rishtonlad
- Joined
- 26 Jan 2012
- Messages
- 80
Can anybody give me the best splits for the above trip this Saturday departing after 08:00 and returning after 17:30
Sorry no railcards i need i need to be there for 14:00 not returning before 17:30
Birmingham to Bristol Parkway should be split at Cheltenham Spa.
Birmingham to Cheltenham Off-Peak Day Return £22. (Hideously expensive journey!)
Cheltenham to Bristol Parkway Off-Peak Day Return £8.20
If time permits you can travel via Worcester which will save another £10 or so by splitting there instead. You must be sure to travel via Worcester using this plan though, which will add anywhere from 45 minutes to nearly 3 hours to the journey.
Rishton to Stockport Off-Peak Day Return £15.50 routed via Preston is valid via Crewe - use it as far as there from Preston.
Can somebody confirm that is Rishton to Stockport via Preston is definitely vaild via Preston as the Virgin guard from Preston to Crewe was certain it was not valid.
Crewe to Birmingham Off-Peak Return £11.75 if booked in the London Midland online sale.
Should save you a few bob.
If going to Bristol Rovers, Filton Abbey Wood is marginally nearer the ground.
I can find no evidence that a ticket from Rishton to Stockport is valid via Preston. However, if the ticket states that it is routed "Via Preston", we are getting into awkward territory - and said ticket definitely does exist.
Bit late now...
Probably not. No-one has yet devised a system to calculate the "best" splits, although people are working on it, it may never happen given that "best" is highly subjective (e.g. if you save 10p but the journey takes 30 mins longer, is that better? what if you saved £1 for 10 minutes longer?).Can anybody give me the best splits for the above trip this Saturday departing after 08:00 and returning after 17:30
Preston is not a permitted route, but there is a Route via Preston fare available.Can somebody confirm that is Rishton to Stockport via Preston is definitely vaild via Preston as the Virgin guard from Preston to Crewe was certain it was not valid.
Welcome to the forum rishtonlad
However, for future reference, if you can tell us what you've found so far, and what sort of itinerary you had in mind, then we can work with you and may be able to provide some suggestions for improvements.
(By the way, the "Title" field is only for use when posting a new thread, it's not needed for subsequent replies, and anything you enter there cannot be read by all users of the forum)
If you use a ticket routed "Any Permitted" then you should be charged a change of route excess fare. If using an Off Peak Day Return the excess fare would cost £1.60 (both directions) or 80p (one direction only).
A ticket routed via Preston is valid via Preston, yes.The ticket is valid via Preston but you need to ask the guard to issue it via Preston.
The fact that Preston is not a permitted route is the reason for the existence of this ticket.Please could someone fill me in: how can there be a ticket via Preston when Preston is not a permitted route?
Yes.Can TOCs offer routes above and beyond those in the Routeing Guide at a higher fare than the Any Permitted fare?
