The complete renewal really should be done by a grade separated junction. To avoid conflicting moves.
Electrifying EK is in the works as others have said. I definitely feel that the EK line would seriously benefit from electrification (and also 4tph in future). EK was my last proper train journey before lockdown and from what I gathered then, the DMU service is totally inadequate. Was reasonably busy but not excessively although I was travelling at the beginning of a Thursday afternoon. I can imagine that those services would be packed during the peaks.
Not seen anything about Maryhill but I don't think it would change much with only 2 units to be released (I think it's usually a 2 coach 158 on that route). Wasn't busy when I went on it a few months ago, only 2 or 3 others in the carriage. I just don't know if it would be worth it in the long run.
I assume any extra track would have to go, pretty slowly. around the Abbeyhill loop?It only needs to be if the lack of grade separation were the constraining factor on rail services here. It doesn't appear to be. More troublesome is the very low speed (15mph) and the single track constraints down to Shawfair. That results in bad reliability and timekeeping, and thus low capacity.
The big change planned for this area is the three-tracking of the approach to Waverley. It appears possible to add a third track all the way to Portobello Jn if required on existing railway-owned land. That could deliver a good chunk of the benefit of grade separation by allowing a Borders Railway train to take the southernmost track out of Waverley and stay on it while ECML services go back and forth on the northern two. It's not as much of a problem to have no grade separation in the station throat.
The tight overbridge beneath the junction of the A1 (London Rd) & Meadowbank Terrace would beg to differ...The big change planned for this area is the three-tracking of the approach to Waverley. It appears possible to add a third track all the way to Portobello Jn if required on existing railway-owned land. That could deliver a good chunk of the benefit of grade separation by allowing a Borders Railway train to take the southernmost track out of Waverley and stay on it while ECML services go back and forth on the northern two. It's not as much of a problem to have no grade separation in the station throat.
As @railjock says, adding a 3rd (or even 4th) track east from Edinburgh would require reinstatement of the Abbeyhill Loop - which would be detrimental to ECML fast services. If Borders Railway trains were to be rerouted via Abbeyhill, a diveunder beneath the ECML just east of Craigentinny would indeed be required. However, North Berwick/Dunbar trains could just as easily be rerouted that way instead, without the requirement to massively alter Portobello, but with the added cost for electrifying the loop. It does however add an incentive to re-open the closed stations at Abbeyhill & Piershill...
They are both types of EMU?The reports appear slightly contradictory, in that in one place it only talks about electrifying the line to East Kilbride, but further down it talks about possible rolling stock on both lines being 380s or 385s
1 and 5 covers the entire route from Larkfield Jn to Barrhead with 2, 3 and 4 covering the EK line, so both Barrhead and EK are due to be electrified.The project has been split into route sections for design/delivery, as shown in Table 1 below and in Appendix A. Routes 1, 2 and 5 are proposed to be electrified. Routes 3 and 4 are proposed to be electrified and double-tracked.
Thanks for the clarification!In the document EIA SCREENING EK-B FINAL VERSION 27052, page 5:
That's news to me! Although, if works progress to Auchterarder as you say, that's a little bit further than the new Highland Spring sidings at Blackford. Wonder how they're going to wire Gleneagles too...The electrification depot should be moving from Cadder to Greenloaning shortly with stage one of the work proceeding from Dunblane to Auchterarder. Possibly to wire up to Russells Highland Spring Depot.
I heard the engineers had planned to wire to Barrhead first as there were fewer problems with over bridges on this section. East Kilbride will take a little longer due to difficulties with track lowering drainage and the rebuilding of the overbriges plus the double tracking from Busby to East Kilbride. Also a problem in the Crossmyloof Pollokshields area gaining clearance under the bridges.
Out of curiosity, there are relatively few services that terminate at Perth from the Dunblane direction, and with no bimodes either, what would be the purpose of electrifying Dunblane to Perth at this stage? Is it to extend some of the Dunblane terminators to Perth - if so that's quite a long extension of those services.
Mostly because it's a necessary first step to heading further north? The reason to do it in preference to Fife is that the Fife Circle is going to be exceptionally difficult.Out of curiosity, there are relatively few services that terminate at Perth from the Dunblane direction, and with no bimodes either, what would be the purpose of electrifying Dunblane to Perth at this stage? Is it to extend some of the Dunblane terminators to Perth - if so that's quite a long extension of those services.
Is the difficulty of the Fife Circle the Forth Bridge? Or is it something else?Mostly because it's a necessary first step to heading further north? The reason to do it in preference to Fife is that the Fife Circle is going to be exceptionally difficult.
Maybe the freight facilities grant included a contribution to wiring. Certainly allowing the trains to be hauled by, say, 88s throughout would be a nice bit of greenwashing (given that transporting water in PET bottles isn't at all green).
Both that and several of the tunnels (I believe many of the tunnels along the coast are very tight).Is the difficulty of the Fife Circle the Forth Bridge? Or is it something else?
Many thanks - any thoughts, @Bald Rick ?Both that and several of the tunnels (I believe many of the tunnels along the coast are very tight).
