OwlMan
Copied from ATOC website
RSP currently has several types of data available for use as set out below.
■Fares Data
■Timetable Data
■Routeing Guide Data
■Retail Control Service (RCS)
Fares, Timetable and Routeing Guide Data is provided through the Rail Journey Information Service (RJIS). Retail Control Data is provided as an FTP feed over the internet from the Retail Control Service.
Fares Data
Fares data consists of fares information relating to permanent fares offered by Train Operating Companies. The data will typically included general fares information such as price, validity, class of travel and restriction information.
Details of the structure and content of the fares data can be found in the RSP Data Feeds Interface Specification for Fares and Associated Data document.
Timetable Data
Timetable data consists of Timetable information for the train services provided by each of the British franchised train operating companies. The data will include general timetable information such as departure and arrival times for all stations (e.g. origin, intermediate and terminating) at which a train calls on its journey. Certain other information relating to the train journey will also be included such as class of accommodation, days of operation and other information unique to the train service.
Details of the structure and content of the timetable data can be found in the RSP Data Feeds Interface Specification for Timetable Information document.
The timetable data supplied as part of the RSP timetable data feed is sourced from Network Rail's Train Services Database (TSDB) in Common Interface Format (CIF) and is filtered to exclude non-passenger train services. Details of the structure and content of the data in CIF can be found in Network Rail's CIF End User Specification Document.
Routeing Guide Data
Routeing data is created by Rail Settlement Plan from the routeing information used to specify route validity for certain fares and prescribe passenger journey route options.
Details of the structure and content of the routeing data can be found in the RSP Data Feeds Interface Specification for Routeing Guide Data document.
RSP Data Feeds Interface Specification for Routeing Guide Data document at
http://www.atoc.org/rsp/_downloads/RJIS/sp0037.pdf
Has anyone seen this data?
AS a database engineer I would to have a look.
Unfortunately their small charge is not small to me (see below)
Having viewed the RSP Data web pages, you may now wish to try out RSP Data on a trial basis. Retail Control Data examples can be found below. For other data, RSP can supply trial feeds in CD-ROM format. You may then test the RSP Data for compatibility with your systems. A small charge of £200.00 per CD-ROM for each type of RSP Data will be applicable. Please note that the Additional Data Feed is supplied on request and without charge if you use either the RSP fares or timetable data.
Peter
■Fares Data
■Timetable Data
Fares Data
Timetable Data
Routeing Guide Data
Peter
