Round versus Oval Buffers
MrEd
13 Jan 2019
I’ve been thinking about this today- what advantages do oval buffers on locomotives have over round ones, or vice versa? All the Class 37s were originally fitted with round buffers but we’re progressively retro-fitted with oval ones in the 70s and 80s (all the refurbished 37s had oval buffers fitted, while most of the non-refurbished 37/0s and 37/3s were also fitted; only a few of these ended their days with round buffers). I seem to think a few 47s used on freight workings were also fitted with oval buffers in the 90s. What was the reason for this?
Interestingly the pilot-scheme Class 26s all had oval buffers, the production examples round. What was the reason for this?
Speed43125
20 Jul 2019
Dunblane
I would hazard a guess it has something to do with the risks of buffer-locking in shunting moves, which having a wider buffer (ie. oval) presumably can help mitigate. Class 68s seem to have almost rectangular buffers for example.
XAM2175
8 Jun 2016
Yes, wide rectangular buffers has been the standard on the continent for some time now - the series 152 locomotives as shown below entered service in 1996:
(Image shows DB locomotive 152029-5 fitted with rectangular buffers. By Rolf Heinrich, via Wikimedia Commons.)
Aren’t most frame mounted, so presumably depends upon length of the frame and how near the ends the bogie pivot points are. The other important consideration must be minimum curve radius as the buffers need to be wide enough to ensure don’t lock on curves.
Historically I think they tended to be round because they have slight dome rather than flat surface and was easier to machine the face if you could turn it on a big lathe
Doomotron
25 Jun 2018
Kent
I believe the round buffers are meant for working with carriages, as the Class 91's blunt end had them, while the front had oval buffers
DB
Guest
18 Nov 2009
Think those rotate and retract? Same as the GA 90s had.
jopsuk
13 May 2008
the sources I've seen are that both ends on the 91 had retractable buffers- with the squared off ones on the front being "vertical" when retracted
43096
23 Nov 2015
If they have drop-head buckeye couplers then they will be retractable - they have to be.
