Routing question Cambridge into London
jsm24601
15 Sep 2021
Cambridge
Hi all, I've recently restarted my commute and am now travelling into Stratford from Cambridge. I am aware I have two main/timely routes - Cam to King's Cross, and then using oyster on HS1 to Stratford international; and via Tottenham Hale on the Liverpool Street line, into Stratford Station.
I wanted to ask if a anytime day return to London terminals is valid on the second route - as the Tottenham Hale to Stratford train terminates at Stratford, and it isn't considered a terminus? I probably intend to buy a return in this way to give me the two options if possible.
Thanks for any insight!
Yes it is. You are only just over 2 miles off the direct route into Liverpool St, and you can break your journey on an anytime ticket.
A quick way to check routes (with flexible tickets) is to put a Via point into a journey planner (Stratford in this case!) and check that it will still show your fare that way.
(PS you can't, of course, use the ticket to do CBG-LST-SRA (=Stratford) and return the same way!)
jsm24601
15 Sep 2021
Cambridge
Perfect answer, thank you!
