Route LM&XC ticket London To Sheffield
Discussion in 'Fares Advice & Policy' started by hkstudent, 7 Oct 2019.
  1. hkstudent
    hkstudent Member
    159
    11 Nov 2018
    May I know if the LM&XC ticket still valid to go via Birmingham or I need to stick to interchange at Tamworth?
    I have checked that there are no provision of West Coast route in the routing guide
    Rail Forums
  3. JB_B
    JB_B Member
    746
    27 Dec 2013
    Route 00370 has mandatory via points Nuneaton and Tamworth which you must pass through.
    (And, obviously, requires you to use LNR(LM) and XC services only.)
    I think you can split the routeing at either or both via points (as long as your journey passes through both). So you could also look at combinations of permitted routes to/from your via points.
    London->Sheffield (which has no routes via WCML as you've found.)
    London->Nuneaton->Sheffield.
    London->Tamworth->Sheffield.
    London->Tamworth->Nuneaton->Sheffield.
    London->Nuneaton->Tamworth->Sheffield.
    So, e.g, London-Tamworth via Nuneaton and Birmingham (on Map TV+WM) then Tamworth-Sheffield (Map BY) should be OK.
  4. lyndhurst25
    lyndhurst25 Member
    961
    26 Nov 2010
  5. Hadders
    Hadders Established Member
    6,476
    27 Apr 2011
  6. pdeaves
    pdeaves Established Member
    2,440
    14 Sep 2014
    Gateway to the South West
    Would that not fall foul of doubling back?
  7. AnkleBoots
    AnkleBoots Member
    354
    8 Jan 2017
  8. JB_B
    JB_B Member
    746
    27 Dec 2013
    I don't think it necessarily would, no. ( I'm happy to be corrected if I have this wrong. )
    My understanding is that you evaluate validity separately for each leg ( from origin to via point (to via point..) to destination ).
  9. Sniffingmoose
    Sniffingmoose Member
    25
    13 Feb 2016
    Burton on Trent
    I use the LM&XC ticket regularly from Burton on Trent because of the low walkup price. Its a great ticket but I can confirm that you must change at Tamworth for the hourly London Northwestern to London. Unfortunatly there are some poor connections at Tamworth if you come back from London in the evening. Not sure if you can go via Birmingham if the hourly London Northwestern Crewe Train is cancelled. I have heard the ticket is available from Derby but I did not realise it was available from Sheffield.
  10. Hadders
    6,476
    27 Apr 2011
    That's correct if the ticket is geographically routed (e.g. Via Tamworth) but this ticket isn't geographically routed. It's TOC restricted to XC & WMT trains only.
  11. JB_B
    JB_B Member
    746
    27 Dec 2013
    Certainly it's restricted to those TOCs but I believe that behind the scenes there are also mandatory via points : Tamworth and Nuneaton (although I don't think there's any way for the general public to know that.) Given that there are no direct permitted routes from London to Sheffield that are doable using just those TOCs only, I think journey planners are quite likely to be using the split routeing.
  12. yorkie
    yorkie Administrator Staff Member Administrator
    43,712
    The split route check would only apply if the ticket was geographically routed.
    My understanding is that these hidden mandatory via points are not treated in the same way; they are just conditions of the fare being considered valid.
  13. Indigo2
    Indigo2 Established Member
    3,476
    16 Apr 2010
    Reading
    I think it is covered by Easement 30052, which says Journeys via Tamworth and Birmingham New Street may double back through Water Orton. This easement applies in both directions.
  14. JB_B
    JB_B Member
    746
    27 Dec 2013
    OK - thanks - always something new to learn!
    I'm going to have to go back and check how that distinction is coded in the data.
  15. Indigo2
    3,476
    16 Apr 2010
    Reading
    Journey planners and booking engines have no way of knowing if the via points are hidden or not! They appear the same in the data. I don't think they affect the validity of the fare, but they might allow you to get a journey planner to produce an itinerary over a route that arguably isn't valid, which could sometimes be useful...
