season ticket slough to eastbourne
Discussion in 'Fares Advice & Policy' started by Slough, 20 May 2015.
Thread Status:
  1. Slough
    Slough Member
    50
    13 Apr 2012
    Hi , looking for advice on the best value annual season ticket between slough and eastbourne .
    Ideally with southern trains as I can pay in 12 monthly instalments . I was thinking eastbourne to london travel card zones 1-6 , and a ticket from slough to west drayton.
    I will be sometimes starting and finishing the journey at feltham though, also I have seen you can get an annual ticket from eastbourne to reading .
    What are the limitations on this ticket ?
    Also is an annual season ticket an anytime ticket and is the travel card part of it also anytime ,
    can i travel from eastbourne to brighton to london all zones as well on the annual ticket as sometimes this is an accepted route.
    thanks in advance
    Rail Forums
  3. Romilly
    Romilly Established Member
    1,554
    5 Nov 2013
    A lot of questions here.
    First, a Reading-Eastbourne season is very expensive - over £6,000 for an annual, and I think it would not include London Terminals, i.e. it would be valid via Gatwick, or via Clapham Junction (and Gatwick).
    A Feltham-Eastbourne annual season would be £3,736 and you could combine it with Slough-Feltham day tickets (via Windsor - £6.70 anytime day single, £12.80 anytime day return) when necessary. But that presupposes you would be happy to go via Windsor when you weren't starting/ending at Feltham. And the season itself would be valid via Clapham Junction but not London Terminals
    And yes, a season ticket is an "anytime" ticket, as is a weekly/monthly/annual travelcard.
    So far as I can see, it is permitted to travel between London/Eastbourne via Brighton.
    The difficulty with two season tickets as you suggest, is that you would be limited to using trains between Paddington and Slough that called at West Drayton. On the other hand, an Eastbourne to Zones 1 to 6 travelcard would cover Eastbourne-Feltham because Feltham is in Zone 6.
    Also, see part 5.11 of the Forum's ticketing guide for customised travelcard seasons, i.e. a Slough to Eastbourne via Zones 1 to 6 travelcard.
  4. clagmonster
    clagmonster Established Member
    1,915
    8 Jun 2005
    There is no season fare in the system for Slough-Eastbourne. However, as there are Travelcard fares for both, one could be calculated.
    Slough - London Zones 1-6 weekly is £81.30.
    Eastbourne - London Zones 1-6 weekly is £131.80.
    The total of these is £213.10.
    An inboundary London Zones 1-6 weekly is £58.60.
    Thus, a weekly Slough - Eastbourne season, route London Zones 1-6, would be £213.10 less £58.60, which comes to £154.50.
    An annual would be 40 times this fare, so £6180.
    A monthly would be 3.84 times the weekly rate, so £593.28
    I don't see why this wouldn't be available on the Southern Direct Debit scheme, after all it is a Travelcard season and your origin is served by Southern. For an unusual one like this, I'd be tempted to contact them first.
    For travel to Feltham, the ticket would be valid as Feltham is in Travelcard Zone 6.
  5. Slough
    Slough Member
    50
    13 Apr 2012
    just to spoke to southern , annual ticket is not available from slough to eastbourne only a daily ticket that will cost a fortune.
    So , would i be able to use the reading to eastbourne annual season ticket like this .
    slough to pad
    pad to vic
    vic to ebn ?
    or would I have to go reading to brighton and brighton to eastbourne ?
  6. bb21
    bb21 Moderator Staff Member Moderator
    22,447
    4 Feb 2010
    Annual season ticket is not available between Slough and Eastbourne.
    Annual customised Travelcard as described above is available. Did you specifically mention it? It would not be in the fares database. It needs to be manually created, and they should be able to find details of customised Travelcard season tickets in the Knowledgebase.
  7. Slough
    Slough Member
    50
    13 Apr 2012
    Hi , yes I mentioned that I was told it's not on the southern website so it's not available .
    Thanks for the re-assurance I will give them another call
  8. Romilly
    1,554
    5 Nov 2013
    On the National Rail season ticket calculator, the Reading-Eastbourne season tickets are stated to be not valid via London Terminals (so not valid via Paddington and Victoria). There doesn't seem to be a quoted price for a Reading-Eastbourne season ticket via London, but that's presumably because you would be expected to buy a customised travelcard (and one that would be more expensive than one for Maidenhead-Eastbourne).
  9. bb21
    22,447
    4 Feb 2010
    Yes, the only season ticket between Reading and Eastbourne is routed Not Via London. For travel via London, the default position is as you stated.
  10. Bletchleyite
    Bletchleyite Veteran Member
    26,611
    Up and down the south WCML (mostly)
    I believe if you get one calculated it often ends up put on the system for future use. I half remember this happened for MKC-Slough for me - it's certainly still there.
    If no joy with customer services I would suggest going to a staffed station at a quiet time and they should be able to handle it.
  11. Slough
    Slough Member
    50
    13 Apr 2012
    no joy again with either the national rail indian call centre or southern themselves , apparently as slough is fgw they can't help
  12. Bletchleyite
    26,611
    It isn't specifically a Southern ticket so they should be able to do you one there.
  13. bb21
    22,447
    4 Feb 2010
    I can't seem to find any information on the Southern website regarding paying your annual season ticket in 12 monthly instalments. Do you mean their Monthly Season Saver scheme where you pay for 11 monthly season tickets and get the 12th free?
  14. Slough
    Slough Member
    50
    13 Apr 2012
    Yeah sorry it looks like it was the monthly one I would be interested in , still not available though according to southern.
  15. bb21
    22,447
    4 Feb 2010
    Condition 2.1 of the scheme seems to suggest to me that your ticket may not be eligible as the journey cannot be made "across the Southern network", since Southern do not operate out to Slough, although that term is sufficiently vague and is open to alternative interpretations.
    Note that the tickets must start on the 15th of each month and you may not make any changes during the subsequent 11 months in order to be eligible for a free one.
    Follow the tweet.
  16. globetrotter
    globetrotter Member
    83
    7 Jan 2011
    How about two season tickets, as follows:
    Slough - London Z5-6 £1528 route "any permitted"
    Eastbourne - London Z1-6 £5272 route "any permitted"
    Seems to me that this would allow any routeing including via Windsor to Feltham. Horribly expensive, though.
    Perhaps the latter one could be payable in monthly instalments.
  17. bb21
    22,447
    4 Feb 2010
    That would be a compromise assuming that the customised Travelcard is not available on instalments as the second one would definitely be available for that.
Thread Status:
Share This Page
