ScotRail HST Introduction - Updates & Discussion
kkong
8 Sep 2008
A ScotRail presentation to Tactran in Sep 2018 says that from Dec 2018 the plan was...
HST will operate 48 out of 99 intercity services:
  • 4 out of 22 Aberdeen – Inverness
  • 6 out of 22 Inverness – Edinburgh & Glasgow
  • 19 out of 24 Aberdeen – Edinburgh
  • 19 out of 31 Aberdeen – Glasgow
and from Dec 2019:
  • Most intercity services formed of High Speed Trains
PG
Given that ScotRail had only received the first completed set in September 2018 (so knew that things weren't going to plan) did they preface the presentation with 'Once upon a time' and conclude it with 'and they all lived happily ever after' !!??
Not strictly true, as there needs to be DMU operated passenger runs between Perth-Inverness and Montrose-Arbroath to rotate the 170s and 158s to the central belt without the need to run more empties.
While I can see that running empty Perth-Inverness is too far and a waste of limited single line capacity, Montrose-Arbroath is (just under) 14 miles.
I'd have thought it wouldn't be that difficult to find a path and adjust a few diagrams to enable a set swap that way instead of using a DMU vice a HST on the whole route?
I'm not sure if there are any Dundee/Arbroath terminators that could get to Montrose in time to form a Montrose-Aberdeen service (and vice versa) so it might be easier to just timetable it as Central Belt/Aberdeen.
47827
3 Mar 2020
Middleport
There's a small number of early morning or late evening services that don't run south of Dundee or Perth on the Aberdeen route too that can remain units to allow swap over of 158s for the far north and Grampian/East Coast locals. As I recall in a similar conversation about the 05xx from Perth and 20xx ex Inverness southbound these sorts of trains can be left as they are with no likelihood of uproar about the lack of Intercity experience on board. 2 or 3 158s can form the services if needs be, or a single 158 to suit what needs moving for maintenance or fleet rotation purposes. I know one ECS hst goes to Perth overnight ex Glasgow due to depot capacity only (?) but the other terminators late at night and early morning starters are all currently dmu operated too from the likes of Perth and Dundee with no passenger hst sets stabling at these locations on a normal night so much better not having to run Highland Mainline dmu ECS moves to swap 158s around off the Far North routes or similar on the Aberdeen circuits. Waste of drivers and money when the off peak early/late services are perfectly good for that.
Clansman
4 Jan 2016
Hong Kong
I admit I'd forgotten about that requirement, though I remember you mentioning it previously now. So at least one Inverness and one Aberdeen-Central Belt service each way will still be DMU then?
Indeed. So long as there are no additional empties penned in then it is essential that passenger services accomodate these rotations. The pre-covid planned timetable enhancements are impossible to maintain without them.
Strictly speaking, you don't need any additonal empties to rotate the DMU fleet and still maintain a full HST frequency on all end-to-end services between Aberdeen/Inverness and Glasgow/Edinburgh.
The key lies in 'end-to-end', and the following services have already been acting as de-facto (whilst not exclusively) rotationary movements for years, without disrupting the usual intercity formations:
1H01 Perth to Inverurie
1A43 Perth to Inverness
1L32 Aberdeen to Perth (terminates at Dundee on Saturdays)
1H25 Dundee to Inverness (starts at Montrose on Saturdays)
Allows up to 12 individual 158s, and 8 individual 170s to rotate daily Monday-Saturday. In my experience these almost always turn up as double 158s or 170+158 combos.
It's also worth noting 1A46 - Inverness to Stonehaven (weekdays only) - it's an ex-Elgin so will certainly serve the same purpose post full HST pre-covid timetable.
More than enough to sustain the rotations required without the logistical hassle of penning in more empties.
The size of Perth and Dundee's accomodation for stabling has always proved to be a blessing for planners, especially now with the HSTs and 385s thrown into the mix.
Edit: 47827 beat me to it!
hexagon789
2 Sep 2016
So we are taking about the early morning non end-to-end working then?
Because that's actually what I meant earlier, just I didn't really convey that clearly, that the full distance services would be HST and the early morning/late night services short 'commuter' workings would be used to transfer units on and off certain routes such as the Aberdeen Crossrail and so forth
47827
3 Mar 2020
Middleport
Those services, for sure (although the last working from Inverness southbound does go South of Perth). Whether any others need to be added in would depend on hst availability/reliability, perhaps, and the fallout of the lost set from the summer derailment, which may not be replaced for a good while and potentially not with a hst if there were a pair of units that could be taken more quickly for instance. For those reasons it's possible at least one set of daytime services on either route will remain dmu operated, even if that wasn't the original intention. There are probably a few daytime workings on all 4 hst routes that are more lightly used and could get away without a hst capacity/facilities. Which route is chosen though remains to be seen. That also doesn't stop the common sight of at least 1 daily hst diagram being covered by a unit every day, which would vary depending on where the hst failure/shortfall was. In fact you can see days with 2 or 3 hst diagrams being fully covered by units. That wasn't rare in some fleets right across the decades in previous fleets (albeit in BR days up until the early 2000s loco hauled sets came out instead generally). Once 20+ sets are diagrammed wheeling the "spare" out often won't work when it's either miles away from the right location or on maintenance. That happens even now with near enough twice as many hst sets as is required some days.
InvHst
9 Dec 2018
1a46 doesn't form off an Elgin anymore it forms of the 1407 Aberdeen arrival as the 1429 is a brand new set normally 2x158s
PG
I assume Aberdeen Crossrail is shorthand for the Montrose - Inverurie local stoppers and not some forthcoming new underground line through Aberdeen! :lol:
hexagon789
2 Sep 2016
Yes! :lol:
(I thought it was at least a 'known' term for the service if not exactly oft-used.)
