Searchlight signals
Tomnick
10 Jun 2005
Trying to think how best to explain it! Put simply - it means that rather than having three separate lights on a three-aspect signal, you'd have just the one on a searchlight signal, that's capable of displaying all three colours (red, yellow, green). This used to be achieved mechanically in the older installations by moving a disc with different coloured lenses in front of the light, but newer ones - as with the North Staffs resignalling, I suspect - use LED technology to achieve the same effect.
Note that the searchlights in question also have to have a second light mounted above, in order to display the second yellow required for the YY aspect!
nutter
13 Nov 2005
Albrighton, Nr. Wolves, Shrops
I know what you mean, and i think you are right. One lens can display Green, yellow and red using LED's and there is a second LED above which can only present Yellow. (I've seen this on another forum).
Thanks.
I've cheered up now, ATW had cancelled a train this morning which really wound me up because I was supposed to spend the day with the TA. BVE and simsig can work wonders sometimes
O L Leigh
20 Jan 2006
In the cab with the paper
Perhaps in your neck of the woods...
The recently West Anglia re-signalling saw the introduction of LED ground position light signals, but we got standard 4 aspect signal heads for main aspect signals. Interestingly, these replaced the old style 4 aspect searchlight signals with rotating coloured filters.
one TN
Nick W
5 Nov 2005
Cambridge
Oh I thought it was still done mechanically as I have seen the ones at colcheter flicker and go via yellow from green to red as if they are still the ones that one TN mentioned were replaced.
Z12XE
30 Sep 2005
Maybe because Colchester want resignalled as part of the WARM? (which is quite understandable.....!)
Colchester-Clacton resignalling is 2007+
andel
8 Feb 2006
I think they have searchlights between Leamington and Banbury too (well, they did yesterday when I went along there)
