Maybe Inverness depot is where they are accepted into traffic?
There is a sheer lack of clarity from Scotrail, the Scottish Government and Network Rail. No wonder why so many folk are disappointed in the service!
They use the egress handle to release a door and reset it afterwards.Interesting, thanks. I've definitely seen Scotrail guards stepping out the local door to check first (and I know at Dalwhinnie and possibly a few other stations that it's local door only, usually the one next to the disabled toilet) so they must just be using the non official way?
Did. Just servicing of the sleepers at Inverness now; maintenance is by Alstom at Polmadie. That said, Inverness is nominally home depot for the ScotRail trailer cars.Inverness does maintain the Sleepers though, so I imagine any serious maintenance could be done there assuming that's what you mean?
Have to say I am utterly astonished that is an accepted working practice.Maybe I shouldn't be, but I'm slightly surprised they are allowed to do that.
Why ?Not just me then.
Why ?
The fact that it is the Scotrail Official and accepted method should be an answer. I am sure a TOC has more knowledge than an outsiderWell surely using an emergency egress handle to release a local door to check the platform is clear, before resetting the egress and releasing the doors is not an ideal process?
Surely an emergency egress release should only be used in emergency?
A TOC that frankly has zero HST experience and a practice that is not used on any other HST operator.The fact that it is the Scotrail Official and accepted method should be an answer. I am sure a TOC has more knowledge than an outsider
It switched when Serco took over.Did they switch to Polmadie when Serco took over or simply with the change to Mk5 stock?
If it's nominally home for the trailers, is that purely a registration thing then?
The plan for ScotRail HST maintenance was power cars at Haymarket and trailers at Inverness and depot allocations reflect that.
Seems like a bodge-it solution though.
Of course it is but options were rather limited.
Don’t need to if they use the TGS van doors for dispatch. And if they do need to use another door, just open the window to see where you are rather than using emergency equipment for a purpose it is not intended for and doing a 10sec mince around the platform.Was there no ability to fit a 'proper' local door release?
This isn't a local door operation as such it is for single door at short platforms so rarely used.
And what is your operational experience?A TOC that frankly has zero HST experience and a practice that is not used on any other HST operator.
Similar to the practice of parking them with the batteries off then doing cold starts all the time then?Seems like a bodge-it solution though.
Did anyone at ScotRail actually bother to study best practice at the other HST TOCs or has it just been “we know best” ?
The training train isn't (or it wasn't tbe ladt time I was on it anyway), we have authority to 'cold start' if required - it's stabled with both engines shut down & power car batteries isolated (to avoid them discharging & failing to start the engine).
Sets for passenger service ARE stabled with 1 engine running, supplying ETS to the coaches & the other power car (in the station anyway - I'm not 100% sure about the set that is stabled overnight at Inverness for the 0554 Aberdeen, although this hasn't ran as an HST very often anyway, I don't think).
The message above is from this thread in January this year, things may have changed since I guess. As I understand it, the 1 power car running is in stations only, not depots or places like Dundee yard though, like I say, things might have changed.I thought they were parking them with one power car running to avoid cold starts?
Edit- they also might have got shore supplies put in at the stabling points by now as well