27 Sep 2018
Not sure about 2K01/2G02 and 2G13/2K14 but the old cardenden 68 diagrams appear to be down as HSTs at the December timetable change
Morning diagram:
Evening diagram:
3 Mar 2020
Middleport
Much needed capacity for those services if usership rises again post Easter (or sooner) but a poor use of IC rolling stock that was brought in for other routes to offer an improved quality of journey for IC journeys. Imagine there will have to be at least a few extra IC services left as dmu stock to balance the use of a hst on at least 1 of the old loco hauled turns. The morning Fife set shown here narrowly misses being able to form the 0833 to Inverness too which comes off Haymarket But I fully recognise there are plenty of reasons that make tweaking things to merge the diagrams hard and what they are. The set off the Fife turn then appears to disappear to Haymarket for several hours.
27 Sep 2018
Am I right in saying that with the reduction of 3 Edinburgh to Aberdeen and 2 Aberdeen to Edinburgh Scotrail services after the timetable change that this means there’s HSTs for services that no longer exist, hence why they’re being deployed on the old 68 diagrams? There’s also a reduction of 3 Inverness - Edinburgh SR diagrams and 1 less in the other direction, presumably freeing up even more sets for diagrams like the fife circle
47827
3 Mar 2020
Middleport
You could well be right there. At present it doesn't matter even there was still to be a full timetable as there are a few sets yet to arrive and no intention of using all of them just yet. I'm thinking more into the realms of the post vaccine timetable if that's the best way of putting it. It's currently useful having up to 10+ hst sets a day if you wanted to stick them out on the Fife circle replacing the previous 68s in readiness for travel increasing again. What happens by the spring goodness knows. I recall for a number of weeks recently during the Aberdeen closure there was a hst that found its way onto the circle services for several hours on a Saturday, but that was a more temporary timetable and diagrams.
47271
28 Apr 2015
Let's hope that it's a temporary thing.
If in a year's time they're using HSTs on the Fife Circle, and I'm taking half an hour longer than necessary to get from Kingussie to Edinburgh because they haven't got their act together on a full HST timetable on the Highland Main Line then there's something not right.
221129
21 Mar 2011
Sunny Scotland
It was always the plan for HSTs to go on the Circle to replace the Loco hauled.
Wynd
20 Oct 2020
Aberdeenshire
My understanding is the HST sets are for the 7 cities, not the fife circular.
Its deeply disappointing that there are very very few HST sets on the Inverness - Aberdeen run and borderline unacceptable that not all of the Aberdeen - Edinburgh/Glasgow services are still 170's with no plugs!
The whole point of bringing in the HST sets was for the Aberdeen to central belt services.
hexagon789
2 Sep 2016
As has been mentioned this is for the interim period, it's not as though 170s are going on the Aberdeen runs cascaded out by the HST sets!
The passenger numbers at the moment make it more logical to use the cheaper to run 170s more than HST sets, once passenger numbers tick-up again to a reasonable level I'm sure diagrams will be re-jigged again to make more use of HST sets on the long-distance workings as intended.
27 Sep 2018
Not exactly a monumental change but there does seem to be an additional return HST diagram on the Inverness - Aberdeen line after the timetable change, 18:11 INV - ABD and 21:56 ABD - INV, as well as the diagram that already does the 0618, 1342 ABD - INV and 1102, 1714 INV - ABD
3 Mar 2020
Middleport
The last Aberdeen to Inverness service used to be booked a hst in the earlier days of Scotrail hst diagrams but it previously came off the Central belt on an arrival via Dundee. I think the 1811 ex Inverness being a hst is a knock on of other trains being removed from the timetable and it being necessary to change the diagrams as a result. I think the set off the first Aberdeen to Inverness now forms the 0845 down the Highland Mainline rather than a fresh set as the 09xx service appears to be one of the missing trains. Frequency on the route gone back to nearer to what it was 20 years ago but with an odd extra train still running, rather than "almost hourly" with an odd 2 hour gap.
InvHst
9 Dec 2018
First Aberdeen to Inverness will form the 0845 Inverness to Glasgow.
1209 Glasgow to Inverness will form the 1811 Inverness to Aberdeen due to the 1556 Inverness to Edinburgh not running.
Also the 1811 once arrives in Aberdeen goes to Clayhills depot which then doesn't necessarily mean the 2156 Aberdeen to Inverness is a hst as it shows as a hst on rtt but is a 170 diagram currently trust me a lot will be difficult to predict until rtt updates the first day
BRX
20 Oct 2008
No it wasn't.
It was the plan for the HSTs to come in and release DMUs from I7C runs to replace the LHCS service.
I keep getting confused when people write I7C because it looks so much like 170...
DB
Guest
18 Nov 2009
It's also rather ridiculous - clearly something thought up by a marketing agency. Why can't people just say 'Intercity', because that's what it means?
Well, to be precise it means Inter-7-Cities, referring to the seven cities in Scotland.
Speed43125
20 Jul 2019
Dunblane
Don't the announcements say 'intercity'? (i've not been the Queen Street in a while, and certainly intermediate stations just refer to the time the service arrives)
Either way, unlike say Azuma, I've not come across passengers who actually talk about 'Inter seven cities', so I would suggest perhaps we just drop it for the time being and re-evaluate if and when we get a full HST timetable running and judge based on official and passenger usage when that occurs.
