No idea. This is all I could find on here: https://wiki.openraildata.com/index.php/Delay_Attribution_GuideAnd what on earth does that mean?
Cancelled due to train fault.
now in for Tuesday
I notice that this time they are using the emptiness of the network to run more or less nonstop from Doncaster to Millerhill, and pathed for 125mph.
Puzzled why they then send it via the Sub, which means multiple reversals at Haymarket to access the depot. Only once has it been routed through Waverley.
I thought they were restricted to 100mph as 2+4. Or is the pathing on RTT not reflective of their actual speed limit?I notice that this time they are using the emptiness of the network to run more or less nonstop from Doncaster to Millerhill, and pathed for 125mph.
Those limits existed in the very early days of the HST, but modifications have long since been made to the braking and even 2 + 1 ould be permitted at 125I thought they were restricted to 100mph as 2+4. Or is the pathing on RTT not reflective of their actual speed limit?
Do you happen to know the former number of 40621?Only 1 reversal at Haymarket platform 0. The formation is:
43183-42277-42300-42299-40621-43035
41146Do you happen to know the former number of 40621?
I'm pretty sure it's 16 sets now, so pretty good progress really considering things.My bad, forgetting that there are crossovers allowing a train to cross over all four tracks there.
How many sets is that now 16 or 17?
The fleet was quoted as 121 vehicles - 17 x 5-car and 9 x 4-car.If so, and taking into account the 25 extra coaches to be delivered later, then Wabtec have finally passed halfway! (64 v 125)
I’m aware this had been discussed. Has this been confirmed by an official source?Believe there is some confusion out there. It may or may not have been stated that the entire fleet will receive another carriage - this may have confused some.
I don't believe so. Though whoever first mentioned it was very convincing with their unofficial source on the matter.I’m aware this had been discussed. Has this been confirmed by an official source?
If it was the entire fleet, presumably that would result in 17 x 6 car and 9 x 5 car?Believe there is some confusion out there. It may or may not have been stated that the entire fleet will receive another carriage - this may have confused some.
As delivered, every set will have 4 carriages (possible exception of the final set), then additional carriages (possibly TGS for bike storage) will be added, as spec'd, that would be an additional 17 carriages to be delivered to lengthen 17 sets, this proposal would be for 26 additional carriages creating a uniform fleet of 2 + 5.If it was the entire fleet, presumably that would result in 17 x 6 car and 9 x 5 car?
I'm more of the opinion that it was all the 4 cars to receive an extra car which would result in a uniform fleet of 26 x 5 car.
Thanks for the clarification....an additional 17 carriages to be delivered to lengthen 17 sets, this proposal would be for 26 additional carriages creating a uniform fleet of 2 + 5.
That sounds as if it would make planning easier.Thanks for the clarification.
That should aid the folk at the coal face with not having to worry quite as much about which set goes where, especially during times of disruption.
The sets were to be rotated around based on demand, rather than rigidly fixed lengths on each route - though Aberdeen to Edinburgh are/would be having most of the 2 + 5s.That sounds as if it would make planning easier.
Can someone refresh my memory? I had it in mind from somewhere that services between Inverness and Aberdeen would be 2+4 sets to suit platform lengths. What's the capacity of the new station at Kintore?
Perhaps I'm wrong. But this is a long thread to trawl though to check, so apologies if going back to anything said earlier.
The previously used Slateford depot is currently being cleared for re use as an HST stabling point. Not sure if the HA31 - 33 will move here too to be stripped, but it will reduce pressure on Haymarket depot which has had to close to any more trains on a few occasions recently due to being full. This has caused some congestion in Waverley as trains cannot move to the depot. I wonder how the local NIMBYS will react, given the relentless moaning they did last time Slateford was in use.
Anyone know what this movement from Haymarket to Wabtec is ?
Realtime Trains - 005H 1106 Haymarket Depot to Doncaster Works Wabtec
Realtime Trains provides live realtime running information for the Great British railway network using open data.www.realtimetrains.co.uk
