ScotRail HST Introduction - Updates & Discussion
hexagon789
2 Sep 2016
I really hope not. National Express did that in 1997 and it was terrible. One of the first things First group did was bring it back in house. It made a big difference.
Hadn't realised NatEx outsourced catering, but then I can't really recall NatEx days.
Certainly I never had any complaints about catering under First as such, for a trolley service it was fine, but I do think progressing to enhanced catering with a buffet was the right step to make.
So long as a reliable catering service can be assured, does it matter if it's provided in-house or not really?
route101
16 May 2010
Actually think the Scotrail trolley selection is pretty good , has different and local stuff .
hexagon789
2 Sep 2016
Certainly the variety at present is, indeed good for a trolley service, but the buffet can stock more and theoretically offer a greater variety.
Mitchell Hurd
28 Oct 2017
Not compared to a 4+2 HST, that's for sure! The difference between a Class 170 (and, even more so, a Class 158) in acceleration is quite an eye-opener. I drove a 4+2 HST north from Perth a few weeks ago, with a sick leading power car (basically the engine was running, but supplying zero traction power - effectively a 4+1, along with a dead power car) was roughly comparable to a Class 170 running at full power!
Sorry, I know this is an EMT HST question but when I videoed NL65 come into Leeds around 13:15 on the 05/04/19, the rear power car was running at the lower rev (like the leading power car normally is when calling at stations). I was in Coach M on this service to Kings Cross. Performed fine all the way there.
What causes the rear power car of any HST to arrive with the engine running at the lower rev and then perform fine for a 2 - 2 hour 30 minute trip?
hexagon789
2 Sep 2016
Normally the rear power car provides the Electric Train Supply for the on-board power such as heating, air-con, lighting etc. This is why the rear power car idles at 1,000rpm (equivalent of Notch 2), against 750rpm for the leading one.
If indeed the rear power car was idling at 750, then the front one must have been providing ETS, presumably due to a fault with the rear one that meant it couldn't.
Mitchell Hurd
28 Oct 2017
That's another big improvement of HST's over 170's - when on layover, staff can work in room temperature conditions (if the air-conditioning is working) when one power car is off and the other is running to provide your hotel needs basically.
With a DMU or bi-mode MU when in diesel mode, you can't do that as the whole train is shut down - depending on the layover times of course.
InvHst
9 Dec 2018
Can I ask anyone who has any idea what services on a Sunday are hsts from either Edinburgh or Glasgow since realtime trains isn't showing a true number and I'm interested as travelling north next week
InvHst
9 Dec 2018
Sorry meant to say to Inverness
hexagon789
2 Sep 2016
I can imagine the staff very much prefer that in the winter! ;)
scotraildriver
15 Jun 2009
It was considerably more expensive when a private company ran it. The current prices aren't too bad at all.
hexagon789
2 Sep 2016
In an HST - easily (in both directions, you can actually easily coast at 100mph, once you get there)! In a 170 - about 97mph (Southbound) is the best I've managed, North bound, it's hard to get much over 90 mph
That says a lot about HSTs and a lot about 170s! :rolleyes::lol:
Be very interesting to see when they finally tighten up timings just what they are capable of.
w1bbl3
6 Mar 2011
But are they the only firm capable of the work ?.
For another refurbishment company to offer sliding door mods they'd need to design the modification in terms of how to fit the door into the carriage end, which is the difficult bit of the process. The actual door mechanism is something that could be purchased from a number of different suppliers of which a Wabtec subsidiary is one.
The Chiltern plug door mod programme (by Wabtec Doncaster) took the approach of cut end off above the sole bar and fabricate a new end, very time consuming and expensive as each mk3 coach is slightly different.
The Wabtec Doncaster sliding door mod was designed to avoid the time/complexity of remaking the coach end by offering a door that could be fitted into the existing aperture.
I'd suspect that the truth is the coaches are just too far gone age and corrosion wise the for door modification to be practical at the scale and time envisaged. Considering how badly the programme is going for Wabtec who are not inexperienced at rail vehicle modification I can't see another refurbisher wanting the work unless the price is very attractive.
pt_mad
26 Sep 2011
I'm surprised they didn't just go with some sort of air release unlock button fitted to the existing slam doors. Like the air release door catch within the class 230 vivarail train, between the coaches. The door slams shut, but an air release button releases the doors from its catch and the door can then be pulled open.
Would that have been PRM compliant? Maybe not?
hexagon789
2 Sep 2016
I think it has to be a sliding door, but I think they theoretically only had to fit such doirs yo it to the entryway used for wheelchair access to the area designated for wheelchairs.
hexagon789
2 Sep 2016
Actually it's interesting how firstly the prices are pretty reasonable for the most part and secondly how much greater choice there is - I sincerely hope the buffets are retained and if the catering does ultimately get outsourced that the choice is still there.
pt_mad
26 Sep 2011
You should try Caledonian Macbrayne. You can get a meal for about 8 quid or a huge jacket potato, filling and a big salad for around 6 quid. It's like a restaurant car without the price!
RLBH
17 May 2018
If the buffets are abandoned, it'll undermine ScotRail quite significantly. Not so much for the absence of the buffet, but for promising it as part of a 'genuine intercity experience' then not following through. And the buffet counters in the refurbished sets will remain in place as a very visible reminder of that broken promise.
It would be interesting to know the economics of CalMac catering - I'd expect it to encounter a lot of the same issues as rail catering. Including the space constraints; ships are bigger than trains, but that space gets eaten up surprisingly quickly.
Of course, it doesn't tend to be full and standing across the Minch.
Mingulay
5 Mar 2018
I was driving up the A9 last week and glanced over to see a 2 car 158 Rammed full! Really felt for them. Brutal way to travel a long distance. Not sure what would be worse. Standing or crammed into the inadequate leg room at a table post refurb. Standing is the better option
Regardless. That is a pitiful effort by Scotrail for an Inverness service. Amazed the local politicians are not all over this grilling the transport minister. St the very least a 4 car 158 even if meant cancelling services in the borders . Longer service trumps the shorter ones
Heaven only knows what tourists think.