  16. JB_B
    JB_B Member
    746
    27 Dec 2013
    I was fairly sure that was the case. So even though, as @yorkie implies, journeys based on split routeing at (non public) via points might not be in the spirit of the public facing RG, correctly implemented journey planners should still validate them?
    I think that the OP's intended journey via Birmingham would depend on this, or is there another easement?
    Yes, that's a potential advantage. I guess a downside is that non-public exclude points on some routes are more of a problem - members of the public won't be able to get an itinerary but won't have any way of knowing why not.
  17. hkstudent
    hkstudent Member
    159
    11 Nov 2018
    Indeed, fare data are too hidden from the general public, which is not a good idea.
    I have checked all the possible connections, and find out that via Tamworth would get me to Sheffield faster.
    Meanwhile, I notice that the journey planner didn't offer 1556 / 1446 departure as super off-peak fares despite they are before 1600. (possibly because of Tamworth journey starts after 1600?)
  18. yorkie
    43,712
    The contractual position is that the ticket is valid, as per:
    However booking sites are not allowed to sell the ticket, due to the following hidden electronic restrictions:
    This results in the following, which are breaches of competition and consumer laws:
    • Customers who book online are overcharged (if they do not realise)
    • Online retailers miss out on sales (if the customers do realise)
    I've said it before, so apologies for saying it again, but the rail industry is skating on thin ice, due to multiple breaches of relevant laws. This is just one example out of too many to count.
  19. AnkleBoots
    AnkleBoots Member
    354
    8 Jan 2017
    In what way do these differ?
  20. tony_mac
    tony_mac Established Member
    3,593
    25 Feb 2009
    A connecting service can be used to complete a journey begun at a valid time.
  21. hkstudent
    hkstudent Member
    159
    11 Nov 2018
    Who can be contacted for rectifying the glitch in the ticketing system?
    Of course, since it is not an advance ticket, what I need to do is to call Crosscountry for changing seat reservation anyway.
  22. tony_mac
    3,593
    25 Feb 2009
    There isn't much that can be done about it - the data formats don't support that type of rule. This has been a known problem for at least the last 10 years, and has been brought up on here regularly during that time.
    If they get pushed into doing anything then I suspect that the most likely result will be that the restriction will be amended to no longer allow connections.
  23. AnkleBoots
    AnkleBoots Member
    354
    8 Jan 2017
    Can it not be changed to
    Not valid to depart origin 1600–1718 on any TOC
    Not valid to depart origin 1720–1859 on any TOC
  24. yorkie
    43,712
    It can be encoded with a list of stations or it can be encoded to apply from any station.
    There is no concept of "origin" as such.
  25. hkstudent
    hkstudent Member
    159
    11 Nov 2018
    And to confirm, would I be possible to break the journey at Birmingham New Street? Would it be very likely that I may need to have a argue with staff?
    It would be best if taking reference to Southwestern's setting, for departure time from Waterloo / Vauxhall / Clapham Junction
  26. yorkie
    43,712
    It is not permitted on the outward portion. It is on the return.
    It is not very likely you would need to argue; there are no staff at the station exits and you are permitted to access any facilities within station premises (which are very expensive at BHM!), however we cannot condone the braking of this rule, even though it's ridiculous and unenforceable.
  27. hkstudent
    hkstudent Member
    159
    11 Nov 2018
    Yeah, what I am thinking of is, to break the journey (for dinner out of station) at Birmingham on return journey to London.
  28. yorkie
    43,712
    That's fine :)
  29. Bletchleyite
    Bletchleyite Veteran Member
    42,152
    Up and down the south WCML (mostly)
    The way to fix it is to have different codes for different stations specifying the relevant origin. They're too lazy, though.
  30. hkstudent
    hkstudent Member
    159
    11 Nov 2018
    Would the XC service from Birmingham New Street to Coventry (and change for LM from there) be also valid?
  31. AnkleBoots
    AnkleBoots Member
    354
    8 Jan 2017
    I checked this ticket on the excellent trainsplit site but even they struggle to show it for the correct times!
Share This Page
