Ben Glasgow
This is what happened. After station duties were completed the driver was undertaking a "pan drill/battery reset" (basically a reboot/switch off and on again) as a result of spurious faults on the train, very common on 334's. This is why there were reports of a "power outage." For some reason (and which is the focus of the investigation) the units detached themselves during this process. As a result the front unit rebooted as expected so the driver continued unaware, leaving the rear unit detached and dead in the platform.
Out of curiosity, what sort of ratio do modern trains run via software versus direct user input via switches etc which bypass any sort of onboard software or TMS System? With how you’ve described it (also thanks as I’m genuinely fascinated how this happened) do you reckon that in doing a reboot of the system, it’s then cycled the coupling mechanisms?
Because the uncouple button was pressed
As others have mentioned, this doesn’t seem very likely but would suggest that it would have to be knowingly done by crew who’d have been able to energise the rear cab which again seems very bizarre and unlikely.
Yes, this is the big problem in this case. After 5 days of investigating, they have so far not been able to recreate the fault. The question I'd now be asking if I was still involved in engineering and not a train driver is "do we think it will or could happen again? and if we do, what will we do?". The company will have to either ground the entire 334 fleet until such time as they find the cause OR immediately ban 334 units from operating in multiple OR come up with a solution that completely isolates the couple/uncouple circuit, thus allowing them to keep multiple units already coupled in service. Its a tough decision to make, especially if grounding an entire fleet of 40 units has to be done. This could seriously harm the December timetable change.
I reckon they will have to change the procedure so that should a 3+3 consist show abnormalities requiring a reboot of the train, the driver will have to inspect the connection between the two trains. Is this reasonable to ask of a driver?
