted, then electrify Cardiff-Swansea/Maesteg. You could probably leave that for now and come back and do when passing by with Birmingham - Bristol - Plymouth (which, now that we have bi-modes on GWR, is probably higher up the list than Castle Cary-Taunton).
was taught that, to evaluate the danger that something presents, you need to consider the likelihood and the consequence.
Yes, it is easier to start a hydrogen fire (higher likelihood) but that is balanced out by the fact that it's lighter than air and so can't form pools or wick into furnishings (which makes diesel fires, if they get started, have much greater consequences).
So the overall risk is likely pretty much the same.
Grumpy Git
13 Oct 2019
I think you are seriously overlooking the explosion risk associated with hydrogen?
I know where I sooner strike a match, given the choice of a room swimming in diesel or one with hydrogen gas present.
