Scottish Electrification updates & discussion
Stopper
11 Nov 2017
That’s not always the case. Class 170s have turned up on the E-G in the past when the timing load was Class 385 EMU and vice versa.
Hence why I said 'fairly sure' rather than certain. I suspect though that the Class 385 timing load is deliberately slowed to make it closer to the Sprinter/Class 170 load - or else there would be junction conflicts.
route101
16 May 2010
Shotts line deserves a better service . Was on the 1003 which left around 1015 , packed 2 car 156 . Skipped stopped West Calder and Livingston South .
Funnily enough, rumor is that it's being electrified and will get an improved service. :)
Highlandspring
14 Oct 2017
Splitting hairs here - the accuracy of timing loads varies depending on service, and always bear some relationship to what actually runs. For example if it says Class 385 then you can be fairly sure it's not going to be a DMU operating it.
On the contrary I could put in a VSTP schedule for an Aberdeen to Kings Cross service actuslly planned to be operated by an HST (125mph) but set the timing load to a rail grinder working in traffic (3mph) and it would show up as the latter on Realtimetrains. Or vice versa! Isle of Wight class 483 from Thurso to Penzance? No problem, you can put in just about anything you want and adjust the times accordingly. Garbage in, garbage out.
Jessicas Dad
1 Mar 2015
I trust they sign off SDA sooner than 'near Christmas' since services are timetabled from Dec 9. And there must be sufficient C&C on the Grangemouth branch to turn round a 385 as that's what will happen in the evening.
Just to follow up on the Grangemouth bit - I was driving underneath the branch on the way down past the fire station at the weekend and noticed a few of the OHLE arms etc on the docks side of the bridge are still folded back parallel with the track.
Looking the other direction, towards Grahamston, there looks like a portal gantry on that side of the bridge with the OHLE terminating there, so I'm guessing that this is the end of the live section, although I could be wrong.
20 Mar 2012
Are we guarantee that we will see the 365s and 385s run to Stirling, dunblane and alloa in passenger service this sunday onwards?
Jessicas Dad
1 Mar 2015
I think this will depend on whether or not the ORR has signed the wires off for public use.
I'd imagine they haven't yet, or it would have been announced on twitter somewhere?
scotraildriver
15 Jun 2009
There have been serious issues with pantograph wear on the E & G in the last few days - indeed this was the cause of last night's failure at Croy. A number of 365s and 385s are out of traffic with damaged carbon. Suspect an OHL issue, lots of checking going on now.
diamond chap
25 Mar 2016
Is this OHL issue the cause of this evening's disruption? (https://twitter.com/ScotRail/status/1070717904776294401) "We have train which has developed a fault between #FalkirkHigh and Croy station. The driver is seeking technical advice and we will feed back when we have further information."
EMU303
24 Aug 2016
Seems like the electric trains are getting pulled off tonight and replaced by diesels
alangla
11 Apr 2018
Do any of the E&G fleet, other than the first 380 north of Larbert, have video monitoring of their pans?
alangla
11 Apr 2018
Someone will have a lot of video to watch. Hopefully they have some sort of computer vision that will be able to do a lot of the analysis for them, both now & going forward
EMU303
24 Aug 2016
Looks like another problem with the "electricity supply" today on the E-G route. Lots of cancellations and short forming with - presumably - diesels being used... doesn't auger well for the new timetable commencing Sunday and into next week... Does anyone know what the actual problem is?
59CosG95
18 Aug 2013
Between Peterborough & Bedlington
Sounds like the problem might be a bit of dodgy OLE geometry in the Croy area from reports I've heard.
There was a similar issue with the GWEP at Hayes & Harlington which saw a lot of 387s OOS with damaged pans, and a restriction of "Turbos only" on the shuttle service from Paddington. MENTOR was drafted in, the fault was identified and repaired, everything soon went back to normal.
Hopefully it shouldn't be too different up in Scotland.
Highlandspring
14 Oct 2017
Today’s issue was an unrelated overhead line trip at Edinburgh Waverley caused by a pigeon.
ld0595
1 Aug 2014
Tonight’s 23:17 Queen Street to Alloa was formed of 365521, marking what I think is the first passenger electric service to Stirling and beyond. Good to see that the hard work over the past few years is finally starting to pay off!
marks87
23 Jun 2010
Dundee
I think it might have been beaten by the 23:03 Edinburgh-Stirling; at least, I'm assuming that's the service pictured in the following Tweet given the time it was posted:
https://twitter.com/iainraehouse/status/1071546143446843392
