S Stock Speed measurement & Met Line speed upgrade
pethadine82
16 Jun 2012
It is possible with a software upgrade that S stock can measure speeds in mph rather than kph?
Do LU have any plans to increase the line speed on the fringes of the met line?
Simon11
7 Nov 2010
It is possible with a software upgrade that S stock can achieve speeds of mph.
Do LU have any plans to increase the line speed on the fringes of the met line.
The new stock train top speed is actually lower than the a stock.
However the s stock has quicker acceleration, so journey times should come down! However it will only be used to the full effect once the a stocks are gone.
Jonny
10 Feb 2011
Tyne and Wear Metro has always been metric - and even uses NwR tracks Pelaw (just east of) - Sunderland - South Hylton.
It needed to use hexagonal speed boards though when it combined with Railtrack (as was, now NwR), LUL could easily do the same, need not be a direct translation.
Daniel
5 Oct 2005
I'm confused. I'm pretty sure the speedometer on the S stocks are in mph?
jopsuk
13 May 2008
Speed limit boards on the fringes of HS1 where it interfaces with NR infrastucture include in km/h signs- white on black.
notadriver
1 Oct 2010
I thought it was a signalling constraint. I hope it isn't. The northern line 1995 stock is the same speed despite the older trains having long since disappeared.
WinterChief
11 Jun 2011
S and 09 Stock can modified from mph to kph (and vice versa) with the click of a button via software update. They are currently in mph.
Line speed will go up in some places.
