Scottish Electrification updates & discussion
GLC
21 Nov 2018
The Class 334 units, of which there are 40, can cascade onto the South bank services - Cathcart/Neilston/Newton, Inverclyde, and hopefully, East Kilbride and Barrhead too, working alongside class 380s.
334s on the Cathcart circle have been looked at before, but they would overheat if running all day. I'm not sure if running out to EK and Barrhead intermittently would be enough to cool them down
EDIT: Scotrail12 beat me to it :D here is a source of the overheating claims though. Granted it's an old document now, but nothing significant has changed for 334s traction wise I believe https://www.transport.gov.scot/media/12937/replacement_of_314_units.pdf
snookertam
22 Sep 2018
Class 380s have operated on the Cathcart routes on a daily basis for over a year now so I doubt there's an issue with overheating. Class 334 units were used as stand in units back in the day and again if there was any issue, I'd have thought there would be an operating restriction placed on them. Much of the North Clyde routes have a similar profile in terms of distance between stations so the units' traction motors will be getting worked hard there also.
The issue with class 380 (and class 385) units on the routes are mainly internal. No need for tables and the doors are too far apart. Aside from that they are fine in terms of acceleration. Class 318 and class 320 units are too cramped inside. Class 334s, especially if increasing the number of 6 car workings, would seem ideal. EDIT: I see the reference to the traction motors on the link above - maybe there is an issue with prolonged usage, but there has never been an operating restriction placed on them that prevented all day working on the Cathcart routes.
One issue with introducing the 334s onto the East Kilbride and Barrhead routes are whether conductors could work them. They are very much driver only units, which will not likely be introduced onto those lines without likely industrial action by the guards. Introducing driver only operation out of Glasgow Central any more than it already is would effectively see the end of the grade at Glasgow Central - there's no way it would be accepted without a considerable battle.
The 458s, which are similar to 334s, were built as 100mph units but re-geared for 75mph. This was something to do with the cooling fan being driven off the traction motor and not creating enough cooling at the speeds the 458s typically run at. As the 100mph capability was not needed, the re-gearing meant the motor and therefore the fan ran faster at normal running speed. Perhaps the 334s need something similar?
alangla
11 Apr 2018
There were some 334s that were modified with guards door controls and NRN radios for operating to North Berwick, same with some 318s. Not sure if the 334s were ever actually used in service in that mode, but the 318s definitely were. Was easy to ID them with the NRN pod on the cab roof.
Thus far, all electrification in SPT land has included a swap to driver only trains, will be interesting to see if this one does
route101
16 May 2010
Dont recall 334s operating to North Berwick, ccertainly the 318s did.
route101
16 May 2010
380s have been operating the Cathcart Circle for least 3 years . Yep , 318s and 320s are cramped with 3 - 2 seating .
route101
16 May 2010
334s used to occaisionally operate the Cathcart Circle , Neilston etc .Dont think any drivers are trained for them now on them routes.
youngac
8 Sep 2017
Some drivers must still be trained for the Circle and the Newton branch as 334s were used on the line during the Argyle Line blockade in summer 2018.
route101
16 May 2010
I see , ive not seen a 334 at High level for long time now.
Scotrail314209
1 Feb 2017
Edinburgh
Pretty sure there was a booked service to Carstairs during that blockade which was 2x 334
Roger B
16 Jun 2018
Gatley
The Scottish Government makes the decisions and Network Rail is responsible for delivery. The decarbonisation action plan will be published later in the Spring and will set out how decarbonisation by 2035 will be achieved.
Thanks CLC
Can we try to stick to Scotrail electrification updates on this thread please
Feel free to create a new thread (if there isn't one already) in the relevant area to discuss anything else (such as traction & rolling stock updates, timetable updates or speculative ideas).
Thanks
CEN60
17 Dec 2018
Is that confirmed?
Early feasibility has been looked at for Perth Stn and out to Barnhill Signal Box - Dunblane to Perth looked at also including passive provision for electrification. Plus S&C rejig at Dunblane & new long loops at Carsebreck. 100mph running in places also. NR are moving onto the next phase at the moment.
marks87
23 Jun 2010
Dundee
Presumably post-Perth they would then just keep heading north?
I can't think of anything between Perth and Dundee that would cause problems, but not so sure beyond, e.g. Dock Street Tunnel.
cyclebytrain
11 Jul 2009
Presumably Dundee to Aberdeen would also be used by Azumas coming from Fife as well as ScotRail services via Perth. Now that I think about it, that would mean that those wires could be used even before Perth was done; which raises the obvious question - what stage (if any) is planning for wiring Dundee to Aberdeen at?
gingertom
19 Jun 2017
Kilsyth
only the Tay viaduct on the exit from Perth. There has been talk of it being doubled, which would obviously need doing before the wires go up. The formation between the station and the river was double at one time, not sure about the viaduct proper.
30 Oct 2016
Current Tay viaduct is single track with a pedestrian walkway. It was never double, although the timber arched viaduct it replaced was.
47271
28 Apr 2015
Given that Stirling-Perth is the old Caledonian main line, built to exactly the same standards as the northern West Coast, 100mph here and there is the least I'd hope for. The more that route can be speeded up and have its capacity increased the less need we'll have for the woeful Ladybank-Perth route.
Noone should underestimate the time and disruption caused by Perth remodelling and electrification (and the complete rebuilding of the bomb site of a station), not least the work that'll need to be done to Moncrieffe Tunnel.
CEN60
17 Dec 2018
It was looked at for higher than 100 also! Moncreiffe Tunnel is perhaps not as bad an issue as you might think - signal sighting because of the tunnel is a problem from what i understand/ Big Ticket item is Earn Viaduct and the restrictions it has imposed on it!
JohnR
23 Jul 2010
There are already sections of it at 100mph. Its fairly straight and level, so I dont see why it couldnt be faster. Same with long bits of the [Perth]-Barnhill-Dundee stretch
gsnedders
6 Sep 2015
Question will be whether it's worth increasing it beyond 100mph, especially when ScotRail's safety-case is based on 100mph maximum and they're unlikely to get that much in way of gains from >100mph running on most of the network.
gingertom
19 Jun 2017
Kilsyth
quite so. Going from 100 to 125mph only gains you 6 seconds per mile, 10 miles running at the higher speed needed for 1 minute. There aren't many stretches of line where such higher speed running could gain significant journey time savings, although every little helps.
Brissle Girl
17 Jul 2018
7.2 secs in fact (a mile takes 36 secs at 100mph and 30 secs at 120mph).
But entirely agree with the sentiment that over relatively short distances it’s not worth it and the time saving can probably be more economically achieved by infrastructure tweaks such as increasing turn out speeds or modest line speeds at lower speeds.
Higher speeds also worsen capacity problems because the fastest trains currently can usually benefit, but due to station stops or using different rolling stock the slower trains often can't or at least don't benefit so much. So there is more capacity penalty from running a mixture of fast and slow trains.
hwl
5 Feb 2012
EMUs replacing DMUs on stopping services is probably the biggest impact on overall performance.
Southsider
10 Aug 2015
Tree cutting still happening on the EK line overnight despite the lockdown. Some more technical looking guys out and about today, one in a Network Rail van and the others in contractor’s vans, never noticed the name though.
Class 170101
1 Mar 2014
The best way to improve journey times has been said many times before inclusing below, improve your minimum speeds not your maximum speeds.
